Results 1 to 3 of 3
    Reputation: fat_tires_are_fun's Avatar
    May 2013
    Wheelset question for Fargo owners
    Hello,
    I would like some input/recommendations from Fargo owners for a new wheelset. I recently purchased a pre owned Fargo and am really enjoying it. It is my first, and currently only, drop bar bike. I realize the Fargo is more intended for trail use, but I would like to purchase a lighter weight more versatile wheelset that I can use for gravel riding, etc.
    any recommendations for a wheelset that can accomodate a set of cross tires as well as mtb tires? Thanks
    - MOOTS Mooto X
    - Salsa Fargo
    - Niner RLT9
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Any XC type 29"er wheel set will do just fine. Keep the inner rim width to under 25mm and any 35-50mm tire will work great on it. Depending upon how much you want to spend, you should easily get a wheel set under 1500 grams. Also- your new wheel set should cover you for both trail/XC and gravel duty. No need for two separate wheel sets at all.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    2OFME
    If you want to go tubeless, then I suggest the Stans Crest rims. You can find deals on pre-built stans wheelsets with stans hubs and crest rim. Expect to pay in the $550-$650 range for a complete wheelset. Relatively light too.
    As G-T points out there are many options. I'm running Stans arch rims on stans hubs. I do some camping with mine and carry some gear so I wanted something a bit burlier. Truth is I could probably go crest and not really notice a difference.
  1. Replies: 0
    Last Post: 08-20-2013, 11:25 AM
  2. Replies: 0
    Last Post: 08-20-2013, 11:20 AM
  3. to all the Salsa Fargo owners...!
    By lee paolo in forum 29er Bikes
    Last Post: 05-25-2013, 06:56 AM
  4. Any Spearfish AND Fargo owners?
    By johnnystorm in forum Salsa
    Last Post: 10-14-2012, 11:15 AM
  5. Replies: 22
    Last Post: 08-13-2012, 10:55 AM
