Page 25 of 25 FirstFirst ... 152122232425
Results 2,401 to 2,491 of 2491
Thread: Vaya Builds
  1. #2401
    Jun 2010
    Quote Originally Posted by Simonns View Post
    Just to update this, Salsa gave me a crash warranty on the orange GX frame. I swapped the parts from the other frame, built some new wheels cause of the 15mm axle and bam, a newish bike!
    How different is the ride between the two frames? I keep eyeballing the new vaya or the RLT 9 steel but just can't convince myself there will be enough of an improvement to merit the "upgrade".
  2. #2402
    Reputation: CaptainSlow's Avatar
    Quote Originally Posted by edthesped View Post
    I'm curious about this too. I own a 2010 vaya that I love, it's a touch large and I would like to size down.
    I'm not interested in the carbon fork, but I bet it makes the ride a bit smoother. I'm interested to see how the offset fork influences the ride. The full cable housing and replaceable derailleur hanger are also something my current vaya doesn't have that I want.
    My only WISH for the vaya would be threaded boss under the fork crown and rear triangle for fender so they look nice. Seems like it would be easy to feature to add.
  3. #2403
    I dream on two wheels
    Reputation: Simonns's Avatar
    The frame rides a little stiffer than the 2010. Could be the 15mm axle and the wheels I build for it are stiffer. I don't really notice the offset in the fork but when braking hard the fork doesn't flex at all compared the 2010. One other thing to note is the frames sizes are a bit different. The old frame was a 56 and seemed a bit small. My feet would rub the front wheel when taking slow sharp turns. The new frame doesn't come in 56 so I moved up to a 57 and I haven't had the rubbing problem but the cockpit seems tighter despite having the same handle bars and stem as the last frame. I haven't really compared the geometry between the two frames but I'm guessing there's a difference.
    I'm torn on if I like the replaceable hanger. On the old frame I bent the hanger probably 10 times and was able to just bend it back no problems. I'll need to buy some hanger replacements for this frame.
    The only other difference I noticed is cosmetic, but the attention to detail on the 2010 frame far exceeds the new frame. "Ride and smile" is stamped on each drop out and the decals are way more detailed on the old frame.
    Whiskey
  4. #2404
    Sep 2012
    My 2012 Fargo has the "Ride and Smile" dropouts as well. I wonder when they gave up on those. I like them!
    2012 Salsa Fargo 2
    2017 Salsa Timberjack
    2009 Giant Yukon
    2015 Motobecane FB4 Fatbike
  5. #2405
    Jun 2010
    Quote Originally Posted by SocratesDiedTrolling View Post
    2013 Vaya has it on the fork dropouts for sure, just fixed a flat tonight and saw it.
    Also, my 2013 uses a wheels manufacturing 142 hanger. I carry a spare hanger in my tool kit.
  6. #2406
    Oct 2010
    2015 Vaya Travel fork definitely has it.
  7. #2407
    Reputation: Drummerboy1975's Avatar
    What's the largest tire you can run on a Vaya?
  8. #2408
    Oct 2016
    Depends on the year. If you have 100/135 QR dropouts then mine will handle 44's without fenders
  9. #2409
    Aug 2016
    A guy in a german forum put Conti Race King 2.0s on his. [Link] to his photo page.
    Me, I'm currently still on the stock 41 Knards. They're OK, if a bit slow on pavement. I'll be trying Marathon Supremes 2.0 once the Knards go.
  10. #2410
    Quote Originally Posted by benhimself View Post
    That's rad. I've wanted to pull my fender off and run a set of 2.1 THUNDER BURT HS 451's for grinding the gravel/fireroads around here. I knew clearance would be tight, but glad to the race kings fit too.
  11. #2411
    Human Test Subject
    Reputation: Volsung's Avatar
    FWIW I read that Thunder Burts measure out to 2.0.
    Contis run small too.
  12. #2412
    Oct 2016
    My Frankenbike rebuilt, powder coated 2012 Vaya frame on a 70° February day in Kansas. My fingers almost refused to type that.
  13. #2413
    Oct 2015
    Quote Originally Posted by rashidkpc View Post
    2015 57cm Vaya Travel. I swear its in there somewhere
    Attachment 1089137
    what is this sorcery? is the mesh and straps a specific product, or did you make this yourself? my lbs has a travel in stock and i'm not normally into road bikes, nor do i travel, but i haven't been able to stop thinking about it since i saw this picture.
    2003 Kona A
    2005 Kona A
    2012 Cannondale Hooligan
    2016 Salsa Deadwood
  14. #2414
    Reputation: schnee's Avatar
    They are an S&S coupler thing. The Security Net.
    Security Net used to protect your bike if TSA opens the case
    Yamaguchi Cross • YT Jeffsy • Salsa Mukluk & Vaya • Canyon Commuter
  15. #2415
    Oct 2015
    Quote Originally Posted by schnee View Post
    tyvm
    2003 Kona A
    2005 Kona A
    2016 Salsa Deadwood
  16. #2416
    I'm looking for a recommendation on a good locking skewer. My vaya is my daily driver and while I'm careful where I lock her up I worry about my wheels getting ripped off. I typically lock the front wheel with the frame and bike rack, however a little extra security never hurts.
    The ones below will seem to work, but they look cheap.
    https://www.biketiresdirect.com/prod...FY17fgod0iAOWA
  17. #2417
    Human Test Subject
    I've been using Sunlite 5 sided Allen key locking skewers for a few years. Nothing will stop a determined thief but these deter the casual passerby.
  18. #2418
    Nov 2016
    I would recommend locking your rear wheel inside your U lock, then using a looped cable to run through the front. Locking skewers are fine, but you will still be better off upgrading your lock than spending money on something that won't protect your bike as a whole. Maybe you already have a nice lock and are looking for extra security. Just remember, it's not just how much hardware you have that deters thieves, but where you lock your bike up. For example, I will choose the rack in front of a busy coffee shop rather than in the middle of a larger bike lock area. The more public your spot is, the less likely someone will be able to swipe something. Good luck!
  19. #2419
    Jun 2005
    Beautiful builds here! I love my current Vaya, but am looking to upgrade. Here are my thoughts on what it would take to make the BEST possible (mechanically not necessarily aesthetically) Vaya build. This would be for winter commuting and short bikepacking trips in mountaineous terrain.
    1) Lower gearing than anything available on the stock 2017 Vaya builds
    2) Hydraulic disc brakes
    3) Shed a little weight (not that important)
    I'm considering a couple options I haven't seen here.
    Option A)
    Shimano RS505 (105 level) hydraulic brifters and brakes, ultegra front and rear derailleur, 11-32 11 speed cassette, XT8000 38-22 double crankset (I'd have to buy a 38-28 and swap the inner ring). This would probably be the front runner but I'm not sure how well the front shifting would be and the XT crankset has a q factor of 170 vs the 150 road I'm used to, not sure how that would be long term.
    Option B)
    Full XT8000 3 x 11 triple drivetrain (40/30/22) with 11-32 or 11-36 cassette. Microshift bar end shifters. TRP Hylex RS hydraulic brakes. Negatives of this setup would be bar end shifters may not be as good for commuting (having to take your hands away from brakes a safety issue?). Also I feel comfortable Shimano hydraulics are as reliable as hydraulics come; not sure about TRP Hylex.
    Option C)
    My friend is selling a force 1x hydraulic groupset for a decent price. Negative of this setup would be that I would lose a lot of top end gearing if I set up the crank for low gearing (or have huge jumps between gears).
    Wheels would be a big area to cut weight as would be getting a frameset with the carbon fork (have ridden both extensively and think there are positives and negatives of both, but that's another subject).
    What do you guys think? Thanks in advance!
  20. #2420
    Jun 2010
    Quote Originally Posted by marcusab View Post
    Option A)
    Option B)
    Option C)
    Another spendy option would be a Sugino compact + double, narrow Q factor and smaller chainrings coupled with an 11-36 rear cassette and brifters of your choice.
  21. #2421
    Jun 2005
    Thanks for the heads up - that's a beautiful crankset. I probably could swap out the inner ring for a 24t with the 74 bcd. Ultegra I think can't do 11-36 in the rear officiallly.
  22. #2422
    Sep 2015
    Option A)
    Option B)
    Option C)
    you won't lose much top end with force 1 if you have a cassette with a 10t cog, depending on what size chainring you select.
    my girlfriend has a vaya with a xt 42-28 crank/fd with ultegra 11speed shifters which works fine except for trim. i don't think the q-factor is really that noticeable.
    that said there are other (better imo) options, mostly made possible by the wolftooth tanpan or roadlink. i have an ultegra 46-36 with an 11-40 cassette via a roadlink. i think with a tanpan and an slx or xt gs rd (which would allow an 11-42 i believe) would be even better.
    pair any of these options with the rs685 shifters (which are fantastic) and i think that checks all your boxes. i doubt you'll drop any weight though.
  23. #2423
    Jun 2010
    I've been running an OX601D for a year now and have been pretty happy with it overall, I do however experience chain suck if I'm mashing during a downshift though so I have to make sure I back off a bit when I downshift on the crank. I got my setup at HubJub prior to their selling retail boxed sets so I was able to tailor my rings a little better than you can now.
  24. #2424
    Jun 2005
    thanks for the heads up regarding your girlfriend's vaya with the 42-28 xt. what are the trim issues - does she get a lot of chain rub?
  25. #2425
    Aug 2016
    Given assumptions: 90 rpm, 622-35 tires, no more than 2,6° chain angle.
    Option A gives you a speed range from 10.2 - 41 km/h with a biggest noticeable gearjump of 14% from 38-16 to 38-14 (jump from 28 to 32 km/h, you will notice this). Total bandwidth is 395%.
    Option B (11-32) gives you a speed range from 8.1 - 43 km/h with a biggest noticeable gearjump of 9%, which is good. Total bandwidth is 529%. You would buy this with a triple setup though, which is in reality less usable and jumps wider than the gear calculator would make us believe; due to the fact that people (at least, I do) tend to switch more in the back and less in the front.
    Option B (11-36) gives you not a lot of change except you can go down to 7.2 km/h with 90rpm. Since the gear calc doesn't offer the Shimano cassette in 11-36 I had to use the SRAM cassette, which is apparently spaced wider in the higher gears - resulting in a gear jump of 13% from 30-11 to 40-13 (as said before, more probably you would jump 15% from 40-15 to 40-13: speed-wise, this jumps from 29.5 to 36.5 / 28.5 to 36.5 km/h). How much gear you need in the low range you will need to find out yourself. Total bandwidth with this would be 595%, but changes at lowspeed always give more % than changes at highspeed so it doesn't mean too much.
    Option C is the 1x variant of the force groupset; I assumed an XD 10-42 cassette and a 36 tooth chainring; this gets very close to option A with a speed range of 10.1 to 43 km/h. Naturally gear jumps are higher, with as much as 20% between 36-12 (35.5 km/h) and 36-10 (43 km/h); usually this will be less of a bother as the higher-mid-range jumps are what's relevant. These are fairly nice with 2-3 km/h increases up to 30 km/h. Total bandwidth for this is 420%, which would give you more than the 2x11 setup from option A, but of course the tuning options for A are much wider due to the double chainring setup.
    The probably more usable variant for A would be a 24-38 (8-41 km/h) setup, or a 28-40 (10-43 km/h) if you'd rather have high range. Of course the gear calc doesn't offer all possible combinations but rather standard manufacturer offerings. More extreme examples for special chain ring combinations would be this 44-26 combination or this 50-32 setup.
    My 2 cents is that a 2x10 or 2x11 setup is the best usable option in the real world, giving you tunable low gears as well as tunable high gears. I am not a big fan of 3x setups, but if you want an option giving you exactly 90 rpm with any possible combination of load, incline and headwind, that's your way to go. I'd rather not use 1x setups for touring, although you can tune them to your needs if you know the terrain to come. However for joyrides and overnighters, 1x is excellent.
    Cheers,
    Ben
    Gear calculator used: Ritzelrechner which is about the best currently in existence.
  26. #2426
    My Vaya in "race" setup. This is with a newly built wheelset with Schwalbe G-One speed tires on Stan's Ztr Grail, spoked with Sapim D-lights (28 front and rear) on Hope Pro4 RS hubs.
    Other noteworthy parts are Sram Rival 1 hydraulic groupset, Brooks Cambium C17 saddle and Ritchey Evomax handlebars. The saddle and handlebars are going to be switched soon, the saddle for a more narrow C15 and a the handlebars for wider Easton EA70 AX.
    I'll post another picture of commuter-mode soon.
  27. #2427
    Jun 2005
    Hey Ben,
    Thanks for the tips. I agree with you that the wide range double is probably the ideal way to go. It seems that we both agree that total range and having small steps between gears is important for touring bike gearing.
    I don't understand why some people favor gearing like 46/36 and 11-36 or 11-42 (as mentioned above in the thread) - seems like you end up having big jumps between the gears the in way that most people shift (mainly with the rear, as you mentioned). In my ideal world I would have something like 42/16 with 11-28 11 speed if there were any systems that could handle that (haha). That would give a huge range of gearing, minimal overlap, and small steps between gears in the rear.
    Best,
    Marcus
  28. #2428
    Human Test Subject
    Quote Originally Posted by boowks View Post
    I just put some Evomax bars on mine too. HUGE stiffness improvement over the cowbells. I sized up to 46 too so there's more stability too.
    I had to put studs back on and also warranty a Compass Snoqualmie pass. It always bothered me that they measured out to be 41.8mm on my Velocity Ailerons (20mm internal width) so I put one on some Velocity Blunt SS and they measured 44.7. Blunts are like 25.6mm internal width.
    You change your own flats? Support your LBS and pay them to instead.
  29. #2429
    Sep 2015
    Hey Ben,
    Best,
    Marcus
    i think people prefer it because there aren't other good options. you'd need a crankset with a different bcd and possibly a different q-factor. and mtb fd are often only semi-workable with road shifters. my girlfriend has a deore xt fd and crank with ultegra 11 speed shifters and it works but trim does not. ideal for me would be 46-30 x 11-32, but 46-36 x 11-40 works ok until that is easier to do.
  30. #2430
    Sep 2015
    is there any brake rub when out of the saddle or anything? i am thinking about putting shimano's hydraulics on mine (a 2015 frame) but am worried the clearances are so tight that it will be both annoying to align it when putting the wheel back in and prone to rubbing.
  31. #2431
    Feb 2014
    I'm one of the oddball people that still uses compact road gearing (50/34 and 11-32), but I don't have an issue making it through the hills/mountains on a 34 up front. For the back, small increments bug me, I just end up jumping 2 gears at a time. Loaded touring is pretty much all I do lol.
    Still taking good care of my baby, but the racks and seat show a bit of mileage
  32. #2432
    Quote Originally Posted by zmjones View Post
    There is some rubbing, but very little and not enough to annoy me. Then again, I am used to some disc rub from my mtb.
    Can't say I have any alignment problems when putting wheels back. When I change wheels a 2-minute fix is enough to deal with any alignment that isn't quite right.
  33. #2433
    I'm going to test ride a Salsa Vaya 2015 in light blue this week. I hope I like it!
  34. #2434
    Jun 2005
    Any of you guys put thought into carbon vs steel fork Vayas? I've ridden both (have the steel and test rode the carbon a bunch) and here are my impressions.
    Benefits of steel:
    soaks up big bumps really well
    seems more appropriate for the utility like feel of the bike, don't have to worry about it as much with travel, crashes
    Benefits of carbon:
    saves about a pound on weight
    stiffer
    In terms of comfort, I would give the steel fork a definite win. Carbon with thru axle is stiff - it doesn't absorb the big hits (which annoy me more) but is just as good as the steel with small road chatter. The carbon definitely is not bad though, still a very comfortable bike.
    I have noticed some instability on my steel fork when braking and coming down a hill while moderately loaded with two panniers. I thought this was the steel fork getting wiggly, but based on the some comments earlier in this thread I think it may be brake judder.
    I actually called the guys from Salsa to ask them what they thought in terms of ride quality, and they agreed that some people find the carbon with thru axle stiffer and my sense that it didn't absorb the big hits as well could make sense. They did say that the stiff thru axle fork helps keeping a line off road.
    Anyone else with similar/different experiences?
  35. #2435
    Jun 2005
  36. #2436
    Benefits of steel:
    Benefits of carbon:
    stiffer
    I definitely prefer the feel and comfort of steel and I will gladly take the weight penalty. The carbon fork tends to be more damp(soaks up more small vibrations than steel), however it doesn't take the big hits well like you've mentioned and for me that is very important.
    However, I haven't noticed my steel fork being "wiggly" that would be cause for concern. Mine is solid as ...steel
  37. #2437
    Love this bike. Just put the Vitesse EX's on and really digging them so far.
    Oh noes. I'm going to drink the Kool-Aid.
  38. #2438
    Jun 2015
    I have the Vaya 3 2015 model that came with the Sun SR25 rims and I have a couple questions I thought might get answered here....
    Will 25mm road tires work on these rims? If so, is this a good idea?
    Has anyone done a century on their Vaya?
    What would be a decent wheelset to replace the one I have?
    Thanks for any input.
  39. #2439
    Aug 2016
    The SR25 has an inner diameter of 20mm - the smallest official width suggestion of Mavic for that rim width is 32mm. Companies usually err on the side of caution, but Mavic tend to know their shit - I myself would probably not go smaller than 30mm and call 28mm cutting it close.
    The other question is, why would you want a 25mm tire? A 28mm is in 90% of all possible conditions faster (less rolling resistance) and more comfortable, unless you have a really smooth tarmac or really fast travel speed (40+ km/h) where aerodynamics play the superior role.
    Regarding wheelsets, for this season I ordered one with WTB cI24 rims (following the "road plus" trend), for aluminium options I would look at wheelsets with WTB KOM or Velocity Aileron rims.
    Centuries are not a very difficult thing to do, on a Vaya even less so than on other bicycle options as it is designed to carry you (and some luggage) in comfort. I ride metric centuries pretty regularly, an imperial century only once so far.
  40. #2440
    Sep 2015
    well how difficult they are depends on how fast you want to ride and your local terrain. it is hard for me to avoid doing less that about 7000 ft of climbing in 100 miles, which isn't a ton but definitely took it out of me the first few times i did it.
    as far as replacing the wheelset, i'd look for a wideish (> 17mmm internal width) tubeless alloy wheelset. something built with hed belgium, pacenti sl25, easton ec90sl, etc. rims will be good. i'd look on pinkbike/ebay.
  41. #2441
    Human Test Subject
    Never listen to Mavic when it comes to rim width. They finally moved away from 15i road rims like a week ago.
    I tried some 23c tires on 20i Ailerons, but as Ben said, go at least 28. Vayas are designed around a 40c tire though so you'll be low riding.
    If I didn't run 30c Xerxes in the winter I'd build up a wheel with Velocity Blunt SSs and White Industries hubs. If you're under 5'10 or so i'd go 650b, if you're taller than that do 700c.
  42. #2442
    Aug 2016
    Quote Originally Posted by Volsung View Post
    Now I am not a fan of very narrow rims either, but I don't think this is a good reason for dismissing their know-how. Their recommendation for 15c rims are tires from 23 to 32mm, which sounds pretty much spot on to me, which also means that there are applications where 15c rims make sense.
    These just aren't what we ride, though.
  43. #2443
    Reputation: steelcityadv's Avatar
    Dec 2015
    Looking at picking up a Vaya soon to do some light touring with. Thanks everyone for the info in this thread.
    Sent from my SM-G900V using Tapatalk
  44. #2444
    Jun 2015
    Quote Originally Posted by Sparky831 View Post
    I ended up getting 28mm Gatorskins. I have two rides on them and they are great so far. All riding I have done is on country back roads with some bumps and potholes and a couple short sections of gravel. Riding at 110psi. So far so good. I'm still going to get a second wheelset so I can switch between my Clement tires faster.
  45. #2445
    Jun 2015
    Can anyone point me towards a thread entry that has the weight of the stock wheelset on the 2015 Vaya 3? The wheelset has the Sun SR25 rims with the Formula Salsa hubs.
    I just want to make sure I'm shedding weight when I get a new set and not adding weight.
    Love this bike, it goes everywhere.
    Very impressed with the Soma Supple Vitesse stiil...amazed I haven't flatted yet and grip on or off road is really good. Very predictable tire.
  47. #2447
    Jun 2015
  48. #2448
    Aug 2016
    \o/
    This has to be one of my favorite Vaya builds so far, it combines aesthetically pleasant functionality with small loving details like the chainring screws and the stem spacers. Nice to see you on here too!
  49. #2449
    I bought a 2016 Vaya Deore to do some bikepacking with. I'm doing a trip in Colombia in September and am shopping for bags and things. Not going with racks. Does anyone have a handlebar bag recommendation that would work with the stock bars and still let me shift? Any good ways to mount a couple small dry bags to the fork? I will be carrying light camping setup. Is there any way to get those triathalon handlebar things then maybe hang a bag off of that to give more cable clearance?
  50. #2450
    Oct 2010
    Quote Originally Posted by vayaist View Post
    Ok, you convinced me. I ordered a Pizza Rack, it'll be here Friday.
  51. #2451
    Jun 2017
    Check out Ornot bar bags. Not really touring specific but I've had mine for about 3 weeks and love it for commuting to stuff a change of clothes, lunch, and wallet/phones/keys. Seems durable enough to me to last for years
  52. #2452
    Jun 2017
    Quote Originally Posted by fixmefixmyhead View Post
  53. #2453
    Quote Originally Posted by Obear View Post
    Thanks, I ended up going with the specialized burra burra handlebar bag. It's awesome. Went on my first overnighter last weekend, the vaya was awesome even on some rough steep downhill
  54. #2454
    What is the best way to get a bigger climbing gear on my 2016 vaya deore? When loaded with my bikepacking gear it was really heavy to pedal up steep climbs.
    Sent from my SM-G955U using Tapatalk
  55. #2455
    Oct 2015
    cassette with larger big cog and/or smaller chainring i would imagine
    2003 Kona A
    2005 Kona A
    2016 Salsa Deadwood
  56. #2456
    Apr 2013
    Quote Originally Posted by buell View Post
    Or both
  57. #2457
    I don't think they make a 9 speed cassette bigger than 36t
  58. #2458
    Jun 2015
    [QUOTE=fixmefixmyhead;13192827]What is the best way to get a bigger climbing gear on my 2016 vaya deore? When loaded with my bikepacking gear it was really heavy to pedal up steep climbs.
    On my green 2015 Vaya 3, I have a 105 triple 50-28 up front and an 11-34 10 speed cassette in the rear. I installed a pre shadow XT rear long cage derailleur, Wheels Manufacturing hanger and 105 shifters with an XT front derailleur. I can climb anything. I am running Clement LAS on DT460 rims with XT hubs.
    I have several other bikes, but this is the only one I ride now. It can tour, climb loaded with ease, ride in a pack on the road, handle single track and gravel grind.
    This is the most fun I've had on a bike in years.
    Seems like lots of riders don't like a triple for some reason. After messing around with several others drive trains, I find this one gives me the most SPM (smiles per mile).
  59. #2459
    [QUOTE=Sparky831;13193674]
    I've looked into this and heard good things about 105s. Although if I was to swap my whole group I would rather go 2x11. I see sunrace makes a 9sp 11-40 cassette, I was gonna see if I could run that
  60. #2460
    Jun 2015
    [QUOTE=fixmefixmyhead;13193694][QUOTE=Sparky831;13193674]
    I played around with other options, as well. It's all personal preference. I actually never really leave the 50 front ring unless I am loaded or I hit steeeeep single track. Then the 39 mid gear and the 28 can really be a life saver as my rear tire doesn't spin out.
    The parts I bought were less expensive because they were an older generation. Luckily I can still find new items in the gearing I like to experiment with.
    Have fun and here's to happy trails!
  61. #2461
    Jun 2017
    I have been following this thread for a few years now and thought it was about time that I contributed.
    I have recently retired my 2012 vaya from commuting and built it up as a dedicated touring bike. Here are some snaps that I took this evening:
    Spec:
    Hubs: Shimano Deore rear, LX Dynamo front (May be upgraded to a SON28)
    Rims: Mavic A719
    Brakes: Avid BB7 Road
    Rear Mech: Shimano 9-speed XT Long Cage
    Front Derailleur: Shimano 9-speed XT
    Chainset: Shimano Deore 44.32.22t
    Cassette: Shimano 11-34t
    Shifters: Shimano Sora STI
    Bottom Bracket: Hope
    Stem: Thomson Elite
    Seatpost: Thomson Elite
    Saddle: Brooks B17 Limited Edition
    Bartape: Brooks Microfiber
    Rear Rack: Tubus Cosmo
    Front Rack: Soma Porteur Deluxe
    Headset: Chris King
    Tyres: Schwalbe Marathon Plus 38c
    Pedals: Hope F20
    Accesories:
    Mudguards: SKS Chromoplastic 50mm with Brooks mudflap
    Front Light: Schmidt Edelux ii
    Rear Light: Schmidt Rear Light
    USB Power: Igaro D1
    Horn: Airzound
    Bell: System EX A-Headset Spacer
    Pump: Zefal HPX
  62. #2462
    Dec 2015
    Great looking bike! Should serve you well
  63. #2463
    Has anyone here fit a 700cx45 wtb riddler on a vaya? My bike is a 2016
  64. #2464
    Aug 2015
    I have 45 riddlers on my vaya right now. It is a 2017. No clearance problems, but I'm not using fenders.
  65. #2465
    Aug 2016
    I've had my Vaya for a couple of weeks now, and am loving it, though after a couple 50 mile rides it's obvious I'm still figuring some stuff out.
    My 56 cm 2012 frame came with a dura-ace double up front and 9 speeds in the back. I'm not sure if I want to upgraded when I replace the chain and cassette or not.
    I'm still playing with the brooks that came with it, and some rides I like it and others not so much. I just tensioned it a bit so I'll have to see how I like that, but the fizik on it right now is working really well, especially considering how much I despise that saddle for the couple of days I had it on my stache.
    I need new tires, and want to go wider than the 36 slicks it has right now. I'm considering something with tightly packed knobs, maybe something from Clement. I'll go skinnier in winter so I can manage some fenders. A 10 mile commute isn't fun when it's downpouring and 40 degrees in the middle of the night. Also looking at the maxxis ramblers. Not sure how hard it would be to go tubeless with my current rims, but I want to try.
    I have mixed feelings about the bar end shifters, mostly because I can't brake and downshift at the same time. They might go, but I have no idea what I want for brifters, and I just rewrapped my bars.
    I think the thing that baffles me the most is the difference in ride quality a little bit of load makes. Be it hauling my daughter in her weehoo, or through the trunk on, just a little bit more weight seems to bring the bike to life. I honestly don't care for the ride quality unloaded, but love it with some load.
    https://goo.gl/photos/BU9p1ULarARV9QNS9
    https://goo.gl/photos/G1q12UFPmqosmwku7
  66. #2466
    Got my custom frame bag from rogue panda. Such a perfect fit
  67. #2467
    Dec 2015
    Quote Originally Posted by steelcityadv View Post
    Done!
  68. #2468
    Jun 2014
    Done!
    I am considering a new Vaya as a touring/commuter but my LBS only has model with Claris groupset- perhaps the same as the one in the photo here. What's everyone;s opinion of the Vaya/Claris combination?
    FYI the GX 105 version seems to be completely gone - it was my first choice...
  69. #2469
    Dec 2015
    It works fine but I'm going to change it to sram for a group set more suitable for climbing
  70. #2470
    Jun 2014
    Well, I pulled the trigger on the Vaya and since it's new to me, thought I'd do a quick review after a 20 mile shakedown ride today.
    - The bike ride is solid and planted on any surface pavement, grass, gravel or limestone hard pack.
    - Surprisingly agile for it's weight and has a lively feel (unloaded)
    - It's more sure than fast but if you gear well, it can fly once you have momentum
    - The orange sparkle in the root beer brown paint really doesn't show up in photos
    - Brakes are okay but wish they were better. It's a lot of bike to stop.
    - The Claris groupset seems capable but it can be chunky occasionally particularly when climbing. I think this is a learning curve
    more than a mechanical shortfall. Still would like to upgrade to 105 but it's not something that seems urgent.
    - That said, for such a heavy bike it climbs well and descends like a bat out of h**.
    Planned upgrades (going for a vintage look)
    - Brooks B17 saddle (never had a Brooks but should work well and look good - on order)
    - Top Peak rear rack (Giant wreck survivor)
    - Copper water bottle cage...assuming I can find one
    - Fenders since I bought the bike to be a commuter as well as a trail ace. Would love copper or bamboo but can't find
    anything fitting that description that accommodates the WTB 700x40 Nanos. I'm not sure the Vaya has mounts?
    - Tires - no complaints with the Nanos but thinking I'd like an option that had less rolling resistance and preferably a
    gum-colored sidewall
    Of course, this post would be worthless without pictures - though I'll try to get better ones soon.
  71. #2471
    mwv
    mwv is offline
    I've just now picked up a used Vaya frame....a 2014 model.
    I noticed looking at the archived bikes section of the Salsa website that after the 2015 model year the tire clearance increases. Does anyone know if this was a change to both the rear triangle and the fork? Basically what actually changed?
  72. #2472
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by mwv View Post
    The fork definitely changed. I think there were some very subtle frame changes, also but not sure they widened the stays for tire clearance. I think they changed how they calculated clearance, for one. I have a 2014 model and run 35mm Clements with fenders at the moment. I have run up to 38mm Specialized hybrid tires with fenders. I could run 40s without fenders, I am pretty sure.
  73. #2473
    mwv
    mwv is offline
    Quote Originally Posted by Harold View Post
    Yeah....after 2015 the claims for fender clearance jump to 42 and then 45.
    2014: 38 with fender which seems correct with mine....40s might work on mine but not easily
    2015: same
    2016 : 42 with fenders for steel, 45 for ti
    2017: 45 with fenders but they don't show a difference between the GX and Deore or Claris despite one being carbon and the others steel
    I have a hard time believing they changed the steel fork twice since 2015. If so I want to get that fork if possible. I'm hoping to hear back something useful from Salsa.
  74. #2474
    mwv
    mwv is offline
    Salsa said everything changed. Oh well my search continues...
  75. #2475
    Human Test Subject
    I ran 42s with fenders on my blue 2014. Without fenders and with the chainstay bridge bolt removed I ran WTB nine line 29x2s for a bit, but clearance was tight.
  76. #2476
    Dec 2015
    Anyone running 1x?
  77. #2477
    since 4/10/2009
    Anyone running 1x?
    I used to, but went 2x because I wanted the range.
  78. #2478
    Dec 2015
    Yeah I'm kicking that idea around too. Maybe a 38 24 in the front/11 36 in the back
  79. #2479
    since 4/10/2009
    I have an 11-36 in back with a std compact double road crank. Will prob drop ring sizes down a bit, though. I never use the 50x11, even on fast roads.
  80. #2480
    Nov 2016
    Anyone running 1x?
    Yes, I have SRAM 1x on my upgraded 2017 Claris, and I love it.
    I have a Wolf Tooth Drop Stop 38T chainring (on a Quarq DZero) and a Shimano 11-42 cassette. (And I swapped the brakes for BB7's and I'm running Gravelking SK 43mm tires). The gear range is perfect for the riding I do around San Francisco, street and gravel fire roads with some single track.
    I love not needing to think about a front derailleur; it's more instinctual for me to just shift up or down with one hand.
    Feeling stoked to be riding this bike in Grinduro on Saturday!
  81. #2481
    Dec 2015
    Sweet! Are you using sram components?
  82. #2482
    Nov 2016
    The levers are SRAM Force 1 left brake and Force 22 right shift/brake, and the derailleur is SRAM Force 1 long cage.
  83. #2483
    I'm running a cross crank double 46/36 and 11/36 cassette. I find it to be perfect for my daily commute in Seattle. I do spin out coming down steep hills in the 46/11 gear, but I probably shouldn't be going that fast down city streets.
    I had the vays up to 51mph this summer on a very steep hill. I'm also running Compass Barlow pass tires at 38mm. However, they measure out to 41mm @ 50 psi on my hed belgium plus rims.
  84. #2484
    since 4/10/2009
    Quote Originally Posted by CaptainSlow View Post
    I am thinking even more about dropping my big ring size and making a few other minor component tweaks to my vaya. I have moved and my vaya is going to wind up getting more gravel duty and FAR fewer commutes and city rides. There also looks to be a a nice, quiet country road route near my house.
  85. #2485
    Reputation: Boo Bear's Avatar
    2016 Vaya X9 or wait for 2018 Vaya Apex?
    Hey all- I have an opportunity to get a leftover 2016 Vaya X9 for $1400. In looking at the 2016 x9 vs the 2018 Apex, the main differences I see are:
    Steel: 2016 is 4130, 2018 is Kung Fu
    Fork: 2016 is steel, 2018 is carbon
    Bottle mounts: 2016 has 2, 2018 has 3
    Drivetrain: X9 vs GX 2.1
    I like the extra bottle mount on the 2018. I imagine that as far as the steel goes, I probably wouldn't notice too much of a difference between the two. (In fact, it looks like the 2016 is lighter than the 2018 Tiagra with the steel fork...) Drivetrain is probably about a wash. I'd prefer an orange bike over a blue as I already have a very similar colored bike in the stable. (This is perhaps the epitome of a first-world problem. I know.)
    Geo looks to be almost exactly the same, slight more standover on the 2018, and wheelbase difference of 1/2" or so. And tire clearance looks exactly the same as well.
    Anything I'm missing here? Thoughts on one over the other?
    Crashing mountain bikes since 1990.
  86. #2486
    Disregard my previous post...
  87. #2487
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Quote Originally Posted by Boo Bear View Post
    Beautiful bike, I love blue bikes.
    A garage full of steel frames means happiness.
  88. #2488
    Sep 2015
    the older one won't be as stiff i'd guess. for my purposes i'd prefer that i guess, but the stiffness does make aligning disc calipers and avoiding rub easier.
  89. #2489
    Sep 2015
    that going down lakemont?
  90. #2490
    Quote Originally Posted by CS2 View Post
    Thank you. I guess I do too...I now have 3 blue steel bikes. Ha. This Salsa is quite stunning in person.
    Great timing picking this up on the cusp of fat bike season. Mwa-wha. I'm having fun with swapping out parts though. Brooks Cambium 15, FSA carbon seat post...will post up a pic once everything is installed.
  91. #2491
    It was a long steep hill on Whidbey Island this summer I always wonder how fast I could have gone with my race bike
Members who have read this thread: 150
