    indigosky
    Guest
    Torque specs for Pro Moto Carbon Riser bar
    Anybody know the torque specs for stems for the Pro Moto Carbon Riser bar? Should I just follow the Thomson torque specs since that is the stem I'm running?
    I keep my brake levers loose enought to spin in a crash, so I'm not worried about over-torquing those...
    Thanks.
    just ride
    Reputation: chequamagon's Avatar
    Torque specs are typically derived from the stem that is being used, as torque on the bolt head is a function of bolt threads, type, number, face plate material, etc. In addition, keep in mind that those are maximum values when we talk about pinch-type applications. If you can get away with a little less, that is ok. I would suggest using something like Tacx gripping paste to be able to use a little less torque, and still maintain a positive grip.
    Ride and Smile!
    Tim, Salsa Cycles
    Steel is Real: www.advocatecycles.com
    Tires for real rides: www.terrenetires.com
    indigosky
    Guest
    Thanks Tim, that paste exactly what I was looking for (and didn't know existed).
    Reputation: Salsa Cycles's Avatar
    Dec 2004
    Quote Originally Posted by indigosky
    You are welcome. LU2021 is the QBP number, so most of your local bike shops can order it for you. Retail is around $17 for enough to last you for years.
    Ride and Smile!
    Tim, Salsa Cycles
    Adventure by Bike
    Check out our blog!
