Results 1 to 8 of 8
    Reputation: csmo's Avatar
    Spearfish tire clearance
    Hi all,
    I have read through the forums, searched, and discussed this a bit on the Spearfish Facebook page but still cannot find an answer.
    I wonder what size tires folks have been able to fit in the rear? I'd like to try a Hans Dampf 2.35 or a Trail King 2.2. In the rear, the lateral clearance looks good but the vertical clearance is questionable, i.e. there's not a ton of room left in there with stock 2.2 X King. Clearance on the front looks fine.
    So, please let me know what tires you've been able to fit. Thanks
    Slant six 2.2 and fast rack 2.2 have fit with room to spare. Nevegal 2.2 hit the fd cage.
    rth009
    May 2010
    Nevegal 2.2 is huge. As is the new Honey Badger 2.2. I can't run either in my 2011 El Mariachi Ti, which sucks because they are both readily available, decent tires that can be had for cheap on ebay. I must note that Im still running 3x9 and the FD cage sticks out beyond the right chainstay a bit, which limits me a little more than if my drivetrain were not so 2009.
    Does anyone else think Kenda tires have bigger casings than their sizes indicate? A 2.2 Honey Badger was quite a bit wider than a 2.4 Ardent.
    Thanks for the replies so far. On the FB page a member posted a pic of a Hans Dampf in the rear with plenty of vertical clearance--lateral clearance does not seem to be an issue.
    offroader
    Dec 2008
    I've got Racing Ralph 2.4 and a good 1/2 or mroe clearance on each side. It has plenty of clearance.
    Thanks. Is this on the rear and the front?
    offroader
    Dec 2008
    rear of course
    Just making sure--thanks.
  1. salsa spearfish tire
    By pa rider in forum 29er Components
    Last Post: 05-24-2012, 10:48 AM
  2. Spearfish Tire Spacing
    By Rucker61 in forum Salsa
    Last Post: 01-21-2012, 01:45 PM
  3. Tire Advice needed for Salsa Spearfish
    By Moe's Tavern in forum 29er Bikes
    Last Post: 01-05-2012, 08:31 PM
  4. Big Top Tire Clearance/Tire Choice
    By TheFCuddy in forum Yeti
    Last Post: 10-07-2011, 06:51 AM
  5. Replies: 2
    Last Post: 07-12-2011, 07:39 AM
