Results 1 to 3 of 3
    Dec 2011
    Spearfish shock pressure
    My wife has a 2013 Spearfish 1 with a Fox CTD and was just wondering what people were running for pressure. I am borrowing her bike for a race and am trying to get a better idea of what pressure I should be running. I weight 170, maybe 180 with gear. Currently running 120, kinda on the squishy side. Thanks.
    I run ~75% of my body weight. For xc racing I've run it near ~85%
    May 2013
    I have a 2012 Spearfish 2 with the Monarch shock (different shock but similar). I weigh 160 with gear and had it set around 120 psi for many months. I just recently went up to 140 psi because I was wanting a bit firmer ride.
    Use the little rubber ring on the shock to note how much of the shock you are using. This lets you know if you are using the full stroke or if you need to adjust.
  1. Spearfish - Rockshox Ario RL Shock
    By Tea@Dimbola in forum Salsa
    Last Post: 06-07-2013, 12:17 PM
  2. Replacing the rear shock on a spearfish
    By pulser in forum Salsa
    Last Post: 04-07-2013, 06:56 AM
  3. Spearfish w/ RP23 Shock
    By 918XC in forum 29er Bikes
    Last Post: 12-02-2012, 08:22 AM
  4. Different shock on Spearfish
    By jaks in forum Salsa
    Last Post: 05-15-2012, 08:02 AM
  5. Spearfish shock question (rebound)
    By car_nut in forum Salsa
    Last Post: 02-11-2012, 06:41 PM
