Results 1 to 6 of 6
    Reputation: weeksy950's Avatar
    New question here. Spearfish configuration question. BB/HT2 stuff
    Morning lads.
    I'm running a Spearfish in the UK. Was built up by my LBS in part but mostly by me.
    Last time in there i asked him to fit the PF / HT2 converters.
    SRAM Press Fit 30 to BSA Adaptor Kit | Buy Online |
    I then ran a standard XTR HT2 bottom bracket.
    When swapping due to excessive play in the BB, i noticed that he'd set the spacers up with 1 spacer on the non-drive side and no spacer on the drive side. I assume this was for chain line reasons rather than anything else ?
    So i was just wondering how you're running your BB configuration on spearfishes ?
    I tried an adapted gxp for a while and finally gave up and bought the correct standard. I never could get the adapter cups to ride true in the bottom bracket. I gotta say, it works much better with the press fit 30 too. I found a Sram x-9 crankset for nearly free and that is what I am running.
    Reputation: pulser's Avatar
    Dec 2004
    I am running a standard Sram press fit BB with the Wheels Mfg. adapters and a RaceFace crank. Its not really a good fix and I plan on getting the RaceFace adapter BB soon.
    Jan 2011
    Parlee PF30-Shimano/24mm BB is working flawlessly in my SF 1 with Rotor Crankset.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Praxis Works | Conversion Kit
    I installed this in my wife's Spearfish. Works perfect. No movement, no creaking.
    I like turtles
    My local shop told me that Rotor (Rotor UK > Rotor Bike Components > Welcome to Rotor UK) do a good pressfit 30 bb that accepts the 24mm Shimano cranksets. I've not tried it yet but they reckon they've fitted a couple and they're good.
  1. salsa spearfish sizing question
    By chesterdawg in forum 29er Bikes
    Last Post: 05-23-2015, 09:47 AM
  2. spearfish sizing question
    By chesterdawg in forum Salsa
    Last Post: 09-07-2012, 12:55 PM
  3. Superfly build kit onto Spearfish frame, Compatibility question
    By CYCLEJCE in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-28-2012, 06:47 AM
  4. spearfish cable routing question
    By phazeshifta in forum Salsa
    Last Post: 03-28-2012, 12:42 AM
  5. Spearfish shock question (rebound)
    By car_nut in forum Salsa
    Last Post: 02-11-2012, 06:41 PM
