Results 1 to 15 of 15
    Oct 2012
    Spearfish bent skewer from dérailleur hanger bolts?!
    Local shop replaced my broken hanger a couple weeks ago, and I just noticed the two hanger bolts are sticking out a little too far and bent the skewer...has anyone run into this problem? Could the bolts have pushed through some how or did the shop bungle this?
    Also, where can I buy some bolts? I have come up empty handed...
    On your left.
    Which frame - 135mm QR or 142mm threaded?
    M
    Oct 2012
    135 QR - it's a 2012 Spearfish 2
    On your left.
    I dont know about the 135mm hanger, but the screws for the 142mm hanger are tiny, easy to strip the hex head and don't have loctite - absolutely unacceptable design. Although it's a design flaw - In your case I'd still say the shop is responsible for your bent skewer because they did not ensure the screws were installed safely.
    M
    Positively negative
    I can't speak specifically about this situation but in a most cases replacement hangers will come with new bolts and, since the hanger is usually made and sold by a third party, they aren't always the right size. They can be too long, short, have the wrong head, or in the case of counter sunk heads they may not sit flush when installed. It is the job of the installer to determine the correct bolts, be they new, old, or sourced otherwise. I don't think you would be in the wrong to swing by the shop, explain the problem and see what they will do for you.
    A local fastener supplier should be able to help you sourcing new bolts. It probably best to stop in with the old bolts and tell them what your looking for. If that doesn't pan out try McMaster-Carr.
    Motivated - Loc-tite 222 should solve your problems.
    Reputation: CYCLEJCE's Avatar
    I haven't found a hanger for my Spearfish from anyone other than Salsa or other QBP owned company. In other words they are all the same. The last two I bought came with blue loctite on the tiny mount screws.
    Positively negative
    Quote Originally Posted by CYCLEJCE View Post
    Wheels Manufacturing Derailleur Hanger 142
    I can tell you from experience that the bolts that come with wheels hangers are rarely perfect.
    Wheels Mfg is a QBP owned company. I can't imagine them making multiple hangers to fit the same bike. Maybe...
    Positively negative
    Since when? And if so why would they see to their biggest competitors?
    Not sure when... Who wouldn't sell to the competition?
    Positively negative
    According to their business model QBP won't. I mean you don't see surly, salsa, dimension, etc being sold by, well, pretty much every other major US distributor. Not to mention Wheels seems to be running completely separate from Q, unlike every other Q brand.
    Not saying your wrong, just that I don't see any evidence to the contrary.
    Ride good on the internet
    No it's not.
    Are you perhaps confusing them with Problem Solvers?
    Maybe.. On a side note, I installed a new hanger last night and had the same issue. The mounting bolts were long enough to poke out of the other side of the hanger about .5mm. The originals were shorter and looked to have been filed down.
    Reputation: pulser's Avatar
    Dec 2004
    I got some Wheels Mfg. hangers and the bolts are definitely long. I just tightened them up and cut them flush with a dremel.
    May 2013
    Quote Originally Posted by Rumblefish29er View Post
    I had the same problem on my 2012 Spearfish 2, but it didn't bend the skewer. My LBS ended up filing-down the hanger bolts to fit and not get in the way of the skewer. Seems strange, but it worked.
  1. nickel derailleur hanger and bolts
    By noosa2 in forum Santa Cruz
    Last Post: 04-07-2013, 08:29 PM
  2. I bent my Pug's derailleur hanger...
    By dancing mad in forum Fat bikes
    Last Post: 07-10-2012, 09:55 PM
  3. Bend-ING (not bent) derailleur hanger
    By PedalDangit in forum Tooltime
    Last Post: 07-09-2012, 04:02 PM
  4. Is my rear derailleur bent or just the hanger?
    By Paladin54 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2011, 10:24 AM
  5. Spearfish derailleur hanger.
    By Macbeth in forum Salsa
    Last Post: 10-06-2011, 07:38 AM
