Results 1 to 7 of 7
Thread: Salsa Vaya Fork
    Salsa Vaya Fork
    Any one replaced their Vaya fork with something lighter? I am looking to keep the handling about the same and tire clearance around 40-45 mm. Thoughts?
    Ballstein Models
    Reputation: hogprint's Avatar
    I've got the Spot carbon fork on my Vaya Ti. Deets in this thread:
    Lightweight Vayas???
    ________________
    The source for mountain biking information in the Madison Wisconsin Area:
    Capital Off Road Pathfinders
    Reputation: Jam esp's Avatar
    I'd like to know more about the stock 2013 Vaya fork. What I've heard is that Salsa actually beefed up the new fork after a few older forks failed in the field. Anybody know more about this?
    "Get a bicycle. You will not regret it, if you live."
    -- Mark Twain
    May 2010
    I've run both the Winwood Muddy Cross fork and now the Whisky No. 7 Fork on my Vaya, both with good results. The Whisky is a tad bit lighter and perhaps a hair bit better at vibration dampening.
    Have you had increase issues with shoe rub? If I understand everything with changing the rake
    May 2010
    In a word, No.
    Is it possible to have overlap? Yup. I ride a 55.
    Is it frequent? Nope.
    Would 5mm change things? No. In the circumstances where I can overlap, 5mm wouldn't make a difference.
    Ballstein Models
    I do have overlap issues on my 57cm. That is with a pretty chunky fender though. Remove the fender and grab the 5mm from the stock fork and I'd eliminate the overlap. Just that close here.
    ________________
