The Salsa Fargo Thread
Printable View
  • 05-02-2017
    Erik_A
  • 05-02-2017
    Guitar Ted
    Originally Posted by Rorshanks View Post
    Does anyone have an experience with the Salsa Cowchipper bars over the Woodchipper?
    I intended the Fargo to be my all-around second bike to use bikepacking, commuting, trailering around the kids, and for mountain biking when my local trails that are getting a little boring on my full suspension.
    I'm 5'11" on a 2017 medium Fargo. When in the drops, I feel a little too much leaned over like the bars are too low, even though the handlebars are at the top of my spacer stack. My bars are currently set up so riding on the hoods is pretty comfortable, but hard to reach the levers in the drops. I could move the hoods lower, but then I'm afraid I would be limited to the "too-low" drop position all the time. I find this position tiring for long rides.
    I know the Cowchippers will solve the problem of having a useable lever position in hoods and the drops, but will they put me in an even lower position on the bike since they have a bit more drop? Or will the tighter radius of the Cowchippers improve my position?
    I may also try a higher rise stem, but for now I'm wondering if different bars might solve both problems (lever reach in hoods/drops and getting a more upright position.)
    I've ridden a lot with both those bars. Your worries are spot on with the Woodchipper and it is why I really do not like that bar.
    The Cowchipper solves all those issues. Yes, it has a bit deeper drop, but as you say, a stem swap can get you in a "drop" position that works better, if you need that. I did not.
    Personally, I feel the Cowchipper is a far superior drop bar. The Woodchipper was a bar that wasn't right out of the box and no amount of futzing with rotating it, stems, or spacer gymnastics could fix that for me. It is an inferior design and many bikes I see it on have compromised either the hoods position or drops position so much the rider doesn't use the one position that has been compromised at all.
    That said, there are many that are in love with Woodchippers. That's why Salsa has both bars. I get it. It is just my opinion that the Woodchipper is a flawed design. Hopefully you get someone to comment that hates Cowchippers and loves Woodchippers. Balanced and fair reviewing, ya know. :)
  • 05-02-2017
    newfangled
    Originally Posted by evirob View Post
    I went with 29+ wheels and the clearance could be better. 40mm ID rims with WTB Rangers.
    Just out of curiosity, that's with the 3.0 Rangers or the 2.8?
  • 05-04-2017
    kevrider
    Originally Posted by annoying crack View Post
    Gearing wise. How do I get the lowest gearing with a double chainset that works with brifters? Planning on using cable disks.
    to get the lowest gearing, you'll use a mtn bike crankset, mtn bike rear mech and mtn bike cassette. if using Shimano, you'll need a Wolftooth "Tanpan" to make the road brifters operate the mech. you can google and/or search this thread for those terms.
  • 05-04-2017
    cackalacky
    Fargo MTB
    I've been riding my Fargo on singletrack a bit lately and I love it more and more. It's just a really fun mountain bike and I'm actually enjoying using the Woodchippers.
    You guys discussing the Woodchipper vs. Cowchipper is making me want to try the CC. I adjusted the reach and level of the levers to optimize for the drops, and only use the top of the bar when climbing or going really slow. Definitely a compromise, but I'm okay with it for now.
    I installed an old Reba I had laying around that had a shorter steerer tube than the steel fork. I had to use a higher rise stem to get the drops up to around saddle level. The WTB i29 Asym rims with Maxxis Forekaster 2.3 tubeless tires are awesome. Tons of grip and feel solid.
    Attachment 1135461
  • 05-05-2017
    niles25
    Just picked up a new Fargo a couple weeks ago. Re-laced the rims with Stans Flow MK3s wrapped in Ikon 2.35's, swapped out the cassette for a Box components 11-46, and switched the front ring to a 28t. I never thought I'd own a bike like this but I love the adventures that can be had. Pic below is from the first real ride, about 45 miles of old double track with some pavement thrown in for good measure.
    Attachment 1135629
  • 05-06-2017
    Couloirman
    I've tried several shops and cant for the life of me find either a steel or Ti fargo frameset +/- fork in medium anywhere. If anyone has any leads, I am all ears, please shoot me a PM. I just broke my old (non-Fargo) frame and need a new one ASAP. None of my local Salsa dealers are saying that they are able to order me one in time. I need a new one this month if possible for some Springtime bikepack races I have planned.
  • 05-06-2017
    RPG
    You try eBay by chance? Or you could look into another drop bar style bike: velo orange piolet, crust bikes, etc... I know they aren't fargos, but better than nothing. Crust bikes people are big into bikepacking fwiw. good luck and hope you find a speedy solution.
  • 05-06-2017
    kevrider
    that is a really cool pic! it's as if your Fargo is screaming "i'm the king of the world!" :)
  • 05-11-2017
    Rorshanks
    Thanks G-Ted. It sounds like the Cowchippers might be the better choice for what I intend to do with this bike.
    I think maybe I see the benefit of the Woodchipper for singletrack riding of you literally only ever use the drops, but I've got other mountain bikes for that type of riding.
    Also, is anyone else excited about recently announced 29x2.8" tires from Terrene? I know there are other smaller plus tires that probably measure to around 2.8", but I need a tough casing for my lava rock infested trails. I want to dangle my feet in the plus tire pool, but these should work fine on my i29 rims without chain rub from my 2x10.
  • 05-11-2017
    Guitar Ted
    I am, for one. Not for a Fargo though. I have 2.8"ers but they are 27.5" tires on my "Fat Fargo", which is a great set up for certain things.
    I'll be looking in to this new Terrene tire for a Singular Buzzard I have.
  • 05-12-2017
    Smithhammer
    The 29+ Rangers are only available in 3.0". Currently....
    I'm excited. They look sweet. Though I've been running Rangers lately on both my 27.5+ and 29+ rigs and they leave little to be desired. While the "Light and Fast" version may not stand up to sustained lava rock bashing, I've actually been pretty impressed at how durable they are on northern Rockies granite/shale and the usual southern Utah smorgasbord of pokey nastiness.
  • 05-12-2017
    cackalacky
    Thanks! Just a quick pic on my roof rack. This bike is a keeper.
  • 05-17-2017
    MikeR91
    I made it 88 miles on my Fargo before breaking my first derailleur hanger. Not terribly expensive given I have to replace the whole dropout, but after removing it and inspecting it, it doesn't look like the most durable piece of hardware. My plan for the bike was to be able to take long rides with occasional single track mixed in. Anyone have any impressions of the alternator dropouts and whether they are up to the task?
    On the plus side, I think the derailleur itself survived just fine (to be confirmed once I fix the bike and ride it again), so the hanger did it's job and provided a breaking point. With the sliding mount, I was able to resize my chain for a middle gear, tension the chain, and single-speed it home without any issues. So, despite breaking, it didn't leave me stranded calling for a ride, which is always a plus.
  • 05-17-2017
    grizzler
    Bummer about the hanger. I have 3000 miles on mine without issue. Mixed dirt and road.
    Also, I just made the switch to cowchippers and am really happy. I haven't tried them on a single track yet though. I also switch the BB7s to TRP Spyre. Mucho mejor!
  • 05-17-2017
    samwe
    The hanger broke? I had the cage separate from the rest of the derailleur. The shop thought I must have damaged it so I had to a buy a new derailleur.
    This year my wife and my friend both got Fargo's and had the same thing happen. Mine was a 2015 and theirs were 2016's. One thing I discovered is that the RD was an older version.
    All of these incidents happened with 2-300 miles on them.
  • 05-17-2017
    MikeR91
    Yeah, the hanger bent so that the derailleur was back in the wheel (luckily, no signs of spoke damage) and when I tugged it to clear the wheel, it snapped. Pictures attached. (Please excuse the mud - they are building bridges over some drainage, but they aren't done yet, hard to ride through without picking some up.) Derailleur seems Ok, but could be bent a bit. I'll know more in a couple days when I get my hands on a new dropout.
    Grizzler - Interesting about the brakes. My initial impression was that the brakes were a bit weak, but I have BB7s on my fatbike and they have always worked well. I haven't really investigated what the differences are (aside from the obvious brake levers) between the setups on the two bikes.
  • 05-18-2017
    wildernessness
    I'm looking for suggestions (pictures?) of front racks for the Fargo. I have a '17 with steel fork running 29x2.4s now, soon 27.5x3s. Prefer non low riders. I live pretty remotely (interior Alaska) making it hard to get my hands on actual products and shipping is expensive. I think the Velo Orange Randonneur and Surly 8/24 Pack would work. Maybe?
    Let me know what has worked well!
  • 05-18-2017
    wildernessness
    Grizzler, what rack is that? Did you have to drill into the fork to make it work?
  • 05-19-2017
    grizzler
    I found the MTB BB7 to be plenty powerful, but for some reason I just couldn't get the road version to be great.
  • 05-19-2017
    grizzler
    It's a (incorrectly mounted) Surly 8-pack. I don't recommend it unless you want to custom fabricate a mounting bracket or add some crown braze-ons. I did not drill the fork, I just used the mid-blade mounts and the top cage mounts. I am waiting for a friend to make a me a block.
  • 05-23-2017
    samwe
    Hey! Fellow Alaskan with a Fargo here,
    I have the Surly Front Rack. Mounted as high as it will go, it clears 29x2.35 Super Motos, but not by much.
    I got it thinking I could strap a dry bag on top, or panniers on the sides depending on where I am going and how much I am taking.
  • 05-26-2017
    Rorshanks
    I have a Racktime Toppit on my '17 fargo which work pretty well. I think when I measured it it had 4" of space between the rack arms. I don't think there would be any problems with 3" tires. In fact, I'm sure 29x3" tires would be fine. It has a decent sized deck and can support panniers.
    I do lament the fact that the rack arms interfere with the ability to mount things to the bottle mounts. I've seen pictures of older Fargos where the 3-pack mounts are to the rear of the fork, allowing people to use a rack and anything cages. That would be nice, but I ordered some 5L panniers from Alpkit to experiment with.
