The Salsa Fargo Thread
Printable View
  • 10-21-2016
    grizzler
    taowave, the fargo does have shorter reach because of the drop bars.
    I'm 6'2" with a wingspan of 6'4" and I ride a large fargo with 100mm stem and large woodchippers. I also ride a large Pony Rustler with a 50mm stem and 800mm bars (reach is 11mm shorter than a timberjack). Both fit perfectly for my taste and match the style of riding I do with each bike.
    Best input I can give is to see if there is one in town you can check the fit on.
  • 10-21-2016
    taowave
    Hi Grizzler,
    That makes total sense. The reach has to be shorter to compensate for the drop bar effect. and to maintain a mountain bike "fit". makes sense why the reach is shorter with dropbars..
    I just measured my reach for he first time.At 6'3.5",I have a 6'5" wingspan.I did manage to find a L Deadwood in town,and that felt pretty good without any adjustments from the store.Probably going with the XL Fargo 29 er.Any thoughts on wood chipper vs cowtipper?
  • 10-21-2016
    grizzler
    I love my woodchippers, which seems to be a less popular opinion. I haven't tried the cowchippers (or tippers heh) but the less severe flare is appealing for commuting/tame trails. I found myself on the end of the flare for tough climbs. If I were building one today I would be the cowchippers simply out curiousity... you're going to have an awesome bike either way!
  • 10-21-2016
    GreenMason
    The woodchippers took some getting used to but once I did the bike only got better - If that is possible.
  • 10-21-2016
    taowave
    You should think about getting a gig at Salsa:)
  • 10-26-2016
    misternicholas
    I pre-ordered a Fargo about a month ago. Has anyone heard any update on when they will start shipping? Last I heard was mid November.
    Also, do the alternators to swap the wheels come with the complete bike or are they sold separately? I ordered a 27.5" but plan to build some a set of 29" wheels for bikepacking.
  • 10-26-2016
    Erik_A
    My original comment. You can look at the stack and reach for various drop-bar "monstercross" type bikes. My XL 2015 Fargo was just too short in the reach for my comfort level. I felt way too upright. So I sold it and built a 60cm SOMA Wolverine which has a longer reach: Wolverine | SOMA Fabrications - Then for 2017 Salsa extended the reach on the XL Fargo: FARGO GX 2X10 | Bikes | Salsa Cycles - if you compare the 2 two geometry tables both bikes now have a similar reach, but the Fargo's stack is 45mm taller than the Soma.
    The Fargo is best for folks with long legs and short torso and arms (in my opinion). I prefer a bit lower stack, but y main bike is a cyclocross - so that maybe why.
    Originally Posted by taowave View Post
    Hi,new to Mountain Bikes,and am looking at the Fargo,Jamis Dragonslayer,marin PM1 and the Krampus with the fargo as my #1 choice.As I am 6'4",I was concerned a bit with your comment regarding the Fargo reach possibly being too short.
    What I don't get is since the Fargo has drop bars that appear to extend way beyond where a mountain bike handlebar does,doesnt that effectively extend the reach?
    Am I missing something?
    Any input greatly appreciated
  • 10-26-2016
    Erik_A
    My original comment. You can compare the stack and reach for various drop-bar "monstercross" type bikes.
    My XL 2015 Fargo was just too short in the reach for my comfort level. I felt way too upright. I always felt like I needed to move the seat back (even with a set-back seatpost). So I sold it and built a 60cm SOMA Wolverine which has a longer reach: Wolverine | SOMA Fabrications
  • 10-26-2016
    Erik_A
  • 10-28-2016
    misternicholas
    2017 Fargo just showed up in the Fargo FB group:
    https://www.facebook.com/groups/sals...target&fref=nf
    Hoping this means mine will be arriving soon! :)
  • 11-02-2016
    bigoz5
    Originally Posted by Erik_A View Post
    Unless you want carbon; I would look at the new Salsa Timberjack 27.5+ in Medium (the defacto replacement for the steel El Mariachi). TIMBERJACK 27.5+ X1 | Bikes | Salsa Cycles Great deal for $1400; even if you decide to upgrade to drop-bars. In my opinion the Fargo's reach is way too short for someone with long arms.
    Med. Timberjack (27.5 +) = Reach: 430mm / Standover: 29.5"
    Med. Fargo (27.5 +) = Reach: 368mm / Standover: 30.6"
    I've been thinking through this idea since you posted this a month back.
    I had always just assumed putting drop bars on something designed for flat bars would just mess things up too much. However, with an ape index of ~2in and a long torso (my wife and I have the same inseam, though she is 4 inches shorter) this isn't exactly the case for me.
    I've been playing around with Stack and reach calculator (a GREAT tool for figuring out bike fit). It shows that throwing drop bars, a normal stem, and a few spacers on a medium El Mar would give me pretty much the same fit as a medium Fargo with the long stem I would need to make things comfortable. Then I wouldn't have to jump up to the large Fargo (standover issues) and would have plenty of room to add a longer stem in the future (I couldn't see myself ever needing to go shorter). This particularly works given my use case...about 90% commuting with about 10% dirt/gravel/singletrack.
    As a plus, I feel like there are 10x as many used El Mars up for grabs as there are used Fargos, and they go for much cheaper. Only downside with the El Mar/Timberjack route...lack of braze-ons. Though with a firestarter fork, a tap and die for the rear alternators, and a few other tricks, I should be able to squeeze on some fenders and racks.
  • 11-14-2016
    ciquta
    a El Mar it's a total different bike
    The stack is way too low to be comfortable with drop bars (unless you want to stay in the hoods for most time).
    A shorter stem means less cornering precision, and with a shorter reach and low stack you dont really have a rest position.
    And last but not least the BB drop: 10mm difference is HUGE.
    There's a reason why Fargo is 10 times less likely to be found on used market
  • 11-14-2016
    bigoz5
    Yeah, since originally posting that bit about the El Mar, I've kind of come full circle. A drop bar El Mar would just have too many trade-offs I'm not willing to make. So, back to looking for a decent Fargo.
    Fortunately, I recently picked one up for my wife...a crazy-good deal came up locally on a Fargo in her size. She loves it...rides it every day. So once our finances recover a bit, it SHOULD be easier to get her consent on picking one up in my size, right?
  • 11-23-2016
    Crowley
    Attachment 1106928
    Scary monster after my Fargo.
  • 11-25-2016
    cackalacky
    3 Attachment(s)
    Suspension
    I wanted to use the Fargo as my main MTB this winter, so I threw my old Reba Race on it. I also finally converted the WTB Asym wheels to tubeless with a new set of Maxxis Forekasters. I moved my levers down so I could reach them in the drops, but need to adjust them a bit more and replace the bar tape.
  • 11-25-2016
    Forster
    Have you run them in snow or ice yet? How grippy is that rubber?
  • 11-25-2016
    cackalacky
    I've only ridden them around my yard, so really can't say. Won't have snow for a couple of months here. The knobs are big and soft, so they should be pretty grippy. Have you seen the Forekaster thread? http://forums.mtbr.com/wheels-tires/...r-1008764.html
    I will say they mounted up super easy with just a JoeBlow "fat" floor pump.
  • 11-26-2016
    Crowley
    Post ride in Bishop California
  • 11-26-2016
    renegade44
    Originally Posted by renegade44 View Post
    Wouldn't mind trying these on my Gen 1 Fargo. With the low tread, I'm guessing these will be close to a 2.4 tire that the Gen 1 Fargo was rated for.
    Tires | Parts and Accessories | Surly Bikes
    While the Surly ET 29er tires are not available yet, I did pick up a lightly used pair of Schwalbe Big One 29x2.3 tires. These tires are so much fun! Super quick on pavement, and plenty of cushion for light singletrack.
    Fast and and fat by jon_baler, on Flickr
  • 11-27-2016
    farleybob
    Salsa #5 Frame bag for sale off my XL 2014 Fargo. Like new if someone needs one. $125 shipped in conus.
  • 11-28-2016
    patrickevers
    3 Attachment(s)
    Two pics from september 2016. The Torino-Nice rally.
    Introducing the Torino-Nice Rally
    Great trip, 680KM, 19000 meters elevation gain. On my trusted fargo. Left my bikepacking setup at home and used panniers, which I regretted on day 1.
    Attachment 1107572
    Attachment 1107573
    Attachment 1107575
  • 11-28-2016
    patrickevers
    I know the fargo (model 2015) is designed for max 2.3 inch tires. I tried the panaracers FatBNimble 29+ (about 2.8 inch) a few months ago, but they just didn't have enough clearance in the rear.
    For the winter I want to have some more width. Will the new Schwalbe Nobby Nic Evolution SnakeSkin 29+ (29x2.60) fit my 2015 fargo?
  • 12-01-2016
    ipaulog
    New Fargo Owner
    First post having read most of the thread and various other places like Guitar Ted's blog.
    I'm putting together a Fargo having picked up a 2 year old (I think) frame that had been stored and never built up.
    I'm sure there are other things that I will probably ask but for now I need to buy a front derailleur. I'm using Shimano XT as I have parts already stored away. The Salsa page for my frame states high direct mount front derailleur (problem solvers clamp included). Is there a reason an XT clamp type won't do the job?
    Thanks for any help,
    Paul.
  • 12-02-2016
    Guitar Ted
    Welcome! (And thanks for checking out the blog)
    No reason at all that a band clamp front derailleur wouldn't work, but you may want to be aware of the location of the lower seat tube mounted water bottle boss. It may interfere with your clamp depending upon your front chain ring size for the big ring. If things align just right, you may see interference with a high clamp style and you may have to seek out a low clamp style to make things work.
  • 12-02-2016
    ipaulog
    Just the kind of help I was after - off to do some measuring. I'll be running 40-28 at the front.
    Much appreciated,
    Paul
  • 12-07-2016
    PeterJM
    I have a Salsa Fargo 2 (2015). For an upcoming bikepacking trip, I am thinking of running Maxxis Ikon 2.35 tires in the back on a WTB Asym i29 rim (29mm internal diameter). Would that work (in terms of clearance)? Or would a 25mm internal diameter rim be a better/safer option? Thanks for your help! :)
  • 12-07-2016
    big_papa_nuts
    I29 is too wide for a 2.35". You will gain nothing but sidewall exposure and sketchy cornering, I25 will be much better.
  • 12-07-2016
    ironacct
    FWIW, with my Fargo I ran Maxxis Ardent 2.4 tubeless on Velocity Blunt 35 rims (inner width 30mm) on a trip through the high Rockies last summer. Lots of gravel, rocks, more rocks, etc., especially above treeline. Traction and comfort was excellent at around 22psi. Sidewall exposure for me was not an issue...rim width is only half the tire width. I have also run 25mm internal width rims with these tires and that should work fine, but if it was me I'd go with the 29mm.
  • 12-08-2016
    ciquta
    I see on the specs the Fargo has a straight headtube but the firestarter carbon is tapered... does it use a headset adapter?!?
    I sold my Fargo and I'm in the process of building a custom Ti frame stealing a lot of hints from this bike, so I wonder if that is a proper setup or I'd better get a tapered headtube.
  • 12-08-2016
    ironacct
    headtube.
    It's a 44mm straight headtube, which is a larger diameter than the straight 1 1/8" headtube found on pre-2013 Fargo models. Accordingly, it uses a headset with the larger outer diameter, but with bearings of different inner diameters for the upper and lower cups to accommodate the tapered fork.
  • 12-08-2016
    ironacct
    It occurred to me this morning that I have a 2.35 Ikon mounted to an i25 rim on another bike. The width at 25psi is a true 2.35". The 2.4 Ardent on my 2008 Fargo measures 2.39" at 22psi on a 30mm inner width rim with plenty of clearance. So, to your specific question, the Ikon 2.35 will fit the Fargo just fine. I also thought a bit more about your rim choice. I don't think you can go wrong with either rim choice for tires that wide, but one thing to consider is whether you'll ever want to run narrower tires in the future, perhaps for gravel/road riding. If so, maybe i25 is the better choice--more options.
  • 12-08-2016
    PeterJM
    Fantastic - thanks so much for the great feedback!
  • 12-10-2016
    PeterJM
    I did a bit more research on this, and was surprised to find out that Jeff Jones runs Maxxis Ardents on Rabbit Hole rims. And he seems to like it a lot. I am really tempted to go this route, i.e. put the Maxxis Ardent on a WTB Scraper i40 rim. Here are links to Jeff Jones' posts on this:
    Jones Bikes – 29×3 and 29×2.4 on 50mm rims
    Jones Bikes – The latest builds from the stand
    Jones Bikes – Knard on Jones. Another front wheel option.
  • 12-11-2016
    grizzler
    I have an ikon 2.35 on an arc27 and would definitely go for it on a 29. I've run 2.4 Ardents in my Fargo with good clearance.
  • 12-17-2016
    sgtrobo
    wife and I had some fun with the pupperoni
    Wife's fargo = 2016 X9 w/Industry-9 hubs and Stan's Crest rims, plus a hand-made front fender mount
    My Cutthroat = 2016 Cutthroat Rival 1 with Roval Traverse SL 29ers and 2.3" Renegades, and Cowbells
    Dog = 2-year old German Shepherd/wolfhound mix, named "Arya"
    Attachment 1110862Attachment 1110861
  • 12-17-2016
    kevrider
    is that an extra small fargo? do you have any pics of it fully loaded? can you trust racks on single track? seems like that could be more stressful and increase the chances of a failure.
    i've been thinking of getting a fargo for the finance, it would be XS. looks like a frame bag would be pointless, but racks... bar bag... seat bag.... maybe i won't have to carry half of her stuff. :)
  • 12-17-2016
    sgtrobo
    yes, it is an extra small fargo. i ride a 2013 fargo, size medium, with panniers, Ortlieb bags and a seat bag without issue.
    that said, carry her stuff. She appreciates it. ;)
  • 12-24-2016
    jtcallahan
    Attachment 1112063
    Just got her built for some winter time fun. It's a older Fargo frame with fresh powdercoat.
  • 01-01-2017
    misternicholas
    My 27.5+ Fargo finally came in. I picked it up yesterday morning. Setup the tires tubeless & put a pizza rack on the front. Loving this thing...
    Imgur: The most awesome images on the Internet
  • 01-08-2017
    moniemoe
    Does it look like your seat bag would fit under her seat between the tire? I am considering getting one but no LBS carries the xsmall. I am concerned about not being able to fit the seat bag between the big tires especially since there is hardly room for a frame bag. I need to be able to load it up for long solo trips.
    Thanks for any help you can give!
    Monica
  • 01-08-2017
    B_Aero
    TI Fargo
    Just a quick pic of my Fargo - rode around the lakes here in Minneapolis breaking in the new studded tires.
  • 01-08-2017
    ironacct
    FWIW, unless you are sold on 29" wheels and drop bars, I would put in a plug for the Surly Troll for riders at the small end of the spectrum. I love my Fargo and had considered building one up for my 5'0" wife, but concerns over the wheels being too unwieldy in such a small frame led me to the Troll. Capabilities are similar to the Fargo, but it's designed around 26" wheels, which seem more proportional to the frame. Accordingly, the stack is much more reasonable (40mm lower than XS fargo) for a rider that height--even so, my wife's stem is slammed and still well above the saddle height. Jones loop bars still offer versatile hand positions and easily attaches gear, while the Troll's tire clearance give you the option for up to 26x3" or standard width 27.5" if you want something other than regular 26" tires. Wife's is set up with Rabbit Hole 26+ rims and WTB Ranger 2.8" back and 3.0" front.
    Lastly, I put a rack on the back of the Troll since there was no way a seat bag (like a Pika, etc) was going to clear the rear wheel. I suspect it would be the same story on an XS Fargo given an even larger wheel, but if you're at the taller end of the XS spectrum maybe there would be enough room.
  • 01-13-2017
    SocratesDiedTrolling
    What tires do you all like to run on the Fargo for paved touring? I don't want to go with a pure road tire, as I think the skinnier the tire the funnier it looks on the Fargo, and also the harsher the ride.
    I was thinking maybe a Schwalbe Marathon of some variety, about 40mm wide? But, open to any suggestions. The idea is to ride RAGBRAI this summer. I know plenty of people have done it on Fargos out there!
  • 01-13-2017
    samwe
    I ride Super Motos and love them. I guess they are not made any more so I got Big Apples for my wife's Fargo.
    Fargo's are happier with big tires. You can actually hear the bike sob if you put on anything under 2".
  • 01-13-2017
    Erik_A
    I like the WTB Nano in 40mm for all conditions on the cross bike; bit for the Fargo would go with 29 x 2.2 slicks: Slick | WTB in order to keep the BB up at a reasonable height.
  • 01-13-2017
    You make a good point! A couple years ago, my bike shop friend loaned me a pair of Bontrager x38 hybrid tires of some sort... and they looked so funny on the Fargo. It did look sad. lol.
  • 01-13-2017
    samwe
    And every time you looked at it, you knew you had committed a horrible crime, right?
  • 01-13-2017
    big_papa_nuts
    The bb on the Fargo is that same height, and in at least one case higher, then Salsa's "road" bikes so I don't understand why you be worried about running tires as narrow as your rims will allow on it. Especially if you're just gonna stick to the asphalt.
  • 01-13-2017
    Forster
    I've run 32s with no issue. Don't know that I'd go a lot narrower due to rim width, but the 32s worked great.
  • 01-13-2017
    ciquta
    last year I did a 1500km road/lightgravel trip with 2.35" big apples, and couldn't be happier
    loved the cushion, fast rolling at reasonable pressure and good protection (only one flat)
    so much that i've put a pair also on my urban bike
