Page 105 of 112 FirstFirst ... 55595101102103104105106107108109 ... LastLast
Results 5,201 to 5,250 of 5591
  1. #5201
    Aug 2014
    Quote Originally Posted by Smithhammer View Post
    The Fargo really does seem to be happiest with larger tires (which is probably why Salsa's designers decided to produce the Deadwood). I ran some Nano 40s on mine for a while (for gravel/forest roads) and didn't like it much. Just felt too thin and I felt every little bump in the road.
    y'know, I did the same thing and had the exact same feeling. Even the 2.2 Nanos weren't all that impressive to me.
    Quote Originally Posted by NDTransplant View Post
    After the OEM Schwalbe's wear out, I believe I'll go with Specialized Renegade Controls in 29 x 2.4. Plenty of grip for basic gravel road riding, not obnoxiously heavy, etc., etc.,..
    If I don't buy a Deadwoood...
    +1 on wider rims.
    wat? Renegades come in 2.4"?? I thought they were 2.3". I got a utthroat and put the 2.3s on a set of the Roval Control 29mm internal diameter wheels, and it was absolutely perfect, but I think 2.4" Renegades would be even perfecter.
    - 2012 Salsa Fargo
    - 2015 Roubaix Disc
    - 2016 C-dale SuperX CX-1 SSCX
    - 2016 Salsa Cutthroat
    - 2017 C-dale Scalpel Si-3
  2. #5202
    Feb 2012
    My bad on that! 29 x 2.3 is the max. I was mistaken.
  3. #5203
    Aug 2014
    haha...no worries on that my man.
    - 2012 Salsa Fargo
    - 2015 Roubaix Disc
  4. #5204
    Jon BALER
    Quote Originally Posted by chrisx View Post
    microSHIFT -The best control system
    SHIFTERS>BS-M11
    BS-M11
    Compatibility Shimano 11 Speed MTB Shifters Compatible
    One small problem. 2 hours ago, I bent my derailluer hanger all the way into the cogs. The largest cog grabed the pulley draged it up and around and bent the non replaceable hanger. bent it all the way to the smallest cog. I grabed the remains of the drailleur and bent it out enough to roll. Tomorrow I will try and straighten it. I will be amazed if it does not snap off. It bent 90 degrees. What is the fix for that? Internal geared hub?
    So this is an early model Fargo without alternator drop-outs or replaceable drop-outs. Internal gear hub still requires a way to tension the chain, which would typically be mounted there the derailleur is on vertical drop-out frames. There are a couple of options for tensioning the chain at the bottom bracket, such as a phil wood product.
  5. #5205
    Reputation: chrisx's Avatar
    Quote Originally Posted by renegade44 View Post
    I was able to bend the hanger back without breaking it! I bought a m800 hub and derailluer back in 2009. I laced it to a arch rim and let it collect dust for 7 years. Shimano M800 has the derailleur attached to the axle. I was prepared. The guy from salsa broke his hanger in the 09 tour divide race. He had to get a new frame sent out mid race. After reading that, I bought an m800 to be ready, should that happen to me.
    Sometimes I get a forbidden screen when I try to post on the fargo thread. I would not be surprised if it pops up when I hit the submit reply button. Sometimes it will not let me even look it the fargo thread until I log out. Does this happen to anyone else?
  6. #5206
    Above post appeared
    11 minutes later I made another post that did not appear. I had to close mtbr because of the forbidden screen.
    common guys,whats up with that?
    Forbidden
    You don't have permission to access /salsa/salsa-fargo-thread-467422-post12609770.html on this server.
    Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
    Apache/2.2.15 (CentOS) Server at forums.mtbr.com Port 80
  7. #5207
    Reputation: backcountryeti's Avatar
    Drank the RivBike Koolaid...
    ... and installed a Wald basket. Also just added some 2.0 big apples. Turning my fargo into a poor man's Rivendell. Or middle class Riv. Whatever. Its a fun bike.
  8. #5208
    Training for the Darwin's
    Reputation: Forster's Avatar
    Sep 2013
    Above post appeared
    Forbidden
    You're "semi-forbidden", only forbidden every once in a while. I've not seen that yet, I would guess it's a server error, not related to your account, but I'm not an admin or an IT person so it's a guess at best.
    The most expensive bike in the world is still cheaper than the cheapest open heart surgery.
  9. #5209
    Tires
    Reputation: Gritter's Avatar
    Dec 2010
    Quote Originally Posted by backcountryeti View Post
    What are Rivendell bikes all about, and why are you turning your Fargo into one? I googled and found this image of a beautiful bike, but I'm fuzzy on what they're all about, like their niche or whatever. Are they Porteur bikes? I'm not sure what that means either though. Are they just sought after because they look classy with lugged steel frames? Ride quality? So expensive.
    Soma, Surly, Salsa, Schwalbe, SRAM, Sun-Ringlι
  10. #5210
    Jon BALER
    My Gen1 Fargo has been put into full-on commuter/haul stuff/townie mode.
    -Big Wald Basket with custom double-sided strut mounting to keep the basket below the bars and weight low.
    -Basket is lined with $15 Army Surplus bag with heavy duty straps for securing large items above the bag & rack.
    -Velo Orange 60mm fenders
    -Original Epic Designs (pre-Revelate) custom frame bag
    -Rear bar-end shifter modified for extra dynasis cable pull with dremel.
    -Flat Pedals!
    -Front and Rear Dynamo lighting
    -Just got Soma Shikoro brown tires to further the camo green, black, brown color scheme.
    New Bag Rain Testing - Day 245 by jon_baler, on Flickr
    Banneker - Day 307 by jon_baler, on Flickr
    WP_20151022_006.jpg by jon_baler, on Flickr
    Beer Club - Day 100 by jon_baler, on Flickr
  11. #5211
    What did you guys decide was the best bar tape?
    Best = most comfortable.
    edit;
    wow, just posted without a forbidden screen. Maybe bar tape is important.
  12. #5212
    Sep 2013
    I still use Salsa tape (doubled in some areas). It's tough enough to pull really tight, it holds up well and I've got the brown Fargo so the tape has to stay orange (seems to fit best).
  13. #5213
  14. #5214
    Lizard skins makes some good tape. Con is it doesn't stretch well. Left it on as a base layer after it began to wear. Trying out some bontager gel cork as second layer (big hands and need the added circumference- cush is nice too)
  15. #5215
    I'm + curious and wonder if anyone had tried a 29+ tire on firestarter fork. I know 27.5+ works from Guitar Ted's posting.
  16. #5216
    Jammin' Econo
    Reputation: Smithhammer's Avatar
    Jul 2015
    I've been using a double wrap for the last year - Salsa cork tape, with a wrap of Lizardskins over it. Really comfortable without feeling mushy. Lizardskins is a very durable tape that stands up well to weather.
    “I dream of a day when my children will live in a world without the shackles of cause and effect.” - S. Colbert
  17. #5217
    Jammin' Econo
    Jul 2015
    Had some fine Fargo riding in MT this past weekend:
  18. #5218
  19. #5219
    Very nice! Thanks for sharing - allows for vicarious adventuring from afar. So what do u think of those junebugs? Have u had any time on singletrack with them?
  20. #5220
    There was mention of silicon bar tape in pages gone by. Some said it was comfortable, but slippery when wet, or something. Anybody want to report back on that after a few thousand miles? Could be less slippery after it gets scuffesd up?
    second layer? Maybe?
  21. #5221
    May 2016
    In search of size small (16") Fargo. Ti or otherwise. Frame set or otherwise.
    Jammin' Econo
    Jul 2015
    Quote Originally Posted by attaboy View Post
    I've got a few hundred gravel miles and some singletrack time on them as well and I really like the Junebug. The shallower drop and less exaggerated sweep than the Woodchipper works better for me. I also found it much easier to set up the brifters for a usable position from both the drops and the ramps.
  23. #5223
    Reputation: newfangled's Avatar
    ^ hooray! Glad to hear they're working for you.
  24. #5224
    Mar 2005
    Very Cool. I am heading out that way for a family camping trip in June, Was thinking about bringing my mtb maybe the Fargo would be a better option.
  25. #5225
    Great, and thanks for the report. I may have to give em a try.
  26. #5226
    Reputation: kevrider's Avatar
    NOW, i'm in the clique!!!
    i've finally ridden my "brand new" 2014 Fargo!!! it was built up in the first week of april but i'm only now finding time to ride. i have less than 20 miles on it, but so far, so good. i was grinning like the village idiot out there today.
    it's a small 2014 frame with a Manitou Tower fork; i do have the steel fork leaning against the wall. i bought the frame 2.5 years ago, but around that time, Shimano released Ultegra Di2 with hydro/mech brifters. i knew i would want hydraulic brakes, so i decided to wait for the trickle down before building. two years later, i started collecting parts.
    RS685 brifters and brakes, 180f/160r
    XT front mech, Ultegra rear mech
    sram GX1400 crankset, 36/24
    105(?) cassette, 12-32
    Dajia ergo bar, Ritchey 30* stem
    Easton Haven post, WTB Pure V saddle
    Velocity Blunt 35, Hope Pro4, DT swiss spokes
    Conti RaceKing 2.2
    my only concern with the build was the low gear, i do use the 22t 'ring on my fully, and that bike is probably 5# lighter with a 650b wheelset. we shall see if the 24t granny becomes an issue; there were no long climbs today.
    todays ride was three commutes, home to work location A, to location B, back home. streets ==> streets/singletrack ==> streets. i was impressed with how smooth it was during the street portions; the drivetrain, the tires, the ride... but on the singletrack, that's when i was a little giddy! this bike is more nimble than i anticipated. doing the dirt on dropbars feels so wrong, it has to be right! i liked changing from drops/hooks to hoods, depending upon the grade. i also liked having the drops during the pavement slog to the dirt as opposed to being limited to one position on flatbars.
    i still have to dial in the cockpit... maybe a longer stem... thicker bar tape... but clearly this bike is going to be a lot of fun, and i haven't even begun to figure out bikepacking....
    In a world full of people, only some want to ride. Isn't that crazy?
    Seal/CRAZY/misquoted
  27. #5227
    ^very nice Fargo. Love the look with the white bits. Is that the largest cassette you can have with that derailleur? Seems like a 11-36 would take care of your gears. BTW you have one heck of a light weight FS bike!
  28. #5228
    Reputation: ACosta's Avatar
    Mar 2016
    Pretty cool. What part of MT is that?
  29. #5229
    thanks, mate! yes, choice of cassette governed by RD governed by brifters. might be possible to jury rig the RD to work with a larger cassette, but i thought i should try the spec'd part first.
    i did not go weight-weenie with the Fargo, obviously with the rims. it feels like 30+ lbs when i carry it upstairs. feels lighter from the saddle, maybe because of the short wheelbase. the FS is ~26.5.
    22 fargomiles yesterday, about 12 paved, 6-7 gravel road, 5-6 single track. great ride, great bike!
  30. #5230
    Jammin' Econo
    Jul 2015
    Quote Originally Posted by ACosta View Post
    Paradise Valley, just north of Jellystone.
  31. #5231
    Quote Originally Posted by Gritter View Post
    Check out their website to see what they are about. I will say upfront, their whole mantra is not for everyone. But, they are all about practical bikes, useful bikes, that are also pretty. If nothing else, their blog is a good read. As are their founder's books, "Just Ride" and "Eat Bacon Don't Jog."
    Latest look:
  32. #5232
    Jammin' Econo
    Jul 2015
    Decided that for some trips, esp. where I'm just riding dirt roads, I'd like to have a good rear rack and some mini-panniers to expand my capacity. However, the rack needed to be solid enough for abuse on washboards, and I wanted to keep the panniers trim and small, with rock-solid attachment. Ended up going with a Blackburn 'Central' rack (which installed very easily on the Fargo using the upper rack mounts and clamps on the seastays) and the Rogue Panda "Kaibab" mini-panniers.
    The rack is rock solid, of course you never really know until you've put a thousand miles on one. But it sure seems like it's built for the long haul. The panniers are awesome - at 10L each, they are just the size and simplicity I was looking for, with the excellent quality I've come to expect from Rogue Panda.
    I'll be putting this combo to use soon.
  33. #5233
    For those of us who love doing singletrack on the Fargo (and wonder why it works so well), I would recommend checking out Jeff Jones talking about his new Jones Plus bike design:
    Jones Bikes ? Jones Plus ? This is it.
    Longer chainstays, shorter reach and lower BB drop than a typical MTB geometry (plus a rigid fork). He actually has a lower BB than the Fargo's 70mm:
    Jones Plus BB drop: EBB in top position – 76mm drop, EBB in bottom position – 88mm drop.
    Great video with Jeff's design philosophy (while you watch him do a build):
    https://www.youtube.com/watch?v=ytCndGtdZpg
    This has caused me to want to try running a Jones Loop 710 bar on my Fargo (but with a 130mm stem).
    I am 6'-4" (with a long upper/ body torso). *On the XL 2015 Fargo, I run a 120mm 0 deg. stem with the Woodchipper bars; as well as a setback Thomson seatpost (and it feels really short for me). *I think that the combo of the tall stack on the bike and the 60cm ETT make it feel short. *I keep wishing that I can sit further back on the seat (which is as far back as it goes) when riding in the hoods on the Woodchipper).
    I know that with MTB's and wide bars, the wider you hands are on the bars the shorter your stem should be; so I am hoping that when I test out the Jones loop 710 bars with a 130mm Thomson stem that allows me to have a similar ride position as Jeff Jones describes for his Jones Plus.
    From Jeff's blog:"The Jones Plus 24″ has less reach than a small Surly ECR (398mm) and the 25″ has less reach then the medium (416mm)."
    The Jones Plus 25" has a 415cm reach + 110mm stem = 525mm
    The Salsa Fargo has a 391mm reach = 130mm stem = 521mm
    ECR | Bikes | Surly Bikes
    FARGO X9 | Bikes | Salsa Cycles
    Jones Plus | 29+ | Complete bicycle
    I am really surprised at the short reach on the XL Fargo (391mm reach). For a tall guy, this feels really short when you set this up as a cyclocross/ gravel grinder bike with drop bars. I didn't really understand "reach" until after I bought the Fargo.
    The Fargo seems most comfortable doing singletrack trails (for me). I thought that it was just because, I am old (mid-40's); and more closely resembled the rigid steel mountain bikes that I rode during college in the early 1990's. But after watching and reading Jeff Jones talk about the Jones Plus the Fargo geometry makes more sense. I still wish that it had more reach though!
    My solution is to make the Fargo a dedicated MTB with Jones Loop bars; and then build up a 60 cm Soma Wolverine (with 403mm reach) for my drop bar, gravel grinding setup.
    Attached Thumbnails Attached Thumbnails The Salsa Fargo Thread-salsa-fargo.jpg
  34. #5234
    Jammin' Econo
    Jul 2015
    One of these days, I really want to try a Jones Plus. There are so many things I dig about them (at least in theory), but I need to really throw a leg over one and try it out before I could take the plunge.
    I ran Jones bars on my fattie for a while. For bikepacking and mild/moderate terrain, I liked them, but I found the sweep to be too much for more technical terrain, at least for my preferences. Jeff obviously makes it work quite well.
    That said, I actually have a lot of fun riding singletrack on my Fargo, with drop bars. But it's critical to set the bars up for that kind of riding. Put the bars too low (as they might be on a cross/gravel grinder bike) and it's not a lot of fun.
  35. #5235
    Stem for jones bar
    Did you get a shorter stem when you switched to Jones bars. What about a higher stem? What about knockoff Jones bars, who makes them?
  36. #5236
    Searching for new tires the widest I can find for a 2009 v1 Fargo are Maxxis Ardent 29 x 2.4. Any other choices for a v1 Fargo? Note; the v1 has just a little less clearance then the newer v2 or v3.
  37. #5237
    No, you need a longer stem because of the sweep. Titec makes an $80 J-bar; but nothing else has the loop.
  38. #5238
    Sep 2013
    Hope
    Quote Originally Posted by Forster View Post
    Popped into my head about 10 years ago when a guy I work with was whining about his $350+ hybrid (purchased because he was pre-diabetic and pre-hypertension). About a month earlier he was yammering about how he was about to become disabled due to his health. I'd heard that same story for 5 years so finally I tell him "Geez, either get sicker and go on disability or get fit and stay here, either way shut the hell up about it." I followed with an offer to help him by riding with him. The first year he worked up to almost riding to work and almost riding home (it was 10 miles each way and he took a year to get to 7 miles twice a day). By the end of the second year he was riding a Trek road bike and routinely cranking out 40 mile days (funny what losing 65 pounds will do). Two years later he shows up with a Madone 5.0, now wearing more money in Kit than his first bike cost. Funny what a little non-enabling can accomplish.
    Best post I have read on 20 pages of the Fargo forum today :-)
  39. #5239
    Reputation: NZPeterG's Avatar
    Yes designed to be run with a short stem.
    Kiwi Pete from the Singletrack
  40. #5240
    Sep 2013
    Quote Originally Posted by handsomened View Post
    Thanks. Still see that guy from time to time, he's still a better cyclist than I am and I'm still jealous that he's physically able to do things in his 50s I couldn't have done in my 40s.
  41. #5241
    Jammin' Econo
    Jul 2015
    A great 40-mile ride with 1900' of gain on the Fargo yesterday, from my front door. Explored some new trails in the Big Holes that I'd been curious about. Once again, from pavement to gravel to rough jeep trail to singletrack, the Fargo eats it all up.
  42. #5242
    Building up a first generation Fargo and having an odd issue with the TRP Spyre brakes. Using XT rotors and the rotors rub on the tops on the calliper. If I move the calliper out ~ 2mm all is good.
    I notice in a lot of pictures people use BB7s with the fargo and they all have those double washers that pivot between the calliper and the frame - is this what is required?
    Thanks.
  43. #5243
    Positively negative
    Those washers are standard with Avid brakes but are not used with Tektros, or most other manufacturers actually.
    You may be experience some slight manufacturing variance or incompatibility between parts. Putting small washers between the caliper and adapter shouldn't hurt anything but you could try a few different adapters from different companies to see if they fit better. Maguras tend to be on the tall side iirc.
  44. #5244
    Nov 2006
    I am thinking of replacing my woodchippers and noticed that origin 8 shows an ergo gary sweep OS on their site, wondering if anyone has tried them or could compare to the normal gary sweep os?
    My goals are a bit more comfort (shock absorption) and hopefully a little wider across the tops as i use a bar bag that is limited in width by the bars
    I have been able to set up the woodchoppers so i can use hoods and drops while braking but they could be improved on.
    Looks like the ergo version extensions could be more usable (and effectively wider as the long parts of my wood chipper extensions rarely get used
  45. #5245
    Not really fixed.
    Feb 2016
    Quote Originally Posted by zoomin View Post
    Thanks.
    I just had to space out a set of Spyre's about 3mm on a bike with SLX rotors, no harm no foul, everything works great now.
  46. #5246
    Jammin' Econo
    Jul 2015
    A few upgrades on the Fargo checklist:
    - Rewrap bars for a little more cush in the drops. √
    - Swap up the 160mm front rotor for a 180. √
    - Wolftooth 40T cog (still to come)
  47. #5247
  48. #5248
    Aug 2014
    7 Fargos (3Ti, 4 steel), 6 Cutthroats, and 3 Mariachis.
    that's 16 of 50 bikes that are all basically cut from a similar mold.
    - 2012 Salsa Fargo
    - 2015 Roubaix Disc
  49. #5249
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Quote Originally Posted by sgtrobo View Post
    7 Fargos (43Ti, 4 steel), 6 Cutthroats, and 3 Mariachis.
    You mean 3 Ti?
    A garage full of steel frames means happiness.
  50. #5250
    Quote Originally Posted by threepin View Post
    The Ergo Gary Sweep OS is a bar that has a million other names: genetic digest, satori boondocks, koga beachcruiser, and veloorange has them as the daija far. Some info here: Budget dirt drop bars
    I've got a normal Gary Sweep OS, and love it. It's a little tough to measure spacing, but with my setup the width at the very narrowest point of the hoods (at the top) is 14.5", vs 14" with my 44cm woodchipper. And at the bottom of the levers it's 21" vs 19" for the woodchipper. I switched to it from the woodchipper and think it's a million times more comfortable.
