Results 1 to 19 of 19
    Reputation: Trailfreak's Avatar
    Dec 2004
    Rear derailleur problems
    anyone else having problems with their rear derailleur on the spearfish?
    I'm running x9 and have tried two different rear derailleurs. I'm just starting to wonder if the frame is out of alignment?
    I have a dos niner that I can put the derailleur on and the wheels. it just looks like the spacing is different between the two.
    May 2010
    No problems on my Superfish. I follow a lot of spearfish threads...haven't seen this issue. Check the derailleur hanger alignment?
    Reputation: supersedona's Avatar
    Dec 2012
    Hanger alignment, and sometimes the cassette to dropout spacing might be too close. A washer can shim that clearance a bit to put it back in range of the derailleur.
    Dec 2004
    Thanks, I've not seen any either. with the back wheel on the spacing just does not look right but it's fine on the dos.hanger looks straight as an arrow.
    Reputation: mikeyonthemadone's Avatar
    It needs to have the alignment checked, eyeballing it is sometimes not enough. Hit up your local shop and have it checked!
    Mikey
    Birthday Collector
    Reputation: ATBScott's Avatar
    What is the "problem" that you are experiencing? No symptoms listed that might be related to the adjustment(s) or the mix of components? Sometimes pieces that run fine on one frame may be a bit off on another, and adjustment basis might be different. Sometimes derailleurs have issues at their extreme high or extreme low position. If you are near these points on either the high or the low, and the derailleur is brand new, it could be that it has to "bed in" a little bit - esp on the small-cog end... Hanger has to be straight not only in a "bent in-or-out" fashion, but also "twist". Lots of little things that can cause problems.
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    Dec 2004
    The derailleur is not hitting the high gear, and just seems to never set. just does not matter how much I tweak it. dropping all the way down I have the limit screw all out. I'll get the hanger checked, thanks.
    Reputation: CYCLEJCE's Avatar
    My hanger was bent right out if the box. Lots of shifting woes, before I manned up and bought a new hanger. Problem solved! Even if yours isn't bent, its nice to have a spare!
    Vincit qui patitur
    Reputation: owtdorz's Avatar
    When I bought mine from a LBS they had to replace the cassette since it was removed to fix someone's bike and it was on backorder. It did take them a little bit to get it spaced correctly. After my cables stretched a bit they readjusted everything for me and no problems.
    My LBS will make any adjustments for me for FREE.
    That is something to be said for Brick and Mortar shops.
    Vincit qui patitur
    2014 KONA Process 153
    2016 KONA Operator
    2017 Salsa Powderkeg
    2018 Santa Cruz Tallboy 29 C R
    It's still better to know how to do all that your self. No down time for minor adjustments, no walking out of the woods for a minor mechanical. Get the Big Blue Book from Park Tools or check out their website!
    My Fargo's X9 rear had the same issue. Ended up being the hanger needed tweaked a bit. You can tweak it with a crescent wrench if need be if you don't have an alignment tool. It probably needs to be moved to the outside just a bit and the barrel tension adjusted just a tad in. The slightest adjustment in the hanger makes a huge difference especially on the 10 speeds.
    Dec 2004
    Thanks for all the replies and the hanger need a tweak.
    Reputation: c0nsumer's Avatar
    Quote Originally Posted by Trailfreak View Post
    I personally feel that the Park DAG-2 is one specialized tool that every more-serious home mechanic should have. Lots of weird, occasional shifting problems can be corrected by being sure the derailleur hanger is spot on.
    For example, my Mukluk 2 was sounding like it was going to ghost shift and occasionally making a popping noise when in the second to largest cog on the cassette. The derailleur hanger was just slightly off (pointer was 5mm off at the front and top) due to a couple recent falls. Straightened it out, things are good as new.
    Reputation: Bob12676's Avatar
    OE hangers are week.
    Thought I might add a tid bit here. My wife and I both have Spearfish and both have had derailleur hanger issues. I own a Parktool alignment tool, so it was a problem that I could take care of at home, but the problem happened quite frequently and even with a fresh adjustment the shifting was lack luster. The OE hanger is seemed really weak and the solution was to buy a hanger made from a sturdier material (I think it was DerailleurHanger.com). The new hanger really does make the shifting much crisper. If your problem persists, you may want to give one a try.
    Sep 2012
    cash converters loans
    The wrong help and advice and therefore the erroneous loan service pertaining to cash loans can result in devastation occurring When you have cash extremely fast, with not a credit score test or even difficulties, allow united states that can assist you We've a way you'll understand that is very easy to use to get into motions People as well give you the many assist you may need along the route The in your case will be debt typically the money you need without delays or maybe huge costs Furthermore you will know that we could enable you to your money around almost no period
    Even while most of us perform some of our very best set each of the information about all of our payday loans over the internet, we all notice you have issues Feel liberated to e-mail us just by email address or perhaps by means of cellular so you can get these people resolved You will end up made it simpler for as a result of well skilled workers which can enable you to ends up with very small moment Additionally, you'll be prepared to publish your individual needs at their side so as to advise you different possibilities that may refer for the software operation ought to you choose to move ahead along with receiving profit because of you
    Being client associated with payday cash advances, everyone help to placed typically the tone for what will reside construction business That is why you have to be revealing to samedayloansbest co uk]same day loans individuals what you such as together with what you dream about to determine superior You should also possibly be currently taking all of precautions towards ensure you get the best quality quotes for those loans most people obtain Everyone knows, most people protect a small fortune during the cover in paying back that will home loan Everyone help it become super easy so that you can help save due to the fact a lot of our estimates are to be not as much as what you will really give to at least one in our rivals
    If you need a amazing final results using cash advances, it's good to accomodate people Everyone all too often see people that happen to be ensconced in a very never-ending cycle of these mortgages a result of situations in the providers increasingly being overly aggressive for him or her as well as too costly It may seem in all probability desire which capital at once, it all doesn’t really mean you'll want to think the 1st supply you with see is normally the way to go Don't hurry to find out precisely what many of us are on the subject of At the conclusion, it's going to come up with a factor for yourself and to your budgeting We have a strong following of potential customers as what we should conduct runs!
    weblogs library mun ca/blogs/index php?/member/7518/]ccj loans
    honda-arista co id/forum/forum-jual-beli/z-best-payday-loans/]bad credit loans part 9
    pilgrimage asiasociety org/fast-payday-loans-bad-credit/]payday loans online delaware
    keykom ru/content/same-day-loans-contact-number/]bad credit loans halifax
    tenantexperiences co uk/members/uukkkpaydaynow/activity/]best loans rates
    ianafinancial org/index php/member/65336/]short term loans students
    infoturist ru/node/14795/]instant cash loans military
    spend-yourself-va org/forum/payday-loans-online-same-day-uk/]fast loans
    spintechspreaders com/member/155/]best car loans 72 months
    detsvartastaketet se/node/56125/]small business loans 5 000
    timsipprell com/node/15181/]personal loans meaning
    alphi org uk/member/14622/]personal loan vs auto loan
    umons-culture be/content/6-month-unsecured-loans/]poor credit personal loans based on income
    auntiestella org/member/1833/]loans online college
    dpress altervista org/]same day loans for bad credit
    On your left.
    I can't speak to the standard dropout, but the deraileur hanger on the 12mm Maxle Spearfish is poorly designed. 2 tiny flathead screws overconstrain the location, but are also structurally very weak - bear in mind the hanger is also the thread for the Maxle - therefore all twisting forces on the wheel go thru these tiny screws. I had brake rotor alignment problems due to loose screws as received from shop. SALSA - Design needs to be improved!
    To to OP - If you have not done so, be sure to check torque on those 2 screws (if you have the 12mm Spearfish).
    M
    Reputation: Hudnut's Avatar
    Apr 2005
    Hanger. I replaced mine with one from wheels mfg. It appears to be a little beefier than the stock hanger.
    Aren't Wheels Mfg. and Salsa under the same parent Co.? I just assumed it was the same part.
    Apr 2005
    Here's my bent stock hanger
    and the wheels mfg 142 that replaced it
    The wheels has an etched name and more machined feel
