Results 1 to 3 of 3
    Reputation: es254's Avatar
    Pro Moto Carbon bars still ok?
    Hey all,
    I have a quick question on my Pro Moto Carbon bars that came on my El Mar Ti. As I was riding today, they slipped backwards as I was just starting a downhill after cresting a log pile on the trail. They rotated backwards about 70 degrees or so, and I exectued a kind of slow-speed topple-dismount. I got my tools out and set about righting the bars and re-checking all the bolts, and saw that there is some definite scratching on the surface of the bar from rubbing into the stem clamp. It appears to be an outer layer of finish (or is that just how carbon looks?), so I'm hoping there isn't any structural damage to the bars.
    Below are some photos (quick crappy ones, sorry). I'm also going to run it by the LBS and have them take a look. I've never run carbon bars before so I'm admitedly a bit parnoid about them. I guess my question is with sort of surface abrasion, should I be concerned about the bars? Do I need to replace them?
    DIY all the way
    Reputation: Mr.Magura's Avatar
    Aug 2010
    If it's just the clear coat that's damaged, simply buff the scratches up, and that's it.
    Magura
    Thanks Magura! the bike shop mechanics took a look and gave it the ok, and applied some carbon prep and re-installed so I should be good to go.
  1. Replies: 7
    Last Post: 01-02-2010, 05:23 PM
  2. Spec carbon bars vs. alloy bars
    By Rock Climber in forum Specialized
    Last Post: 07-28-2008, 07:12 AM
  3. Rise on Pro-Moto bars?
    By GRAVELBIKE in forum Salsa
    Last Post: 08-14-2007, 08:08 AM
  4. Pro Moto Bars
    By Little Willy in forum Salsa
    Last Post: 09-06-2006, 05:55 AM
  5. Aluminum bars are colder than carbon fiber bars.
    By KRob in forum General Discussion
    Last Post: 01-13-2006, 12:49 AM
