Painting inside the Salsa emblem...
I want to color in the Hot Pepper emblem on the front of my Mukluk... Any ideas on the easiest way to do this? What would be the best paint to use?
Pepper-- Red
Top part-- Green
Birthday Collector
One technique would be to use some nail polish - you get a small vial, with a small brush that is easy to get "detail" with, and a bazillion color options... When we get a hard-to-match bike in that someone wants touch-up work done on, we usually can find some close matches at a CVS or Walgreens, etc....
I checked the emblem on my Salsa bike and it has a clear coat. To prep it, you may want to carefully rough up the top edge of the chile and leaf/stem with a dremmel or sand paper. You can also find primer, paint and little brushes in hobby shops that would last longer than nail polish. On the other hand, if you use nail polish over the existing clear coat, you could scrape it off if you don't like it.
I used some sandpaper scuffed up the areas on my Fargo that I wanted to paint, and then painted it with some small brushes and model paint from a hobby shop. Turned out fine and held up to crappy weather well, even on the dropouts.
Testors or tamiya paint with small brushes from a hobby shop. Make sure to stir the paint well, and use some thinner so the consistancy is...consistant.
Well how about some pics of hand painted Salsa logos?
I second the hobby shop paints. That should work pretty well. You could also get a clear coat to spray over top if you wanted.
Depending upon what the surface is like, you might be able to use a sharpie for an anodized type look. just a thought.
...big and slow
After a very wet, messy and fun Global Fatbike Day Ride, my tempera paint looked pretty runny and in need of being redone. So this time I went for a more permanent solution by using Testers model paint.
Not too many people notice the colored head badge but those who do really like the idea. A nice subtle customization anyone can do their Salsa.
The color paint looks really cool...esp. with the flat black frame color.
Makes me think about my Salsa bike.
Nice. Man, I really want a Mukluk!
- You may not post replies
- You may not edit your posts
Forum Rules
