Greets all. Quickly allow me to introduce myself as a shop guy and Salsa fan down in Austin Texas. While my primary job of raising a couple of kiddos under the age of 2 dominates my time - I do like to get out in the garage workshop and tinker when I get the chance.
My latest project is converting my Casseroll into a dedicated commuter bike. I recently ordered up a set of Honjo fenders because I love how they look. Today the planets aligned in my favor and all the girls left the house on an all day post-Christmas playdate with some neighbors. I took the opportunity to leave work a couple hours early and crank up this project.
I'm figuring I'm not the only guy out there who'd like to put a set of Honjos on his Casseroll so I figured I'd post a brief description of the process as I'm experiencing it because, quite frankly its a bit more involved than I was expecting. These aint no planet bike fenders.
Pardon the bad text in the pictures. I had to resize them to get them to upload after I had edited the text boxes into the pictures.
For reference I used the following websites for reference. I'd read these both before doing the job. They are helpful but it seems every bike has its own challenges with installing alloy fenders.
Velo-orange
Jitensha
Also a Flikr album with detail shots
Step 1 - Installing the fender brackets
This went easily enough. I used the 15cm recommendation from the Velo-orange instructions, drilled my holes and tightened the bolts up. So far so good! Piece of cake. You sir owe yourself a sip of homebrew. See the first picture for a shot of the bike with the brackets installed.
Step 2 - Mounting the front fender at the brake post
Velo orange recommends using the daruma to hang the fender from the brake bolt. Sweet, I ordered me one of those with the kit. Doh! doesnt fit with the Casseroll crown design. The crown doesn't expose enough of the bolt to use the daruma, and to be quite honest it doesn't have a flat enough "bottom" of the crown surface to tighten it up properly. Someone please correct me if I'm wrong about this part. See pictures 2 and 3 to understand what the daruma is and the appearance of the fork crown innards.
Step 2.5 - Mount front fender using the L bracket.
Fortunately I had ordered an L bracket with the fender kit as well. I lined it up with the brake post, marked the holes with a sharpie, drilled them out and screwed down the bracket. Here I ran into another problem at the fork crown. Using the standard hole placement with the bracket in the position I'm assuming it should go one of the screw heads hits the crown and does not allow the fender to slide up away from the tire enough to allow good clearance. My fix was to drill another hole in between the two original holes on the L bracket. I'll be using the two holes toward the tip of the bracket to position both screw heads up inside the steerer tube and not interfere with the crown. I also put a dent into the top of the fender to fit under the Tektro long reach calipers. (Now there's justification in my mind for some new Paul Racer Brakes!) See pictures 4 and 5 for a shot of the modified L bracket and final install picture.
So far thats about as far as I've gotten. I still need to hacksaw the fender braces for the front fender and start over with the rear. I'll update as I complete the job. In the meantime I'd like to hear if others have tried this as well with any tips or different outcomes - Jason, I know you had mentioned having a set ready to put on.
Other notes: I'm not getting enough clearance for comfort with Pasela 32c tires. Using the conti CityRide tires that are a noticably smaller 32c I get much better clearance. A 28c or a "small" 32c seem to fit the bill for this setup.
Velo-orange
Jitensha
