Results 1 to 8 of 8
    Nov 2013
    Maxle swing plates el mariachi
    I'm curious how many people are using the maxle swing plates on an el mar. I'm buying a hardtail this spring seriously thinking El Mar. I realize the El Mar is proven, but it just seems like the maxle swing plate would void the point of the thru-axle. Is there any flex in that setup? With all do respect wanted to hear from owners with the maxle swing plate or those that have ridden this setup. thoughts? thanks in advance!
    Dec 2005
    I've got an El Mar with QR swing plates, and I sure don't notice any lack of stiffness back there.
    Call me old school, but thru-axles on the rear of hardtails seem a little bit pointless... It's not like you're going to make a rigid rear end much less flexy, it's rigid already!
    Reputation: VeloRyan's Avatar
    I'm planning on doing the change over to thru axle plates too. I feel like the swing plate drop outs are decently stiff but I feel like the maxle change over will add to the wheel and frame stiffness without a huge investment (assuming your rear hub can be converted easily as well).
    -VeloRyan-
    I'm looking at doing a new set of wheels, but 160$ for these plates?!?!?!?!?!
    What gives?
    Oct 2011
    They come with the Maxle, which by itself would be probably $50-80 (based on Google). A lot of other frames that have optional 142x12 dropouts don't come with the axle.
    the 135 plates are like 20$ a piece so plus your 65$ still isn't 160!
    Not saying I won't pay that, but i'll hurt for a while.
    universal cycles has one side (right) of the maxle swing plate for 30$ but is out of stock. and the pair for 160$ also out of stock
    Reputation: Idshooter's Avatar
    In stock now. Use code vip10 for 10% off.
    Reputation: jmiah's Avatar
    They are all out of stock. Have been for a long time as they were discontinued while Salsa was working with a new manufacturer to put a new version out. According to Salsa, these were to be available to order from "your local Salsa dealer" at the end of the month. That was April and I still can't find them anywhere. For what it's worth, after a few years of riding this bike the set screws on both sides no longer hold (due to torque I'm sure) and one side the screw that holds the brake mech to the dropout is stripped causing the brake mech to move under braking conditions. I was looking for these to kill two birds with one stone. It is starting to look like I'll be stuck just replacing the original QR dropouts or risk riding a whole season with a flexy brake mech.
  1. Zee FR for 2x10 with SLX GS plates ?
    By guim in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-06-2013, 03:43 PM
  2. New Plates
    By dwt in forum Idaho, Montana, Wyoming
    Last Post: 02-28-2012, 10:23 AM
  3. Maxle lite vrs old Maxle
    By Jaybo in forum Shocks and Suspension
    Last Post: 12-20-2011, 07:30 AM
  4. Shimano top-swing, bottom-swing?
    By Stratocaster in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2011, 02:16 PM
