Results 1 to 5 of 5
    Feb 2012
    Hooking up a bike computer to a Vaya
    Since the rear brake cable is on top of the chainstay, how have you guys hooked up your cadence/speed computers?
    Feb 2012
    So, apparently I'm screwed and there is no way for a computer w cadence to be hooked up to the Vaya.
    Reputation: ianick's Avatar
    Can you put the sensor upside down on the bottom of the chainstay? What computer are you using? Can you post pics?
    Just un-tie the cable to get a small amount of slack and route the cable behind the sensor. Mine worked fine. If your route the cable on the outward side of the sensor it will hit the crank arm. Then re-tie.
    Good luck.
    Reputation: PhatRoller's Avatar
    This is what I use: http://bontrager.com/node/sensors/. Attaches with rubber bands, and goes right over the cabling on my Vaya.
