Results 1 to 8 of 8
    Fargo Ti build questions
    I am building up a Fargo Ti (waiting on a few more parts to come in). I have a few questions concerning the build. A.) Do I need any Ti prep for the frame? I have heard that aluminum and titanium "cold weld" together. Is this true? Would any aluminum part that contacts the frame fuse together permanently? B.) Pretty sure I know the answer but can bb7 mtn brakes be modified for apex brifters? I'm thinking not but am interested to know if anyone has done it. I have built a few bikes before but I realize there is still a learning curve. Any one built up a Fargo ti I'm open to advice/opinions.
    Birthday Collector
    Reputation: ATBScott's Avatar
    Just a bit of grease or anti-seize on the aluminum/Ti interface will prevent any problems with the Aluminum oxidizing. Good idea to do this with any parts except carbon [Edit] with about anything - always use assembly paste to grip. The Ti will not corrode or oxidize in the environments you will survive!
    BB7 Mtn brakes have a different pull than the road versions. If you are spending the money building a Ti Fargo, get the right calipers and you'll be way happier with them than any type of jury-rigging you might do to try to make the wrong calipers work with road levers. That is going to be a nice ride.
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    Mar 2012
    Just my 2 cents, but I have Force shifters on my Fargo, we had to put on Road BB7s and not Mountain BB7s.
    Yeah I noticed the angle of the control arm is smaller on the road bb7s to accomodate a shorter pull. Might as well get the right parts like ATBscott said. After all it is a Fargo ti. Do it right
    May 2010
    I think a Fargo ti is in my future; my plan is to just move all/most of the parts off my gen 1 Fargo at first.
    I bought the fargo ti to be a one bike to rule all bike. I have become a multiple bike owner and wanted a bike that would last a lifetime. I hope that maybe I can sell/donate my other bikes to people would need them or don't have the means to buy a bicycle. I got a good deal on the frame as well and I think its the last of the US made ti frames. I'm running compact road gearing with a sram apex 50/34 crank. I figure a 34 will probably handle most of the singletrack around here (I used to ride a SS monocog that was a 34x19 without any problems). Thoughts?
    Quote Originally Posted by Dr_MurdocChongo View Post
    If you've been 34x19 single speed and have no problems, it shouldn't be an issue. I'd be more worried about ground clearance for the 50 tooth.
    Reputation: kevrider's Avatar
    not sure about the ti frame, but the steel frame requires spacers when using a road crankset.
    In a world full of people, only some want to ride. Isn't that crazy?
    Seal/CRAZY/misquoted
