Results 1 to 34 of 34
Thread: Fargo Knard
    Reputation: seat_boy's Avatar
    Fargo Knard
    Anyone know if a Knard will fit on a V1 Fargo fork?
    Ride good on the internet
    Nope. Not even close on a V1...
    We tried it on a customer bike, and had to crush his dreams.
    Reputation: shiggy's Avatar
    Dec 1998
    Fargo Knard
    Quote Originally Posted by seat_boy View Post
    Which Knard? The 700x41 would fit fine.
    mtbtires.com
    29x3".
    Quote Originally Posted by shiggy View Post
    Dang. After making this post, I saw this other thread, where G-reg had a Knard on a 26" Salsa fork (I think 447mm length). Maybe the bend of the unicrown is different and limits the fork? Do you recall if it was with a RH rim? I wonder if that stretched the tire out vs. the 35mm Velocitys on G-reg's bike.
    Quote Originally Posted by Pancake Adventure View Post
    I've tried the RH+Knard 3.0 on my Fargo v1; not even close. I've also ridden lots of miles with a RR 2.4 on a Gordo (35mm, I think), and there was lots of room. So a Knard 3.0 on a Flow or a 35mm rim *might* work, and it might not.
    May 2010
    Fargo Knard
    If my memory serves me right, my 3.0 Knard didn't fit in the V1 Fargo fork, even on a Rynolite rim.
    Reputation: bigringrider101's Avatar
    It fits. I'm running the Fargo fork on my El Mari steel. My LBS had the Krumpus. I took the front wheel off and put it on my bike. It fit fine
    May 2010
    Fargo Knard
    Not in a V1 (1st Generation) Fargo fork.
    It only fits in a V2 (2nd Generation) Fargo fork.
    Quote Originally Posted by FTMN View Post
    Correct, sorry. I have the V2
    FYI, here's a pic of the Fargo V2 with a Knard/Blunt 35 combo (on my current bike):
    Oct 2013
    Holy Smokes, WIll that fit on the rear wheel?!
    Adventure Mapper
    Reputation: forgiven_nick's Avatar
    Nov 2006
    29+ vs B+
    Quote Originally Posted by Gyro_t View Post
    The 29x3.0 tires (29+) won't fit in most 29er frames, but 27.5x2.8 (B+) will!
    Guitar Ted Productions: B+ Riding Experience
    My YouTube channel for MTB content:
    http://youtube.com/RideAlongside
    Website:
    RideAlongside
    Oct 2013
    That makes a good case why 650B wheels have a place in mountain bikes. This give the Fargo that much more versatility, the reason I bought mine in the first place. Is that a custom wheel or off-the-peg? That is a 650B = 27.5 X 2.8 B+ Blunt rim, correct? That looks pretty damn close to as much rubber down as the 29er Plus
    Adventure Mapper
    Nov 2006
    I wasn't the one who wrote the article nor do I have first hand experience with this setup, but I believe it is just a run of the mill 650 velocity blunt rim.
    The real difference is in the plus sized 27.5x2.8 tire (B+ aka 27.5+ size) that brings the overall diameter to 28.9inches, whereas the the 29x3 (29+ size) has an overall diameter of 31inches.
    Website:
    RideAlongside
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Quote Originally Posted by forgiven_nick View Post
    Yes, that's my bike and the set up was with a Blunt 35 and the WTB Trailblazer 2.8"er.
    I ended up putting the wheels and tires on my Trek Sawyer where they fit great with plenty of mud clearance and lower the BB to a more reasonable level. Those Sawyers have pretty high BB's to begin with.
    I may end up moving these to my Gen II Fargo before winter ends though......
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Oct 2013
    So when you say "these" you mean a 29er plus up front and the "650B+" on the rear, like seat_boy did. Thanks to you all. This is going on my Fargo this winter. Just looked at the Velocity site and have a little sticker shock at the $600 wheel set for the "standard" 35s. I imagine a single rear wheel is going to be over $300 retail.
    Adventure Mapper
    Nov 2006
    Thanks for adding to the conversation Guitar Ted!
    From what I have read, you are really preferring the B+ setup for both front and rear as opposed to 29+ front and B+ rear, but it would be beneficial to hear your reasoning reiterated here if you are willing. I currently am planning to run the Maxxis Chronicle 29x3 tire up front on a Velocity 35mm rimmed wheel with a 29x2.4 Maxxis Ardent on the rear. I won't be able to purchase the new front wheel and tire until this spring, so any advice you can give to help me fufurther form an opinion would be much appreciated.
    Website:
    RideAlongside
    Harmonius Wrench
    Here's the full monty with the bag set up I tried on the Gen I Fargo.
    Couple of clarifications:
    • I never ran a 29+ wheel with a B+ back wheel
    • I removed the wheels from the Fargo because it wasn't an ideal set up- Too low in the BB and not quite enough clearance
    Okay, with that said, I will say that I have contemplated putting the B+ wheel out back with a 29"er 2.4" Chunky Monkey on a Dually up front on my Singular Cycles Buzzard. I think this would slacken the head angle a bit more, lower the BB a tic, and allow for a faster spin up out of corners. Essentially, making this a more DH oriented bike.
    I wouldn't do this on a Fargo set up, and the reasons why are the same as the ones "why I would" for the Buzzard. A Fargo, in a bike packing set up, or touring bike off road set up, probably would not benefit from the slacker head angle, in my opinion. I do feel a bike designed for that sort of mixed wheel set up might be intriguing, but the Fargo wasn't designed for that, and since that is the case, I feel it would be a step backward in handling. YMMV
    The Buzzard, on the other hand, is set up to be a slack, DH oriented sled from the get go, and doing what I am contemplating is seen as "tuning the ride" to a different attitude which I think the base geometry is good for. The Fargo- not so much.
    I am- as stated in my previous post- going to give the Fargo Gen II bike I have the B+ treatment just to try it out. I may find clearances and BB height to be different there. We;ll see, but it is Winter now and my attention has turned to something different for the time being
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Adventure Mapper
    Nov 2006
    Thanks GT! Enjoy that dingle dingle this winter!
    Website:
    RideAlongside
    Big wheels keep on rollin
    Reputation: senor_mikey's Avatar
    The Fargo's have more BB drop than a standard 29er. (70 vrs 60 mm drop) For that reason I would just be aware that a 650B+ wheel will drop the BB from 6 to 10mm depending on the tire you compare it to. Of course if you are doing less technical riding or touring this may not be a problem.
    That said I ride a custom monstercrosser with 75mm of BB drop and 44 mm tires and rarely have any issues with pedal strike
    mike
    Reputation: TheirOnlyPortrait's Avatar
    Dec 2014
    Quote Originally Posted by Guitar Ted View Post
    [LIST][*]I never ran a 29+ wheel with a B+ back wheel [*]I removed the wheels from the Fargo because it wasn't an ideal set up- Too low in the BB and not quite enough clearance
    I am- as stated in my previous post- going to give the Fargo Gen II bike I have the B+ treatment just to try it out. I may find clearances and BB height to be different there. We;ll see...
    Hola Guitar Ted!
    IŽm analyzing a Fargo B+ (Blunt 35 & Trailblazer 2.8") for gravel touring... do you think the lower BB might be an issue here, too?
    Saludos,
    Federico
    Cycling in developing countries, making & printing portraits for those families who've NONE. www.theironlyportrait.com
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Please keep us posted, I just purchased a 2014 Gen2 Fargo and Im very curious to hear you conclusions on the fitment.
    #THELEGEND
    2016 RSD Mayor
    2017 Diamondback Haanjo Trail (Alu)
    Harmonius Wrench
    Hola Guitar Ted!
    Saludos,
    Federico
    Not at all. Well, not unless you get into some badly rutted dirt, then maybe.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Harmonius Wrench
    Quote Originally Posted by Guy.Ford View Post
    Will do. May get the itch to play with that sooner since the weather is supposed to get warmer again and melt our current snow cover.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Adventure Mapper
    Nov 2006
    GT-
    Just heard about your transition from TNI to RG. Congrats to you, although I am a little sad after thinking back to all the articles and reviews of yours I have read on TNI. Thanks for all you have done for the community!
    Website:
    RideAlongside
    Dec 2014
    Hola Guitar Ted!
    Thanks for the GOOD news
    On the first stage of my Project (Their Only Portrait. Portraits & Cycling) IŽll be cycling Ruta 40 in Argentina (80% paved).... but after this IŽll also be riding Bolivia & Peru and I would love to keep the same bike for the whole Project.
    Saludos,
    Federico
    PS: Anxiously awaiting for a 29+ Fargo!!!
    Positively negative
    Quote Originally Posted by TheirOnlyPortrait View Post
    Hola Guitar Ted!
    Saludos,
    Federico
    You can build a current 29+ frame with drops, see this thread Any drop-bar specific 29+ frame?, just keep the top tube length in mind.
    The ECR I posted in that thread is a great example.
    Attachment 940303
    Harmonius Wrench
    GT-
    Thanks. That's nice of you to say.
    In some ways, this switch makes it easier for me to comment here than before. I won't be going anywhere anytime soon.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Harmonius Wrench
    Quote Originally Posted by big_papa_nuts View Post
    Attachment 940303
    Here's the results of the B+ fitting. Thoughts....
    • More clearance with Gen 2 than with Gen 1
    • Ride feel is very similar to when I had these wheels on other bikes.
    • Spins up fast-Loses momentum faster than 29"er wheels
    • Easier to get moving than 29+
    • Similar roll over, cush feel, and traction as with 29+
    I'm not 100% convinced this is for me, but it is very interesting. I'll have to wait for the trails to clear up before I decide if this is for me.
    On the other hand, the ECR drop bar bike idea makes a lot of sense, except that you are limited out of having a triple. The key for me is bottom bracket height. The ECR is designed correctly, conversions of fat bikes and other bikes, don't account for this. The ECR and the new Jones + bikes seem to be the direction I'd like to see a "plus sized Fargo" to go in.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Dec 2014
    Attachment 940303
    Hola Big Papa Nut,
    Sorry for the late response! IŽs analyzing the ECR but I wasn`t sold because I might want to get a suspension fork in the future (and I would also like to keep the same bike for the whole Project).... but IŽll definitively spend more time analyzing this option
    Thanks,
    Federico
    Nov 2014
    Anyone know if a 3" Knard will fit into the carbon firestarter fork? Thanks!
    Reputation: bubba13's Avatar
    Hey GT, Could you possibly measure the O.D. of your Blunt 35/WTB Trailblazer wheel? Trying to compare these to 29" Flow EX with 2.2 Continental Race Kings currently installed on My GF's gen 2 Fargo. Would like to get an idea how much the BB will drop. These would act as a 2nd set of wheels intended for dirt, gravel etc.
    EDIT: Found a diameter measurement on your B+ Sawyer story. WTB Trailblazer tubeless after 24 hours = 28 9/16" O.D.
    Portland Off Road Navagators
    Feb 2006
    We the people ... fargo chronicle
    got some new rims 50mm chris holm freeride 29er,got a 3 inch chronicle up front and 2.4 ardent on the back
  1. Fargo 2 vs Fargo 3
    By windhorze in forum Salsa
    Last Post: 09-09-2014, 04:46 AM
  2. Gen 1 fargo just not sure
    By ADV in forum Salsa
    Last Post: 05-18-2013, 06:40 AM
  3. Replies: 22
    Last Post: 08-13-2012, 10:55 AM
  4. Old Fargo or New Fargo?
    By cfpete in forum Salsa
    Last Post: 03-14-2011, 06:02 PM
  5. Fargo Steel vs Fargo TI
    By surly73 in forum Salsa
    Last Post: 03-12-2011, 04:53 AM
Members who have read this thread: 7
