Page 17 of 17 FirstFirst ... 71314151617
Results 801 to 832 of 832
  1. #801
    Quote Originally Posted by Ryder1 View Post
    So a 32t oval ring runs fine on a 2015 steel El Mar? Doesn't hit the frame at all? Salsa says 32t max. I'm building from the frame up, probably with XT M8000 crank. I was thinking oval 32t might hit the chainstay. Anybody running 34t on a steel 2014-2016 frame?
    My bad man, I didn't see this until now, here's some pics to help you with your decision making, I think you can run the 34T no problem. If you see I put some spacers on my ring, to push it closer to the frame, which allowed the chain to stay more aligned and when pedaling backwards, the chain doesn't drop.
    The El Mariachi photo thread!-img_20161023_091439.jpgThe El Mariachi photo thread!-img_20161023_091454.jpgThe El Mariachi photo thread!-img_20161023_091601.jpg
    Sine my salsa was one size too small for me, I ended up picking up a Kona Unit, a other steel frame bike, heres the M8000 just for reference.
    The El Mariachi photo thread!-img_20161023_091635.jpgThe El Mariachi photo thread!-img_20161023_091643.jpg
    Sent from my Nexus 6P using Tapatalk
  2. #802
    Mar 2012
    From a recent bikepacking trip. I've been running 27.5 Blunt35s with 2.8 tires since spring and loving it! Clearance is tight in back but have yet to experience any rub even after 500 + miles. Dropouts are all the way in.
    Drivetrain is 1x10 with Sunrace 11-42 cassette and oval 32t chainring.
    The B+ setup transforms the bike as far as handling and cush. No bottom bracket issues either.
  3. #803
    EXORCIZE
    Reputation: Ryder1's Avatar
    Quote Originally Posted by Vto2.0 View Post
    Thanks! I think 32t oval + 19t cog will work nicely.
    2016 Pivot Mach 429 Trail
    2011 Kona Unit
  4. #804
    Professional Nerd
    Reputation: Danimal's Avatar
    Quote Originally Posted by wahday View Post
    Very cool set up, thanks for sharing. Think you gain any rear tire clearance with dropouts slid back?
    Dan
  5. #805
    Mar 2012
    Quote Originally Posted by Danimal View Post
    Dan
    I don't think so, though I have haven't moved them. It rides so beautifully the way it is set up I have been reticent to change anything. I think the tread would be too close to the chain stays if I moved the dropouts out. Based on my experiments with 29er plus wheels on this same bike (FBNimble almost fits in the back...) I think I would start getting rub when cornering since tread flexes more than other parts of the tire.
    But I have ridden the hell out of this thing over the last 4 months and no rub or other issues. Even light mud was not a problem (again I think because of where the actual tread is). The bike is very stable and playful. I take it everywhere I ride my FS without hesitation. Really shines as a commuter/bikepacker but rips as a day rider too.
  6. #806
    You have any up close shots to see the clearance? I might set one up like this, this thing looks super nice.
  7. #807
    Shift less, Pedal more.
    Reputation: Birdss's Avatar
    +1. Please post a pic. I'm running a 29er Kenda Slant Six Pro that is a 2.35, but runs fat. I had to move my dropouts back to gain some additional tire clearance. I'll post a pic later.
    Thanks in advance.
    I'd rather be hated for what I am, than loved for what I'm not......Dolemite.
  8. #808
    Mar 2012
    Right chain stay
    Left seat stay
    Ok, here are some shots of rear clearance for the Trailblazer 2.8 X 27.5 on a Blunt35 rim. This is a 2012 El Mariachi and the dropouts are all the way in.
    Yes, the clearance is tight! It is closest at the chain stays but again, I have really abused this thing and no tire rub. They are set up tubeless.
    I have been thoroughly happy with this setup!
  9. #809
    Right chain stay
    Left seat stay
    Not bad at all, you sir have given me hope to run 27.5 on my salsa and on my Unit - Kona unit
  10. #810
    Does anyone know if the B+ setup will work with the stock 29er Reba fork on the El mar?
    Salsa El Mariachi SS
    Salsa Vaya
    Lurch Fatbike
  11. #811
    Mar 2012
    These guys tried it with success running trailblazers, though not on a wide rim (35mm or wider). There is a pic of the clearance.
    "The clearances to the fork are getting a little tight on the sidewalls but perfectly acceptable, with the wide rims this may be more of an issue. We tried them in both Rockshox Reba and Marzocchi 320 29er forks with pretty much identical clearances."
    I put the same wheelset pictured above on my Anthem 29er which has an F29 fork. The clearance is more than acceptable and the bike rode wonderfully. Bottom bracket drop was an issue, though. Not so with the El Mar!
  12. #812
    May 2016
    A picture from last weekends trip to Mohichan.
  13. #813
    Feb 2012
    Quote Originally Posted by sven98 View Post
    yes it will....ran it that way for about 9 months, then set up a lefty to run B+ this el mar will be mine forever
  14. #814
    Reputation: JUSTINAZ's Avatar
    Dec 2004
    How I turned a steel El Mariachi into a Ti El Mariachi.
    I picked up a 2014 SS on a close out and [wanted a TiB]loved[/B] it. I had a good crash and dented up the frame and tacoed the rear wheel.
    Salsa has a crash replacement program ( new frame at a discount).
    They had no El Mariachis and I got the word that they were discontinued.
    Always wanted A Ti El Mar so I bought a slightly used frame off eBay and a case of Top Ramen.
    Build
    Salsa Ti El mar frame
    Salsa Chromoto fork
    Cane creek 40 headset with 110 bearings
    Industry 9 SS hubs laced to Easton Arc 30's
    Maxis icon 2.35 rear Ardent 2.4 front
    Ti-carbon bolt on thru axles
    Easton haven carbon bar / ESI grips
    Shimano xt Brakes and rotors
    Sram XO carbon cranks Wolf Tooth 32t Rennin 20t cog. Chris king 12 tooth lock ring.
    Time ATAC pedals
    KMC 8spd chain
    Thomson masterpiece Post
    Thomson stem
    WTB laser V team saddle ( great seat but discontinued)
    22lbs. 11 ounces but who's counting.
    Bike rides like a dream but I nut a huge difference over the steel.
    Attached Thumbnails Attached Thumbnails The El Mariachi photo thread!-img_2540.jpg
  15. #815
    Feb 2012
    Lovin my El Mar out at Fort Ord!
    Finally found a small frame.
    Attached Thumbnails Attached Thumbnails The El Mariachi photo thread!-img_4231.jpg
  16. #816
    Looking for a large ss probably rigid for lower $. Frame or bike. Thanks
    Jimbo
  17. #817
    Aug 2016
    Nice
  18. #818
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    My dream bike is finally in my hands. I have found my cycling panacea. Holding this beauty in my hands brings mixed feelings towards Salsa. Praise for making something so unique and nice, and dissappointment for pulling the plug on the most beautiful, coolest hardtail ever.
    I can't wish for more only for this frame to last for ever! (at least till I die since its now... "obsolete")
    Cheers
  19. #819
    Professional Nerd
    Looks awesome, post pictures during/after the build. I feel the same way about mine; I won't even keep it in the garage because I can't risk it getting stolen. I have much more expensive bikes, but this one literally can't be replaced...
    Been getting my El Mar all ready for 2017 while it waits patiently. A pic from a late fall ride:
  20. #820
    Merendon Junkie
    Dec 2011
    So the big event happened yesterday. I spent my afternoon with the El Mariachis on the stand, swapping my parts from the old frame to the shiny pretty new (to me) one.
    First order of business was stripping the old one. I felt kind of sad while I was at it, the bike had done nothing wrong ever but was getting un done none the less.
    Now that I had both frames bare, I though it might be a good time for a weigh in. This weight is with headsets, rear slider dropouts and rear brake adaptor on. I was quite surprised at the substantial difference in weight. Was expecting the Ti frame to be about a pound lighter at most.
    After a couple of hours and a couple of beers, my new El Mar, was ready. The swap was pretty straight forward. I did have to get an adapter for my fork as this frame came with a tapered headset. I had to cut a linkset from my chain due to the shorter stays and put on full cable housings.
    Yellow housing was all I had so I will have to stick with it for the mean time. Maybe it will grow on me. These are some better quality pics taken this morning.
    I REALLY like the look of this bike. It looks much better in person than I ever thought. I havent had the chance for a proper ride yet. I did a couple of laps on my backyard just to finish setting it up. So far it feel greats, the shorter stays are noticed when cornering. Tomorrow will be its first real ride.
    Cheers
  21. #821
    Sep 2013
    Abelfonseca, Beautiful El Mar! Where did you get your titanium frame? Is it new or used? Thanks...
  22. #822
    Merendon Junkie
    Dec 2011
    Quote Originally Posted by mohrgan View Post
    Thanks Mohrgan! I bought the frame from a fellow mtbr member. It is used but extremely well taken care off, almost looks like new.
    Cheers
  23. #823
    Professional Nerd
    Sweet build, thanks for the details and good pictures. Put some 3M clear tape on that frame to protect it from cable rub! The yellow cables look good...
    Dan
    *EDIT* One of the pictures makes it look like you did put some protective tape on the downtube...
  24. #824
    Merendon Junkie
    Dec 2011
    Dan
    Thanks Dan. I put some "helicopter tape" on al cable/frame rub points. I will put some on the stays too for the occasional heel rub.
  25. #825
    wanna ride bikes?
    Oct 2013
    that thing is beautiful! ditch the yellow when you get around to it though, it distracts from the beauty of the Ti.
    good stuff though congrats!
    Rigid SS 29er
    Fat Lefty
    29+
    Hardtail 29er- dead forever
    SS cyclocross
    all steel, all the time
  26. #826
    Salsa El Mariachi by Sven S., on Flickr
    Salsa Vaya
    Lurch Fatbike
  27. #827
    Cool-blue Rhythm
    The El Mariachi photo thread!-el-marmtbr.jpgThe El Mariachi photo thread!-elmarmtbr2.jpg
    My Old Clunker - 2011?
    Old style skinny headtube and ancient quick release dropouts (no problem with Deore Skewar).
    Usually setup with Salsa Cromoto rigid fork (pictured bottom), but currently with Fox F100 as it came to Lancashire (Northern England) which is a bit bumpier than my usual Hampshire trails. About to replace the old 1 x 10 (11-36) setup which lasted 18 months. New setup will be: new 32t oval chainring with Sunrace 11-42 cassette and Goatlink to help shifting. It'll be ready tomorrow so I'll be searching out some steep stuff to see what that 42t 'granny' sprocket can do.
    Update:
    I took the bike out yesterday with the new setup. My buddy had been impressed with the way the Goatlink wrapped the chain around the cassette when it was set up, and I found the whole thing worked well in practice. I had no shifting problems and 42 tooth sprocket got me up a couple of things which I would have probably struggled with if I'd been on the previous 11-36 cassette. First impressions - Good.
  28. #828
    Reputation: Raymo853's Avatar
    My first year Ti, no sliders, Lynskey made, with the classic straight headset frame. Thinking of selling it, have little use for it these days.
    Sent from my SM-G900V using Tapatalk
  29. #829
    wanna ride bikes?
    Oct 2013
    ^ what size?
    I'm looking for an El Mar, but i need an XL
    Rigid SS 29er
    Fat Lefty
    29+
    SS cyclocross
  30. #830
    Quote Originally Posted by *OneSpeed* View Post
    ^ what size?
    It is a medium.
  31. #831
    Reputation: thx138's Avatar
    Aug 2013
    ^ what size?
    What exactly are you looking for? I've got a 2014 ti XL that I have been thinking of selling.
    Sent from my SM-N920T using Tapatalk
  32. #832
    wanna ride bikes?
    Oct 2013
    Quote Originally Posted by thx138 View Post
    well, that would be sweet! I have been looking for a frame for a while. that may have been an option before last week but I just contacted a frame builder and it looks like I'm getting a custom frame.
    I'll still keep an eye out, i like the El Mar, and if i come across an XL frame i'll grab it.
    Rigid SS 29er
    Fat Lefty
    29+
    SS cyclocross
  1. 2007 Salsa El Mariachi LE 29er Photo
    By chris9888 in forum Salsa
    Last Post: 05-09-2015, 11:30 PM
  2. 2013 Photo Thread
    By El Salt in forum Ventana
    Last Post: 12-26-2013, 09:29 PM
  3. Nimble 9 Photo Thread
    By rob1035 in forum Canfield
    Last Post: 10-28-2013, 10:35 PM
  4. Bullit photo thread (Merged thread)
    By Pete in forum Santa Cruz
    Last Post: 05-18-2012, 12:49 PM
  5. Photo Thread.
    By benwitt11 in forum Fat bikes
    Last Post: 03-29-2011, 05:34 PM
