Page 1 of 3 123 LastLast
Results 1 to 100 of 295
    likes to ride bikes
    Reputation: TunicaTrails's Avatar
    Dos Niner Fan Club
    Salsa, don't ever discontinue this frame.
    At long last, it is here. I just built up a bike based around the 2009 Dos Niner frame. Here's a parts list, I weighed it tonight and it's a ridiculous 24.4 lbs. Ridiculous because this is an XL 29er softtail frame with 185mm cranks! I wasn't really even trying to weight weenie it out, but 24 pounds is an ideal XC bike weight in my opinion.
    2009 XL Salsa Dos Niner Frame
    Stan's ZTR Arch 29er Rims, DT Swiss Spokes
    American Classic hubs, front 20mm thru-axle
    2009 Rock Shock Reba Team 29er 120mm 20mm maxle fork (adjusted to 100mm)
    Surly Mr. Whirly 185mm crankset 44-32-22 with external bottom bracket
    Schwalbe Racing Ralph 2.4" tires with Stan's tubeless
    Easton Monkeylite SL carbon handlebar
    Oury lock-on grips
    Avid Juicy Ultimate 160mm disc brakes
    USE Alien carbon seatpost
    Selle Italia SLR saddle
    XT front derailleur, XTR rear derailleur
    SRAM Attack 8-speed grip shifters
    SRAM 8-speed cassette and chain
    Token carbon bottle cage
    Race Face XC 70mm stem
    Crank Bros Eggbeaters 2 Ti pedals
    I'll upload photos soon.
    Dec 2004
    Wow, that is impressive for a XL frame. That Surly crank has to be pretty heavy too (although I'm just assuming). The Dos Niner is my fave bike for sure. Look forward to seeing the pics.
    Former XXC Mag publisher (re)turned amateur bike blogger at The Soiled Chamois.
    likes to ride bikes
    Thanks, here's photos.
    The handlebars look higher than the saddle in this pic, but they're actually slightly lower
    Carbon handlebars, seatpost, and SLR saddle compensate for weight gains in other areas. Having a little carbon flex in these areas is good too.
    The 185mm Surly Mr. Whirly cranks immediately impress. They weigh in with bottom bracket at 1020g but I wouldn't do without them.
    Through-axle Reba Team 120 set to 100mm travel is gracefully plush.
    The Salsa Dos Niner is all tatted up, even on the seatstays! Beefy 2.4s barely fit in the back against the flattened chainstays. Dialed in the Relish shock at about 15psi.
    i heart singletrack
    Reputation: mgersib's Avatar
    Wow... That's a great looking Dos. Congratulations and thanks for sharing!
    Cheers,
    MG
    I like bikes
    likes to ride bikes
    Thanks. I love the inked out, tatted-up look of the silver frame. I also want to go faster. I ride an offroad route to work every day. First day on the new bike, <a href="http://tunicatrails.org/?q=node/88">I broke my previous record by 18 seconds</a>.
    Hud
    Hud is offline
    Singletrack minded
    Reputation: Hud's Avatar
    Nice looking build! The white rims go nicely.
    I wonder if the colour for 2010 is going to change, not such a fan of silver, I like spicy colours.
    The twenty-nine inch wheel.
    likes to ride bikes
    I believe that the silver was chosen because paint chips easily on scandium frames. For me that's good since I intend to rail on this bike pretty hard. I suppose they could anodize it another color. I can tell you that the grey-on-silver graphics look cooler in person, like I said it looks like a full body tatoo on the Dos Niner
    After getting the right pressure, the Relish is doing its job and keeping my back from getting sore. I fell like I'm going to strengthen my back muscles because it's making me get off the saddle a little more than my previous bike. That's fine, because the Dos Niner feels completely under control. The 29er's wheelbase, or really, the length from longitudinal tip of the front wheel to the rear tip of the back is monstrous compared to my old Scalpel.
    hey ive got a stupid question, im not familier with this frame but am interested in this frame. anyway if this is a softtail frame how does the lower part of the frame pivot with suspension movement? i know it only has 1 inch of rear travel but how does this work? does the lower rear frame move down at the bottom bye the crank? i cant find any pics of just a dos 9er frame.
    likes to ride bikes
    Yes, it's an all scandium/aluminum alloy frame. The chainstays (tubes down by the chain) are flattened so that they're thin vertically but thick horizontally, meaning that it will flex up but not sideways. You can see it in the pics above. You'll read of other guys on MTBR that have raced a Dos Niner frame for years, it's a simple, tough design.
    With an all-metal frame I guess 1" is the most they can expect to get out of it. On a 29er this is good enough. It feels great on descents, climbing, and the pavement. I'm not going to tell you it's the same thing as a 3" full-suspension bike, but it's about 2 lbs lighter than most of those frames, and you don't have to worry about shock service, worn/broken linkages, or losing any power to suspension bob.
    Quote Originally Posted by roscoe1971
    thanks alot i did manage to find a pic of an 07 frame (paint on those were alot better LOL) and was able to see the down tube i talked to some local racers at a local bike shop and 2 of them use this frame and they both love it. they ride on med. frams and when i sat on it it felt alot bigger than other med. frames. but thease guys swear up and down on the salsa bikes so other than the silver wich i love and hate im starting to get pretty pumped on the salsa rides and may be building one this winter.
    i heart singletrack
    I've owned every version of the Dos Niner except the newest silver one (I ended up going with a Big Mama this season), but I still have my orange '07 frame, which is pictured in these photos. It's an awesome bike if you're looking for a frame that weighs just a bit more than a hardtail, but offers a much smoother ride. It's not a true full suspension bike, but as I've told many folks before, it's more like a hardtail with privileges. You can get away with stuff on a Dos that you'd never be able to get away with on a regular hardtail. It's pretty incredible -- just about the perfect 12 or 24 hour bike for a fit rider.
    Good luck!
    MG
    I like bikes
    likes to ride bikes
    What made you choose to go with the Big Mama for racing?
    Quote Originally Posted by mgersib
    Good luck!
    MG
    i heart singletrack
    Quote Originally Posted by TunicaTrails
    The desire to have more travel... and the fact that I already have a Dos Niner in the quiver. Now I have both bikes to be able to choose from!
    I like bikes
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Ok, just how tall are you that you're working the XL with 185 cranks?
    I don't post to generate business for myself or make like I'm better than sliced bread
    likes to ride bikes
    Glad you asked, I'm 6'4" with a 36-37" inseam. I should also mention that I have size 15 feet, which makes for a little more ecto-morphism I guess
    I'm looking at my Reba Team 120 and wondering whether by having the shop adjust the travel down to 100, the shock has compressed at all. I have no complaints about the geometry or pedal ground clearance so far.
    Quote Originally Posted by DeeEight
    I'm thinking the silver frame would look pretty sweet paired with all silver hardware. On the other hand, sometimes it looks real crappy when colors don't quite match.
    Thoughts?
    I just ordered a 20" myself (6'6, 36 inseam) and I'm going to be using 175 cranks (i run them on ALL my bikes, except for my singlespeed which is 180). I see no need to order the XL just for a fraction of an inch more of TT room right now, with a much greater increase in standover. Its taking over from a 17" GT Peace 9R multi i've been using. The parts are coming off the GT and going to the Salsa... parts like WTB Laserdisc lite on DT 7.1 rims with DT Revo 1.8/1.5 spokes and alloy nipples, same tires as you, DuraAce 9sp thumbies, Shimano XT Hollowtech Octalink cranks, 22/34/bashguard, 11-34 XT cassette, and so on. I just picked up an 09 Reba Race at cost+10% today, ordered the frame maybe 30 mins before that. I figure low 24 range will be easily achieved also. I'm just debating if i'll move the gold annodized headset over also... it would tend to clash with my silver/black/red colour scheme i have in mind.
    likes to ride bikes
    I felt robbed of sprinting and climbing power with 175s. I'm not sure why tall guys do that to themselves, small cranks and frames, but I suppose you have your reasons. I do ride a 58cm cyclocross bike with long stem and layback seatpost, which feels just fine.
    Most of what I've bought was measured in trying to get better performance in races. I have to say that the new Dos Niner looks like a monster truck next to my old Scalpel, but the long top tube and bigger wheel out in front is very much welcome, especially on really steep drops. I do like a small stem to make the handling as quick as possible against the other big elements.
    By the way, Racing Ralph 2.4s fit ok in dry conditions, with a tiny but of rub in hard corners at low psi. In mud though they clog up in front and back really quickly on this bike. I'll buy 2.2s or 2.3s next.
    Reputation: newking's Avatar
    Nov 2007
    wow, that first bike in the tread looks just like mine! Here is my 09 Dos 1x9 with 2010 Reba Race 120mm fork and some other goodies. Was not sure about the white / silver but it has grown on me.
    ok im 6"3 235lbs with a 34-35 inseam should i go large or extra large? if i recall this frame runs on the bigger side? i love that orange/red 07 dos!!!!! how long into the year would i have to wait to see the 2010 salsa line up? someone told me salsa wont have anything in 2010 line up until dec/jan.this could end up being a slow winter build up. man i havent built a bike since my hutch bmx back in the 80's it was pricey but i had a bad ass hutch racer. frame/fork is sitting in my basement.
    likes to ride bikes
    You have excellent taste, newking
    roscoe1971, you're only slightly shorter than me, go with the XL and get a short stem. You should have plenty of standover.
    The DosNiner shares the same back end for three of the frame sizes (21.3 inch seattube on the 16, 18 and 20" frames), so you're always going to be limited with how low the seatpost can go. Its DEFINITELY not a frame for short people, and even if the standover on the 16" isn't that bad, many folks will complain about the seatpost not being able to go low enough.
    The 20" has a 24.4" effective toptube and the 22" (which is really a 23.7" seattube) has a 25" effective toptube. The difference in standover is a bit over an inch though (at over 33" for the 22" frame). I'm riding a 24.1" effective toptube now with a 120mm stem on my current 29er. The 20" Dos will let me go to a 110mm stem and keep exactly the saddle to bar distance i like to use now (and the same as I have on my 20" beasley with a 130mm stem and most all my 26er bikes which tend to run 130 or 150mm stems depending on TT length). If I got the 22" Dos I'd have to go to a 95mm stem to be in the same position and well, that's not quite a common size for stems. Not to mention I already have a nice 120g titanium 110mm stem ready and waiting to go on it when the frame arrives, hopefully next week. In addition, even if I wanted a longer compartment, a 20mm longer stem is lighter than a 2" bigger frame size. The only reason at all for me to run a 25" toptube would be if I planned to use my Ti Jones bar on it, which I don't, as I haven't actually enjoyed it that much.
    another one....
    Selma being ordered tomorrow.
    2009 Dos Niner
    2009 Dos in size midget. Many thanks to Velomech in Boise!
    Space Ghost
    Reputation: Coach417's Avatar
    Quote Originally Posted by funboarder1971
    another one....
    That looks light. Nice build. Got a weight?
    "No good deed goes unpunished"
    No weight yet...I haven't picked it up from the shop. Will post the weight and a ride report as soon as I get the chance.
    My bad....Looks like you are looking for the weight on the previous post.
    Reputation: cackalacky's Avatar
    Welcome to the club, guys. Still lovin' mine:
    I've got a Reba Race on it now...
    No longer 26
    Reputation: G-Live's Avatar
    D8,
    At what travel are you going to run your fork on your Dos?
    Roscoe, I think a frame size that allows a stem length from 90-110 is just about perfect. Shorter or longer seems to me to say go to the next size up/down in frame size. Also, keep in mind that the longer the travel used on the fork, the shorter the effective top tube becomes given the same (your own preferred) saddle postion relative to bb.
    G
    You can't depend on honest answers from dependant hands...
    Reputation: Flat Ark's Avatar
    Quote Originally Posted by cchan999
    Your bike looks great! Do you have any more photos from different angles? Would like to see them. I'm currently riding a Mamasita but I am thinking of going back to a Dos. It's just ideal for about every XC situation.
    The 09s have the increased offset so I'm going to run it in the stock 100mm travel mode. I got my frame yesterday, today I'll build it.
    I can finally join the club...
    I just got my frame in about 30 minutes ago. Its an '07 I got off ebay, you probably saw it there. I'm waiting on a Reba, Cane Creek 110, and some bling to come in in the next week or so, then I'll get to building. Can't wait!
    I'm slowly assembling mine. I realized after I got the crankset installed and stepped back to look at it again, that I despise how they did the cable housing stops on the toptube for the brake cable. An open loop ? Really? How cheap. With no way to position a zip-tie or clip to hold the housing in place cleanly.
    must be a mid-year change. mine has the standard brake hose mounts (for zip ties or clips).
    Not a change for the better IMHO.
    Just built mine yesterday and have already experienced the most severe chainsuck EVER in twenty years of mountain biking and probably a hundred different bikes. I've never had it take ten mins to extract the chain before. Also the remote lockout on my Reba broke (while locked) and I had to pop the cable out to get the thing to open again while on the ride. I'll post it into my own thread later today when I have more time but for now, 25.2 pounds as pictured (but since I've yanked the remote lockout, its down to a couple ounces already), Large size, and those are also the 2.4 RRs. I will say to the OP, I'm getting tire lug buzzing noises under power... how about you? I'm thinking of switching to the 2.25 in the back at least.
    <img src="http://yoda.densan.ca/kmr/bikes/dos1.jpg">
    <img src="http://yoda.densan.ca/kmr/bikes/dos7.jpg">
    <img src="http://yoda.densan.ca/kmr/bikes/dos8.jpg">
    <img src="http://yoda.densan.ca/kmr/bikes/dos9.jpg">
    Space Ghost
    DeeEight...I'd be interested in your thoughts on the Dos overall. Expectations and reality kind of thing. I am acquiring parts to build up a HT (or softtail) and the Dos is near the top. Thanks.
    I expected a better ride (then again I was coming from fully rigid chromoly) than my GT Peace 9R and a good weight reduction at the same time. I achieved that. Hell the frame alone was lighter by more than the suspension fork was heavier. There IS some frame flex laterally in the rear end though, which has resulted in buzzing the RR 2.4 (granted they only claim clearance for up to a 2.3 in the specs) against the inside of the stays whenever I lean the bike and the softtail suspension cycles (which means really, ALL the time when powering up a hill or sprinting). You certainly don't want to run the same tire if you're not gonna keep up on wheel trueness, there's no margin for error with a warped rim here.
    So far i'm enjoying it otherwise but I need to find my sweet spot in body position on it still. It certainly steers better than I expected but that could be the new Reba's increased fork offset. A few times yesterday on an XC course that's of World Cup level I found myself having to negotiate some really tight switchbacks and it was necessary to go to the outside a bit more than I usually do on say, my Beasley, but I never really found myself falling off the track into the trees. It does afterall also have the longest wheelbase of any of my bikes, even longer (by about 20mm) than the GT. I'm also still trying to find the perfect tire pressure for sealant tubeless. I ran 23F/25R yesterday and got some rather loud noises smacking rocks, but no burping fortunetly.
    likes to ride bikes
    You're right, the Racing Ralph 2.4s are not a good match for the rear of a Dos Niner. I asked my LBS to order them, realized my error, and tried to change to a 2.2 rear after they'd already been ordered, but I just went with them when they came in. Under most conditions I think they give a luxurious ride, the buoyancy works well with the softtail frame.
    It hasn't been a big problem for me at 180lbs and 30 psi, but I have considered trimming the knobs.
    I was going to attribute the rub as much to flex of the tire casing instead of the rear triangle, but I could be wrong. Dos Niner frames apparently support bigger tires than they used to, but the RR 2.4 is just a really big tire. It's considerably bigger than a WTB Werewolf LT 2.55:
    http://mtbtires.com/site2/tech/38-ge...dth-comparison
    It spins fine in the stand or upright on pavement... take it off-pavement (so the softtail starts flexing) or lean the bike and bzzzzzzzzzz goes the side knobs. Its not as bad as my Peace did before I aligned its dropouts but still... annoying (especially since the peace clears them fine). More so since the beads sealed fine and tight with the stans sealant and now I have to break it free and setup a different (smaller) tire.
    Reputation: Mattyd's Avatar
    Dec 2005
    Rockin' an 05
    Have had this frame for quite a while and it is still kickin' it. Yes, the tire clearance was tight on the original frames, but I haven't had an issue in the AZ dry dirt.
    Agree, this is the perfect XC race machine, especially on a 24 hr. course.
    Go make a difference
    Reputation: k2biker's Avatar
    Here's mine suited up for winter riding in Pisgah National Forest, NC. Love love love it! Have been on one since '07 and have done several enduro races on it. I've been training for a hundy that's this weekend on my SS WaltWorks and got on my Dos Tuesday night for a ride and it felt like a little speed racer! Can't wait for Saturday!
    Charles Myrick
    33North Adventures | Owner
    Bike | Climb | Hike | Paddle
    New trips: Tibet & Bosnia!
    likes to ride bikes
    OK I trimmed my rear knobs last night in preparation for a race that might be muddy, problem solved. Good thing I did, because the beginnings of an indentation had occurred on my left chainstay. I used an angle grinder, what a mess of powdered rubber. I had a new Kenda Nevegal 2.2 that I could have put on, but its large knobs make the tread width just about the same as the RR 2.4s. http://mtbtires.com/site2/tech/38-ge...dth-comparison
    Quote Originally Posted by newking
    That bike looks great!! How's the bike handle with 120mm up front?
    Reputation: goneskiian's Avatar
    Sep 2004
    Here's my '06 that I build up in February of that year. Seems like it was only yesterday. Changes from these pictures include flipping the stem over and a cushier saddle.
    I've actually be thinking about selling it and getting something with more travel, then I come read other's enthusiasm for the Dos and I start to waver.
    Have there been any changes to the Dos other than the color in it's lifetime? Sounds like they gave it more tire clearance at one point?
    Build highlights:
    180mm cranks
    Marta SL brakes
    Easton carbon post
    Mikesee built DT240/Delgado Disc wheels with his signature "puke" spoke nipple color scheme
    If I remember correctly, this build is right about 25.6 lbs.
    Cheers!
    -Ian
    Sep 2004
    Quote Originally Posted by goneskiian
    Nevermind. I found the thread that talks about the year to year differences.
    LINKY for those with the same question I had.
    Cheers!
    Sep 2004
    My apologies for the reposting of pictures. I'd completely forgotten I made a complete thread for my dos when I first got it.
    likes to ride bikes
    No problem
    I virtually locked out the rear shock at a race recently by putting 55psi in it and realized how much I missed it by the end of the race. It helps my back so much on all the little things like roots and rollers.
    Nice bike! Do you have that reba set at 80mm? I think mine is at 100mm but not completely sure as I bought it used. Don't sell it, you'll regret it later!
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Here's mine. Love the bike with the right parts. Get too many flexy bits on there and it goes in two different directions at once.
    Still tweaking mine out. It's a work in progress.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    I mounted a RR 2.25, which is really actually a 2.15" tread width and 2.1 in casing. Again it solved the problems without needing to degrade the edge knobs of a perfectly good tire, which is going back onto my GT Peace (which is now a loaner bike). The RR 2.25 was harder to seat tubeless though, had to use my compressor instead of the floor pump as with the 2.4. If I'd known ahead of time though that the Evo casing 2.25 was skinnier than claimed, I might have shaved the knobs anyway. I hate giving up casing volume.
    likes to ride bikes
    I can report that a Kenda Nevegal 2.2 fits just fine with no rub. My new rear hub died recently and is being warrantied for new pawls (beware American Classic?). So I've got the rear wheel of my piggish backup wheelset on now.
    It had been reported that the tread width of a 2.2 Nevegal was nearly that of a Racing Ralph 2.4. It appears to me to be noticeably smaller, and of course the casing is smaller..
    No real downside to shaving the 2.4s, if you love big casing volume, other than the hassle.
    Reputation: CaptainCalf's Avatar
    I'm looking to join you fellas cuz you're havin way too much fun...
    I've been doing all my racing on my all mountain Titus Switchblade Talus, which has to be around 28 lbs, so I'm looking forward to seeing what this baby will do in a 12 hour race!
    I'll post up some pics when I find the frame...RC
    09 Salsa Mamasita
    09 Specialized Tarmac Comp
    Honda VTR1000 Superhawk
    Stone's Arrogant Bastard on tap
    Decisions, decision?
    Ok guys, the more I read/study, the more I like the Dos Niner........
    I should have enough parts lying around to build up the Salsa (sans 80mm fork), but I've got a rigid salsa cromoto 29er fork that needs to be put to good use. Do I get the Dos Niner and build up (temporarily) with the rigid (most likely as a SS) until I can convince/bribe the CFO of the house of a 80mm fork (suggestions?) at a later date,or would I be better off with the Mariachi? Any advice would be humbly appreciated
    What's amusing to me is that the 2007 DosNiner frame was listed as having clearance for 2.5" wide tires. I wonder if they re-did the chainstays on the frame in the last couple model years and took away tire clearance in the process.
    likes to ride bikes
    While I agree with you that the buoyancy of Racing Ralph 2.4s mates very well with this frame, I can't find any evidence that Salsa spec'ed tires that wide on this bike. All I've ever seen officially is 2.3", although plenty of online stores get it incorrect. I remember reading that, especially in the smaller sizes, the first-edition Dos Niners didn't really even support 2.3s
    2007: http://www.salsacycles.com/dosniner.html
    2008: http://www.salsacycles.com/archive/dosniner08.html
    2009: http://www.salsacycles.com/dosniner09.html
    Most 2.5s tend towards All-Mountain with a beefy tread, which is probably beyond what most riders would want this bike for. It might be Big Mama time for you
    Has anyone tried the Dos as a Single speed????
    I want to make the jump from 26 to 29er mostly due to my height/inseam and ill fitted bikes. Currently I'm enjoying the less maintenance of riding SS but with my 26er I use a Thudbuster. Would a 29er dos SS be comparable to running the Thudbuster on a 26er hardtail?
    Unless they based it off the WTB 2.55s which are really 2.3s.
    likes to ride bikes
    I know a SS rigid rider who's got a Dos Niner, although he doesn't ride it often. I used a Rock Shox suspension post years ago. I can only make a comparison to that product, and my feeling was that a suspension seatpost bobs with every pedal stroke. A Dos Niner softtail doesn't do that noticably if you've got the right pressure set up.
    Quote Originally Posted by TaylorMade
    just ride
    Reputation: chequamagon's Avatar
    That seems to be an incorrect clearance..... The earlier models (light green) had tire clearance for maybe around a 2.1, and subsequent models were improved to get better tire clearance. The current silver one we rate as having clearance for up to a 2.3.
    Ride and Smile,
    Tim, Salsa Cycles
    Steel is Real: www.advocatecycles.com
    Tires for real rides: www.terrenetires.com
    hey, i'm quoting your former canadian distributor who's going off the literature Salsa provided him at the time. I just got a pair of 2007 Las Cruces framesets brand new for $880USD w/shipping. I almost got the last DosNiner he had listed but for the fact none of your 16" 29ers actually have much in the way of standover room for people who actually need 16" frames.
    This is what he's listing as specs...
    Dos Niner Orange
    Disc and canti compatible.
    Salsa scandium size-specific, custom drawn tubeset with Salsa Relish Air rear shock
    ISO 51mm disc mounts
    Fits up to a 29 x 2.5" tire
    Seatpost clamp: 30.6mm (Salsa Flip-Lock included)
    Frame weight: 4.1 lbs. 18" with Relish Air shock
    Geometry sheet available upon request.
    Color: Orange
    Seatpost Diameter: 27.2 mm
    Headset Type: 1-1/8" Standard Cups
    Fork Travel: 75 - 85 mm
    Front Derailleur Style: Traditional/Topswing
    Front Derailleur Cable Pull: Bottom
    Front Derailleur Clamp: 35.0mm (1-3/8")
    Mount Type: BB Cup Mount
    BB Thread Type: English
    BB Shell Width: 68 mm
    Disc Mount Type: 51mm I.S. Rear
    Brake Type: Disc/Linear Pull - Canti
    Brake Usage F/R: Rear
    Material: Scandium
    Wheel Mount Center Offset: 0 mm
    Rear Axle Type: 10x1
    Rear Hub Spacing: 135 mm
    Wheel Size: 700c
    Weight: 1,859.0 g
    just ride
    Dos Niner Orange
    Ah, yes, definetely an error in some communication, as the orange frame never had V brake mounts either. Like you said before, maybe the 2.5 they were thinking was the WeirWolf LT........
    Ride and Smile,
    Tim, Salsa Cycles
    Yeah I measured a set of those weirwolfs on a el-m, they weren't even 2.4s mounted on the delgardo rims. The Continental Mountain King 2.4 is however 2.4 at the tread, and 2.1 in casing, mounted on ZTR Arch's. Shop I got my dos thru is building up an 18" dos as a 'rental / demo' bike and was originally planning the 2.4 tire for the rear till i pointed out the lack of paint on my chainstay issue (I switched to the RR 2.25 before it polished/grooved the stays).
    One comment after a ride lastnight with a LOT of pedal whacks... the BB height needs to be higher... the selma is 3mm higher and it doesn't lower its BB as the rear end travels upwards 1"...
    just ride
    Thanks Dos Fans!
    Thanks for all the good words and pictures Dos Niner fans!!! It has been one of our iconic models for our brand.
    Tell me, what is it that attracted you to the Dos? The nice light weight? The simplicity? Or its stunning good looks?
    Tell me your story, I am interested to hear from you.
    Ride and Smile,
    Tim, Bike and Frame Product Manager, Salsa Cycles
    likes to ride bikes
    New saddle, I liked the ideas of matching white from the previous posters. Also new 100mm carbon stem. 70mm was what I had initially and felt very confident on some super steep descents, but I couldn't weight the front wheel enough to rail corners. Also switched to 2x8 with a 36t ring.
    Although it's twice the weight, the Selle Italia XO Trans Am Ltd Edition is much better for all day rides than the SLR. I hope to move into endurance racing next year.
    To answer chequamagon, this is my first 29er. I was set to buy a full-suspension bike but I made a last-minute decision that the weight was too much with the current crop. I couldn't bring myself to go hardtail since I tend to get a sore back. The Dos Niner is extremely lightweight for a 29er with rear suspension and I'm just loving it. A 2" model would completely rock but the simplicity of the pivotless all-scandium design would be hard to forgo.
    As mentioned above I ride 185mm cranks and BB height might help a bit with pedal strikes but I can recall only one trail where that was a problem. It had whoopy ups with lips on them due to red clay erosion. If I didn't get enough momentum I'd have to crank it at the top and sometimes dab a crank. Not really a big deal and I'd rather have the low center of gravity the rest of the ride.
    I love the "all tatted up" look of the Dos Niner graphics; silver is a little more mature than the hot orange, although it is exciting-looking. I understand that scandium has paint flaking problems which is why the current color was chosen?
    I'm sitting here, thinking about how I'm going to build my Dos up over the winter. For some reason, it's begging to be set up for gravel grinders w drop bars and a 2x9. Guess I'm sick in that way...
  67. #67
    Wow, I have to admit the silver and white color combos are making me want a Dos really bad.
    I was hoping someone could give me some thoughts on what size frmae and what travel fork - I am 6'4 with a 37 in-seam and would use the bike as an XC race bike.
    I am thinking the XL frame size and an 80 mm reba team? I like the idea of having a 25 inch top tube so the XL seems ideal.
    Also, for the taller riders (you will understand this question better) I have yet to find a bike that I do not feel like I am sitting on top of - I am looking for a bike that will feel like I am actually sitting inside the cockpit. If this makes sense do taller Dos riders feel that you are actually inside the cockpit instead of perched high atop it?
    How does the bike handle and how does the center of gravity feel?
  68. #68
    Well last night's ride, same trail where I discovered the lack of BB height... three of us on 29ers (niner air-9, niner jet-9, my dos niner) and the fourth on 26" fully, and everyone on 29 inch wheels smacked pedals, so maybe its not simply the dos with the low BB height. It seems to be a problem common to the genre. Designers over-lowering the BB heights to make up for the taller wheels. The guy who had a 26er has said he's experienced the same problem on that trail riding his partner's Karate Monkey.
  69. #69
    likes to ride bikes
    You and I must be the same size. I ride an XL. There is plenty of space between my knees and the handlebar in that size. The bike feels very stable to me. If you have the chance you could try a size L if you like it flickable, but the XL feels very good, very much in control.
    I'm a little sluggish in tight turns with the big bike frame and 100mm fork, but on low speed technical stuff, my balance is much better on the big bike, so dabs are much less frequent.
    I don't know if this will be your first 29er or not, but if you're riding 26" currently, a 29er is a must-have for tall guys. The feeling of teetering above the wheels is greatly, greatly reduced.
    If a Dos won't be your first 29er, I don't know what to tell you other than I understand. Regardless of the bike, the optimum saddle height will be the same. I'm just working really hard to rail corners better but the lil' problem with endos I had on my 26" FS bike is gone
    Quote Originally Posted by XC23
  70. #70
    THis will be my first 29er - I currently ride 26 FS which I enjoy. BUt I have always felt that I am to big for all of my bikes and that I am teetering on top as opposed to sitting in the bike. I am looking at a three 29ers currently including the Dos Niner, the Niner Air9 and the Cannondale Flash 29er 1 Alloy. I kind of like the idea of just getting a frame and building my own bike.
    How noticeable is the softtail on the Dos Niner - I am concerned about going back to a hardtail and think that a softtail might really take the edge off. BUT at the same time I want the pedaling efficienct of a hardtail and am concerned that the Dos might bob a little.
  71. #71
    I've yet to notice it without actually looking at the shock. Course it was trial and error to hit the pressure setting right. I wish my shock pump's gauge was digital but best guess is 31psi.
  72. #72
    likes to ride bikes
    The Dos Niner's Relish combined with the bigger wheels gives it a "virtual travel" feeling of a 3" 26er. The progressive feeling of the scandium stays is very healthy; bottoming out is something you don't feel. Bob is easily alleviated with the right pressure settings; I'm at about 20psi now and I weigh 180lbs; that's on the plush side.
    If I were getting the Flash 29er I'd go for carbon but that's just me. Don't forget to get you some light wheels, something in the <1800 gram range, preferably running tubeless. It'll make a big difference in how the new bike treats you.
  73. #73
    I had that problem with my Dos Niner until I reworked my fork to 100mm. I'll never go back. I don't know why 80mm is spec'ed. Handling and clearance both seem better with 100mm.
    DR
  74. #74
    I'm already running my fork at 100mm though and its pedal strike prone. Another 20mm of fork travel only lifts the BB about 5mm higher.
  75. #75
    likes to ride bikes
    My road/cross bike is in the shop, so I just rode my Dos Niner on a 78 mile road ride!
    The pace wasn't killer, about 17mph but through the hills. I pumped up the tubeless tires to 50psi and locked out the front and rear. The big 2.4s performed as well as could be expected.
  76. #76
    Dec 2004
    wow...that's exactly how I felt on my old mtn bike
    You said "I have yet to find a bike that I do not feel like I am sitting on top of - I am looking for a bike that will feel like I am actually sitting inside the cockpit. If this makes sense do taller Dos riders feel that you are actually inside the cockpit instead of perched high atop it? "
    This is almost word for word as to what I told my buddy after getting my dos niner two weeks ago.
    I'm 6'3" with long longs and arms...I've always ridden 26" Large size steel hardtails...that have never fit right. Picture a 400mm seat post nearly maxed out.
    Anyway I went with an XL with a 100mm stem and I'm so glad that I did. I've never, never even close felt so balanced and comfortable...especially when descending...I'm thrilled!
    ~matt
  77. #77
    Dec 2004
    ~matt
  78. #78
    Sep 2004
    Quote Originally Posted by cackalacky
    Thanks! Sorry for not checking back sooner. The fork is set at 80mm. Seems to be plenty for me but I'd like to try something with 100mm at some point.
    I may regret selling it but have to make room in the stable for something new. Look for it on Ebay or here on the classifieds soon. Will likely part it out.
    Cheers!
  79. #79
    Reputation: AK47's Avatar
    What I like about my Dos...
    Tim, I have several things that attracted me to and what I continue to like about my Dos Niner:
    • Lightweight
    • Soft-tail design would take the edge off the rough stuff
    • Good looks
    It definitely met my expectations above! Here is what I continue to like about it:
    • Fast bike
    • Doesn't bob, even when out of the saddle
    • Makes longer rides more comfortable
    • Geometry fits me great
    • Simplicity of a hardtail but with some of the benefits of full suspension
  80. #80
    Reputation: swampfox's Avatar
    my dos in 2007
  81. #81
    Nov 2006
    just finished my new salsa dos niner build. actually only the grips are new, i got a used '08 frame because of the nice color and build it up with existing components. i liked the build and ended up putting nicer and nicer components ...
    this will be my back up trail bike, therefore TA and just 1x9 gearing. weighs about 23lbs, so it may see some endurance racing as well.
    and it will make my waiting for the tang air9 carbon lots easier
  82. #82
    In here is mine...in French
    ://img94.imageshack.us/img94/7772/p1020376d.jpg
  83. #83
    Reputation: dubjay's Avatar
    Here's my 2009 Dos with a mix of XTR/XT parts. Weighs a smidge over 24 lbs right now.
    I'm still playing with air pressure. I weigh ~165 and I currently have about 15psi in the shock. How far down should the o-ring go at full travel?
  84. #84
    <a href="http://www.flickr.com/photos/zenbiking/4143356035/" title="Salsa Dos Niner frame by S.Fuller, on Flickr"><img src="http://farm3.static.flickr.com/2658/4143356035_82fd3332d4.jpg" width="500" height="363" alt="Salsa Dos Niner frame" /></a>
    All I've got right now is a really nice piece of art for my desk in the basement. Not sure if I'll build it up to match my La Cruz in color scheme, or do something different. Looking forward to actually riding it come spring.
  85. #85
    likes to ride bikes
    My Dos Niner has been a real winner for me this year.
    Hey can someone give me the clamp size for the front derailleur? Looking at a roadie model for my 2 chainrings, for less mud grabbing and lighter weight than XT.
  86. #86
    35mm
  87. #87
    likes to ride bikes
    I'm lazy for not finding out myself, but 34.9mm it is. I'd bet that 35mm would work just fine.
  88. #88
    Quote Originally Posted by dubjay
    I wanna say that I read from Salsa that you should actually bottom the shock out a couple of times each ride (depending on terrain of course)otherwise you are not using the shocks full 1" of travel. I am about your weight and I ran mine at "0" psi. Many others do the same.
  89. #89
    Quote Originally Posted by Flat Ark
    I'm around 165 lbs. and never run mine over 5psi...
    Nice bike btw!
    Like the silver. Are you running an 80 mm fork?
  90. #90
    Reputation: Destin's Avatar
    Jan 2009
    So you cut the setpost down. problem solved
  91. #91
    likes to ride bikes
    geometry
    Anyone riding/racing a size smaller than advisable with a longer stem and/or layback seatpost?
    I'm a pretty tall guy, 6'4", 36" inseam, long arms, big feet. This was my first 29er and as I race it more and get more demanding of the bike, I have been making minor tweaks to my position on the XL frame.
    The first thing I noticed coming from a 26" is how much more wheel is sticking out front on a 29er. That was very much welcome, I could take big descents with much more confidence.
    As I learned to rail corners I found the 70mm stem had me too far back and I switched to 100mm. That made the cockpit feel too lengthy and I slid the seat forward. Now I'm feeling the need to weight the front even more and noticing the slightly sluggish turning with a big wheelbase on tight switchbacks.
    I've been studying the measurements between the Dos Niner XL and L, here are the differences:
    Seat Tube: 23.76" XL, 21.35" L, difference= 2.41"
    Top Tube C-C: 24.06" XL, 23.36" L, difference = 0.7"
    Top Tube (Horiz): 24.46" L, 25.0" XL, difference =0.54"
    Head Tube: 3.9" L, 4.3" XL, difference = 0.4"
    Front-Center: 26.0" L, 26.7" XL, difference = 0.7"
    Standover: 32.38" L, 33.48" XL, difference = 1.1"
    The only significantly negative difference I see is in seat tube length; I may have to buy a longer seatpost. The Head tube difference of 0.4" is somewhat annoying since the XL's is pretty short to begin with. The >3/4 inch of difference in top tube might be just perfect.
    Complicating this decision is the fact that I favor my 120mm maxle Reba. Plushed out with lowered psi, it still gives me excellent clearance for the 185mm Surly cranks that I swear by. I think a shorter wheelbase could compensate for the slower turning angle that this fork gives me.
    Thoughts or experiences? If anybody has an offer to make in trade, PM me.
  92. #92
    I don't have this anymore but I came across this photo in my computer and just figured that I would post it up for the sake of the thread.
  93. #93
    I am new to the Dos Niner thing. Can anyone comment on out of the saddle hammering? Does it feel like a hardtail when standing and pedaling to accelerate for small jumps? Thanks for any help. Looking to buy a medium soon..
    Oh also, I want to set up as a SS andy thoughts?
  94. #94
    Feels just like a HT out of the saddle IMO. As for setting it up SS, others have done it successfully.
  95. #95
    Always Learning
    Reputation: BruceBrown's Avatar
    You are a tad beyond the "tweener" spot [6'2" - 6'3"] that could probably make a size L work. You firmly land in the size XL category and that's usually where I go as well in spite of testing and trying to make a size L fit before.
    I'm pretty much the same dimensions as you (long legs and arms, but a hair under 6'4" (I'm 191.5cm) and a hair under 36" inseam (35.75") using the bare foot on the floor to top of book in the crotch measurement) and comfortably ride the 2006 XL Dos with a 5 degree 90mm stem (sometimes I flip it down and sometimes not). But I ride and race it with my older generation Reba Race set at 80mm. I've yet to try my Reba at 100 on the Dos, but I like the quickness of the 80mm for XC racing. 180mm cranks.
    Maybe your fork at 120mm, with your seat slid forward and perhaps too long of a stem compromises your turning/handling and is the underlying reason you are contemplating swapping frame sizes. I think for your size, dropping to the size L is going to end in a bad fit filled with band-aids. That's my opinion of course - totally based on being the same size as you. Okay, my feet are not size 15, but my son's are. ;-]
    Why did you jump all the way from a 70mm stem to a 100mm stem? I guess if you had a 17 degree sweep handlebar you would be okay with 100 - 110mm stem, but I bet there is a sweet spot waiting for you in there around 90mm stem length. I've tried 85mm, 90, 100, 105, 110 all with various angles and a half dozen handlebars thanks to my parts bin and other bikes in the garage. That's all part of the natural tweaking phase one goes through as they get used to a bike and look for handling improvements.
    I would not be so quick to trade out to a smaller frame size. All the plumbing (bars, stem, spacers, etc...) might get even more crazy with the smaller size L frame and lead to utter frustration. Heck, the Dos Niner - as well as the XL Karate Monkey - both have one of the shortest ETT's for the size XL's out there in 29"er land compared to other brands (ditto for the Dos and KM's wheelbase - short). My Sugar 293's ETT is 1/2 longer and my JET and RIP are also longer in XL than the Dos (both ETT and wheelbase). What does the ETT mean stem wise if you dropped down to the smaller sized L frame? 1/2" = 12.7mm so in addition to more seatpost, you'll need a longer stem and/or more layback on the seatpost. And more spacers, stem/bar rise to deal with the even shorter head tube length. I think you are on the correctly sized bike.....
    My XL in 23.x lbs. with flipped 90mm stem and very little sweep bar race kit:
    <a href="http://www.flickr.com/photos/7166535@N05/4085993147/" title="RaceLightDos by singingsingletracker, on Flickr"><img src="http://farm3.static.flickr.com/2755/4085993147_c10f89a218_b.jpg" width="1024" height="768" alt="RaceLightDos" /></a>
    And here she is in flipped up 100mm stem and bar with more sweep formation:
    <a href="http://www.flickr.com/photos/7166535@N05/3756060691/" title="DosNinerConAspens by singingsingletracker, on Flickr"><img src="http://farm4.static.flickr.com/3424/3756060691_a631a1b932_b.jpg" width="1024" height="768" alt="DosNinerConAspens" /></a>
    Since your Dos is still pretty new to you, I'd say keep fiddling and tweaking the fit with proper stem length, saddle position and fork travel until you find your sweet spot. I'll be riding my 5th XC race season this year on the Dos and it took a season or two to dial in the sweet spot and really get comfortable on the bike. Even then, I still like to play with bar height, stem length, stem angle all the time just for the heck of it. I run narrow bars with very little bend in them for tight and twisty courses and sometimes run the Salsa 17 degree bend bar with longer stem for other courses and training. It all depends.
    BB
  96. #96
    Okay, how about the seating position is it more relaxed or are you bent over like a true cross country race position? Thanks again
  97. #97
    Always Learning
    Quote Originally Posted by Forest72
    Are you looking for a more relaxed position on the bike or to be more bent over on the bike?
    I can do both (as well as everything inbetween) on my bike depending on number of spacers, stem rise, bar rise, etc... combinations. The headtube is short (too short IMO for those of us riding the XL) and with an 80mm fork - one can get a huge saddle to bar drop if desired. Or one can add plumbing to get things adjusted (see my photos above in this thread) up enough. I run with about a 1 - 2" saddle to bar drop before accounting for sag. And if the HT is not too short for riders in all sizes of the Dos, one can run a negative stem to get lower if so desired.
    I run it most of the time with a little drop and pretty narrow flat bars with little bend, but as you can see by the amount of spacers I use - there is plenty of room for an extreme drop.
    Using the 2 pictures from above again to show examples, I get in a good position on climbs with this set-up:
    <a href="http://www.flickr.com/photos/7166535@N05/2855502145/" title="BBDiggingDeep by singingsingletracker, on Flickr"><img src="http://farm4.static.flickr.com/3045/2855502145_0937c1d807_o.jpg" width="368" height="550" alt="BBDiggingDeep" /></a>
    And out of saddle is easy to use for those power up grunt climbs...
    <a href="http://www.flickr.com/photos/7166535@N05/2614555172/" title="GrindingUp by singingsingletracker, on Flickr"><img src="http://farm4.static.flickr.com/3117/2614555172_50b54397cc_o.jpg" width="533" height="800" alt="GrindingUp" /></a>
    My more "all mountain" position that is more upright using the higher rise stem and Salsa 17 degree bend bar gets me closer to level between bar and saddle before sag:
    However, that forces me to really bend the arms and tuck on the climbs:
    <a href="http://www.flickr.com/photos/7166535@N05/3898370707/" title="ClimbingLakeside by singingsingletracker, on Flickr"><img src="http://farm3.static.flickr.com/2520/3898370707_be6c5fd55f_b.jpg" width="1024" height="768" alt="ClimbingLakeside" /></a>
    <a href="http://www.flickr.com/photos/7166535@N05/3837346042/" title="Border Battle Opening Climb by singingsingletracker, on Flickr"><img src="http://farm4.static.flickr.com/3483/3837346042_038bbd11d5_b.jpg" width="1024" height="768" alt="Border Battle Opening Climb" /></a>
    So that set-up using the higher rise stem and severe bend bar doesn't get used as often for my racing. But it sure is comfy for training and longer efforts - or races that I want a little more upright and comfy position on for whatever reason.
    You can dial it in however you want is what I'm saying. Spacers, stems, bars and any combination of them allows you to be way below saddle, just a bit below, even with or if one wanted to even be above the saddle. Mix and match. Accessorize!!
    BB
  98. #98
    Thanks for all of the great info. I actually want the bar at or above the saddle height to give me more of the relaxed positioning because of my lower back. From the pics it looks like this will be impossible on the dos niner.
    Thanks again
  99. #99
    Always Learning
    Thanks again
    Not true. Did you read my post above and see the pictures? You can easily get the bar at or above saddle level (providing you don't hack off too much of the steerer tube on your fork so that no amount of spacers, stem angle and riser bar would get you at or above saddle level). Heck, run it with a 100mm suspension fork and you'd be there in a New York minute!
    And look at all the pictures in these two Dos Niner threads you are posting on. Lots of Dos Niners with the bars above the saddle.
    BB
  100. #100
    okay, this will be the new 09 so the steere tube (Reba SL) will still be in tact. It looked like the pics showed the bars below the saddle but I will take your word for it and also upgrade that Reba to the 100mm. Thanks again for the help!
