Results 1 to 42 of 42
    Oct 2011
    No good Cracked Spearfish Chainstay
    Well, I'm joining the ranks of those with cracked non driveside chainstays. Just wanted to give a little insight into my ordeal.
    I was going over my bike last Friday and noticed a crack going halfway through my chainstay, close to the bottom bracket. I've heard of this happening to a few folks lately, but I'm 150lbs, 5'9", so I didn't really think I'd fall victim as well.
    Anyway, I got ahold of Salsa. Their customer service guy, Zach, was actually really awesome and helpful. He and I exchanged a series of Emails over one day trying to figure out the best course of action. I bought the frame in new condition a couple years ago.. but it was technically second hand. So I didn't have a receipt. No warranty coverage - Okay, I can understand that.
    The biggest bummer is that they don't have any triangles left for the Spearfish 2 / 3. Only the Spearfish 1, which is a 142 x 12 thru axle. Kind of a bummer if you have a Formula hub. Fortunately, I have Stans hubs, which can be converted for ~$50. But the cost for the triangle, sans warranty: $380! Without that Maxle! And I'm pretty sure Zach even helped with getting the price down a bit.
    Anyway, to replace Salsa's crappy rear triangle design with another crappy rear triangle design is going to cost $500 with labor. Honestly, I'm just concerned about it breaking again. This issue isn't going to go away, and they're moving to a different design, presumably because they realize how shitty their "low maintenance" / "innovative" rear triangle was.
    I'm going to get my bike back together, working with the new triangle and put it up for sale and buy a real full suspension.
    From above:
    From below:
    On your left.
    That really sucks. The Spearfish is a great idea in need of better execution, but don't forget Salsa is a budget bike. The failure is clearly in the heat affected zone of the weld, so maybe it's a technique / QC issue, not necessarily design issue. The 2 axle types was really a strange marketing idea. They should've just offered interchangeable dropouts.
    We'll see if 2014 is better.
    M
    Ride good on the internet
    Quote Originally Posted by brdpkns View Post
    Interesting. Where did you hear that? A bit of a stretch if you ask me.
    Also, you can't swap the triangle yourself? There is pivot torque and bearing info on the salsa site. It's like two bolts to remove if the frame is already stripped down. Took me less than 10 minutes to pull off when I replaced my bearings. Far from rocket science.
    Also, are your surprised that the rear triangle is that much? Seems a little steep, but then again, it is half the bike, basically.
    Reputation: CYCLEJCE's Avatar
    I think your disappointment is misplaced. Are you upset with Salsa for offering you great communication, and a discounted fix? Or are you upset that you purchased a second hand bike with out a warranty? Bad design or not, it appears Salsa is doing what they can to make these issues right for customers who wanted a warranty and thus bought new, and unfortunate souls like yourself who were not concerned with having a warranty. Just my .02
    This may sound nutty but..can you bring the rear triangle to a welder/fabricator and just get the crack repaired? Then maybe get that part powdercoated afterwards. I would think that would cost way less than $500. You have no warranty anyways.
    Salsa El Mariachi SS
    Salsa Vaya
    Lurch Fatbike
    On your left.
    Or get a discount on a new '14 model? If they offer you that - I'll buy the new frame from you - then you'll have ~$1000 and can go buy the frame you want. I need size XL.
    In any case you should replace the whole frame and resell it as new - which it is.
    M
    funny that someone would complain about a used frame and the customer support that goes with it i bought my spearfish and horsethief new and when i "broke"my horsethief (it actually had a creak i couldnt find) salsa sent me a new one in a matter of days.i bought new frames and got everything that goes along with that
    ^man, that makes too much sense.
    The OP has not commented again either. Weird.
    Oct 2011
    Quote Originally Posted by fast540 View Post
    From my original post: "No warranty coverage - Okay, I can understand that." Also said that their customer support was great, if you would actually read what I wrote.
    I'm bummed at the design flaw and how fragile these frames are turning out to be. I didn't expect warranty. Take it down a notch.
    I got my new triangle on the bike. Took it out for a spin and seems to be riding great. ($500 later)
    I would also like to point out that you also said:
    "they're moving to a different design, presumably because they realize how shitty their "low maintenance" / "innovative" rear triangle was"
    Any actual facts to back any of those theories up?
    At this point, based on how these bikes ride on the internet: I'm basically going to get a crack in my frame and die tomorrow when I go for a ride.
    I have a living will, and an ID bracelet. FEAR NOT, I'll be safe.
    Oct 2011
    You seem super smart, so you're right -- My bad for letting other folks know I am not as pleased with Salsa's frame construction as I had hoped.
    HARK!
    Again, you dodge the Questions.
    Also, the use of the word "ordeal" in your first post cracked me up.
    *****ing about a cracked 29" full sus-frame on the internet you bought used is, like, the most first-world problem ever.
    I broke about $250 of shit today doing something dumb on my spearfish (hbar and the rear .der..oops) but I'm happy to have the "problem" I do.
    Bikes are fun.
    Be happy you could spend "$500" to fix it.
    On your left.
    Personally I think Salsa MTB bikes are marketing first, design second. I've had 3 and the primary selection criteria has been low cost and frankly that shows in the details and the ride, but I've certainly had some awesome rides, so no real complaints, but I could certainly make a long list of constructive criticism. More engineered bikes cost more - not that they necessarily break less (how could any consumer possibly determine that?), but there is potential for much more attention to detail - like proper welding, cable routing, bearing interfaces, etc.
    M
    Oct 2011
    Quote Originally Posted by Motivated View Post
    I completely agree. When the chance to purchase a near-new Salsa Spearfish frame came up last I jumped at the opportunity. I actually love the bike. I've put a lot of saddle time in through the Rockies and taken a few trips to Moab and Fruita. (Going back to Fruita next weekend.) The Spearfish is perfect for taking along camping gear and putting in lots of miles.
    Admittedly, my original post was more dramatic than I intended. To address some of the folks that are upset with this thread, I'm not sure if you're employees of Salsa or what your deal is, but for whatever reason, this statement seems to be an issue:
    I will emphasize my choice of words here. I PRESUME that Salsa may have figured out that their old rear triangle design wasn't ideal. Why do I assume that? Because I've read 6 threads in the last 2 months, (here and on SF's Facebook page) about cracking rear triangle. That seems awfully high. I don't need facts to make a presumption. You're grasping at straws.
    The intent of this thread was to
    1) Call attention to something I consider to be a design flaw on a bike that I think is otherwise spectacular. Other people are having a similar issue. I don't think that's a coincidence. Again, I'm 5'9" 150lbs. Not exactly a huge guy pounding on a bike more than it should be.
    2) Share the fact that I had to purchase a more expensive thru axle version (SF1) of the rear triangle because they completely stopped stocking / producing the QR version. That seems strange to me, to not produce a part that is prone to cracking. I don't have a warranty, so I didn't expect any handouts. But I want to know that if it breaks again, I can replace it. The reason this was an "ordeal" (again, more dramatic wording than I intended.) is because I had to also convert my rear wheel to 144x12, and purchase a Maxle, as it was not included with the $400 rear triangle. If I didn't have Stans hubs that were easily convertable, I'd have to buy an entirely new wheel. That's a lot of stuff and cash. Don't think so? That's fine too. Just my opinion.
    I really shouldn't have to defend myself against some of the folks in here. It's me calling attention to an issue that others are having as well. If that's not you, move along.
    Bikes break. Components fail. Be excellent to each other and party on dudes.
    Reputation: pulser's Avatar
    Dec 2004
    I also have a cracked sperfish. Mine is at the driveside dropout. I totally agree with you about it being a bad design. They even state in the marketing for the 14 fishes they went with a DW Split pivot because of lateral flex in the frames. I think that's the reason for the failures. My frame cracked with only 6 months of use. I also think they stopped making the QR rears because of that problem. I have yet to see a broken rear with a TA. I think having that will cut down quite a bit with that lateral flex.
    Oct 2011
    Quote Originally Posted by pulser View Post
    Yeah, I have yet to see a report of any quality issues of the TA version of the triangle. It seems to be constructed differently. For example, the seat stay bridge is burlier / slightly closer to the tire than my old QR triangle. (So much so that my 2.4 Ardent just barely rubs. I'll need to get a smaller rear tire.) Maybe it's just the finish / my imagination, but the TA version seems better constructed than the QR. I'm not a huge fan of the red graphics on the black. (Doesn't look great with the green frame.), but whatever...
    Dec 2004
    Get some quality black vinyl from a sign place and wrap it around the stays so you can't see it. It will protect the paint from scratches too.
    I sure hope I don't have this problem with mine. I am 6'4 263Lbs and have put several thousand miles on it over the last couple of years. Quite frankly, I love the bike. The trail demos I have attended over the last couple of years solidifies how much. I wouldn't trade it for anything I have ridden. If it were to break, I would buy another one. I hope the new design actually improves the bike. The Spearfish is great for what it is and it definitely fills a niche not covered by any other manufactures. I bought mine new from a dealer so........if it breaks I assume I am getting a replacement.
    Oct 2011
    This is kind of a turd of a thread, but I figure I should update. Everything is working perfectly now with the rebuilt frame. I dig the thru axle rear as it seems to have stiffened the rear, making it more responsive. I'm running 150psi in the rear shock, a little more than I was before trying to minimize the seat stay flex. Truthfully, I feel like I have to baby the bike a little more than I'd like now that we're finding they're prone to cracking, but that will hopefully go away with more rides. Here's a few shots from this last weekend in Fruita, CO.
    Photos by Garret Schmidt
    Reputation: hendricks97's Avatar
    Aug 2013
    not saying this is the OPs case, but Im wondering how many of these issues have come up for people that should have bought the Horsethief instead of the Spearfish.
    Oct 2011
    Quote Originally Posted by hendricks97 View Post
    I agree that the Horsethief is almost certainly more suited for my riding style. My plan for next season is to get an all mountain 26 or 27.5 and "give" the spearfish to my wife, as we ride the same size bike. That will allow me to get something that can take a bit more abuse, give her an upgraded bike and allow me to borrow the SF for bikepacking / races / long rides. I love the Spearfish, but I think this may be my last FS 29er.
    That said, I wonder if the 1st gen HT is going to be having similar issues as we've seen with th SF. Seems to me it would be even more susceptible with more travel.
    Reputation: progfan1's Avatar
    I have a 2012 'Thief and have had zero problems so far, but that doesn't mean I couldn't in the future, I guess. I rode Whole Enchilada in Moab in the summer and give it a pretty regular beating on rocky stuff back east. That said, I'm disappointed to read that Salsa was already negotiating with Weagle 2 years ago while touting the flexing rear triangle design. It seems like they already saw flaws in it while rolling it out, so why roll it out? I've dealt with Salsa on the phone about some things and they are super nice guys that seem passionate about riding, but I don't know if I'll buy my next bike from them. I likes the idea of buying from a smaller company instead of Trek or the big "S" and not having to spend over 5k, but this gives the impression that they don't stand behind their products as much as others. Why only a 2-year warranty on frames, for example?
    2012 Salsa Horsethief
    2005 Independent Fabrication Deluxe
    Quote Originally Posted by progfan1 View Post
    huh? Fact checking is easy.
    Salsa Cycles Limited Warranty
    Five Year Warranty
    Steel frames for original owner
    Titanium frames for original owner
    Carbon frames for original owner
    Three Year Warranty
    Aluminum frames for original owner
    All other Salsa bicycle forks, parts and components
    You are correct, except that on the same page it states the following:
    "This warranty applies to 2014 and newer model bicycles and covers only Salsa Cycles branded product. Any other original part or component shall be covered by the stated warranty of the original manufacturer. Any products not specifically included above are hereby omitted."
    I have a 2012 bike and warranty was 2 years. Is 3 years that good, considering that Trek, Giant and (I think) Niner have lifetime warranties?
    Your 2012 is three years. Trust me.
    Be careful how you view that "lifetime" warranty.
    Those guys you mention generally use the fatigue life of the frame (usually 5 years or so) It's not free bikes forever.
    Quote Originally Posted by Pancake Adventure View Post
    WTF?!?!? I want a free bike every year! :-)
    Oct 2011
    Pancake Adventure, do you work for Salsa in some capacity?
    Ha, No. I work part-time at a shop that sells them, and has for a while. I also love correcting people on the internet.
    Oct 2011
    Haha! Fair enough, fair enough.
    Reputation: fixgeardan's Avatar
    My SF1 is apart right now with the shock and fork at PUSH. while apart Ive been playing with the frame with no shock . That seat stay flex is so minimal almost undetectable I really don't think the pivotless design is the problem as much as the flex from the QR
    interface.
    Oct 2011
    Quote Originally Posted by fixgeardan View Post
    interface.
    Interesting. Not sure I'm fully following though. (I'm certainly no physics master.) How would the 9mm quick release make the chainstay, close to the bottom bracket, more fragile?
    Flex the rear of the swing arm will flex the front would stay solid between the welded cross piece and the pivot. Where yours cracked is the first place any flex would meet resistance . Makes sense in my head but that's not sayin much.
    Pancake, If my information was incorrect, I thank you for the clarification. I should also clarify that I've been very happy with many aspects of my 2012 'Thief. My main point was that I'm a little disappointed that they rolled out and pushed the flexing rear triangle design when they were starting almost immediately on a new design they thought was a better one. This suggests to me that another poster might not have been entirely wrong in suggesting that Salsa was aware of deficiencies in the 2011-12 designs. And no, I was not expecting a free bike every year, but I'm glad I gave you a vehicle through which you could feel clever.
    I agree to a certain extent, but...something for you to ponder: What company does not do this?
    If you were not selling something, and working behind the scenes to make something new and better to replace what is current, what would be the point of being in business in the first place?
    Improving an existing design is one thing. Putting a design that you know to be flawed on the market and touting as the latest and greatest is another. I'm not necessarily saying that Salsa did this, but the timeline suggests the possibility.
    eh, i still think that is a bit of a stretch...
    Should be interesting to see how the split pivot stuff holds up!
    Just hit it with speed
    Reputation: GFisher2001's Avatar
    Mar 2006
    Here I sit with a cracked TA Spearfish. Out of warranty, I get that. Bike shop wants the bike to be entirely put back together, yet Salsa says they only need to see the chainstay.
    Salsa is unable to sell me just the chainstay (I bought an out of warranty frame, I expect to fork over cash), but they apparently can't even sell it and don't know of any place that would be able to, other then the shop that wants to see the whole bike (so I have to put a broken bike back together).
    Anyway, deep breath, I am wondering did Salsa sell you the part direct? I am thinking no since you mention $380 for the triangle but total came to $500. How did you know the triangle was $380.
    Don't hate on the minivan!!!!!!!
    Reputation: Raymo853's Avatar
    After reading this thread, I began to worry to about my '13 SF1. (non-split, ano black, thru axle) It makes and odd clank or crack sound on any big hit to the rear. Well I checked seatstays, chainstays and associated bridges and the shock mount points. Found no visible problems. My suspicions are now back to the pivots, the shock itself or even the semi-wonky through axle.
    Quote Originally Posted by Raymo853 View Post
Name:	2016-12-11 05.56.22.jpg
    Check the pivot bearings and inspect all the hardware. They go quick. I end up replacing mine about once a year as they are only good for a few thousand miles. The press fit BB make a bunch of noise too. Could that be your culprit.
    I am 280 lbs and ride a 22" first year model Spearfish. I have thousands of miles, with no rear triangle issues. The only thing left on the bike at this point that I haven't had to replace is the frame, stem, and seat post clamp. At this point, if it breaks, I got my moneys worth. They sold a ton of these as they are a great value..... and I am sure some of them break. I can also cite an example of just about every other brand that has broken too.(case in point my buddy is on his 3rd Mach 429 Pivot) You are flogging something, as hard as you can, that is built intentionally as light as possible, in the worst possible conditions. What could go wrong? I love the pivotless triangle....it is one less thing to service and service full suspension you must.
    Quote Originally Posted by mrmas View Post
    I just started my rebuild last night. Wow, the bearings were so horrid after two years. It also took a lot of effort to press them out. Am going to finish the rebuild Tuesday.
    I am now suspicion the sound I was hearing was a lower bearing making noise as it is nearly seized solid and makes awful noise when I force it to move.
    Am looking forward to getting done, bet it will feel so much more active.
    Reputation: targnik's Avatar
    Jan 2014
    Feelin your pain.
    Not so much Salsa pain... but my old girl (12, 29er) has developed it's second crack in the rear triangle.
    I've had both cracks repaired by engineers i.e. TIG welded.
    However, my brain & gut are telling me that the old girl is on her last legs (rear triangle is gonna give up the ghost eventually).
    I'm investigating getting a reasonably priced, AM HT frame.
    Likely as a time filler, to save some coin for a new FS whip. Or, it may prove to be a fun, cost effective move.
    Either way it'll keep me out on the trails.
    Sent from my kltedv using Tapatalk
    "Mountain biking: the under-rated and drug-free antidepressant"
    Ive got a really well kept 2012 SF1 frame I am looking at selling . Its a medium with pushed fox shock black ano frame with all graphics removed.
  1. Cracked Chainstay: Best way to repair
    By illcomm33 in forum Frame Building
    Last Post: 01-16-2016, 06:31 AM
  2. Replies: 5
    Last Post: 12-09-2013, 09:25 AM
  3. What size chainstay guard on a Spearfish?
    By jadedbee in forum 29er Bikes
    Last Post: 07-09-2012, 02:19 PM
  4. Remedy 8 cracked chainstay
    By timsan in forum Trek
    Last Post: 08-21-2011, 02:11 PM
  5. cracked non driveside chainstay repair
    By mountaingoatepics in forum Frame Building
    Last Post: 08-17-2011, 10:02 AM
Members who have read this thread: 9
