Results 1 to 2 of 2
    get down!
    Reputation: appleSSeed's Avatar
    Can you convert the Horsethief/Formula rear 142x12 hub to 135?
    Just wondering. Going to sell/use these on something else and need to know if they convert an also grab some part numbers if they do.
    Thanks in advance.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Horsethief wheel woes
    Quote Originally Posted by appleSSeed View Post
    Thanks in advance.
    I'm in the same predicament. I have a 2012 Horsethief which was spec'd with Stan's Flow/Formula hub wheelset. The 2013 Horsethief has the Flow/DT Swiss 350 wheelset, which should be convertible since they have the 240 internals. The Formula website is totally useless. Since Formula is primarily an OEM supplier, I suspect that any switchability in those hubs is done in-house and not available as an aftermarket kit. I will try emailing Salsa and Formula in hopes they can help out in this regard. An alternative, while pricey, is to reverse-engineer and get pieces machined.
    geek
