Results 1 to 7 of 7
    tl1
    tl1 is offline
    Bicyclist
    Reputation: tl1's Avatar
    Can El Mariachi be happy with a Crud?
    I put a 2009 Crud Catcher front fender on my 2007 El Mariachi and started to have shifting issues. Then it dawned on: I've used a lot of Cruds before but never with downtube routed cables before. I don't see a way to make it clear the rear derailleur cable enough to not rub on the cables and interfere with shifting. Any ideas?
    http://www.crudusa.com/product/11/9
    Jan 2003
    Try running full length housing if your not allready?
    I use a Planet Bike grunge board -
    Since the front and back edges hug the tube instead of curling under it actually tucks neatly under the cables. Maybe you could notch out galleys for the cables or drill out pass-throughs?
    tl1
    tl1 is offline
    Bicyclist
    I'll give that a try
    Quote Originally Posted by PepperJester
    I haven't yet but I noticed the stock Shimano housing was cracking anyway so I'll see if that's workable. It's another reason to dislike down tube mounted cables though.
    tl1
    tl1 is offline
    Bicyclist
    I have one of those somewhere.
    Quote Originally Posted by dankilling
    I could try that too. The Crud is a larger fender with better coverage though.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by tl1
    I use that CC on my Ala Cart with no shifting issues.
    Just run the O-rings under the cables. The cables do rub a bit but not enough to affect the performance.
    mtbtires.com
    tl1
    tl1 is offline
    Bicyclist
    I'll try again
    Quote Originally Posted by shiggy
    I think the issue on the EM is because the cables stick out a larger distance from the downtube and at at a different angle than the Ala Carte. I'm thinking this is most likely because of the larger diameter of the eccentric bottom bracket.
Hot Deals
Contests
Latest Mountain Bike Articles
