Results 1 to 6 of 6
    Cleavage Of The Tetons
    Trick tips for threading cable through Rocky (internal) Frames....
    What have you got?
    Same techniques as the old Kleins?
    Please tell me there is a shortcut!
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    ups and downs
    Why not just take the removable cable plug out of the BB so it is easier?
    THAT, my friend, IS the kind of 'trick tip' that I was looking for!
    (didn't really look that hard)
    ups and downs
    My not-a-job here is done.
    Reputation: jrastories's Avatar
    The other good trick is to find a sheath for the cable (check with your local bike shop) thread it over the cable first pull the cable out leaving the sheath in place then thread the new cable though, remove the sheath and continue with the cable install. Check out this Specialized video and you will kind of understand what I am talking about. rI now use a sheath from a spec build or I have used the inner liner from a set of gore cables.
    Rocky Element
    My Attempt at a Blog
    Yeah, that was (sort of) one of the old Klein tricks. Thanks. Too late after you pull the cable, though.
  1. Internal Cable Routing?
    By kfb66 in forum Niner Bikes
    Last Post: 01-03-2013, 02:53 PM
  2. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  3. Internal Cable Routing
    By Phishin Paul in forum Ventana
    Last Post: 09-22-2012, 03:20 PM
  4. Rocky Mountain Internal Cable Routing Noise
    By field_c in forum Rocky Mountain
    Last Post: 08-08-2012, 09:58 PM
  5. Cutting cable trick.
    By Gary H in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-06-2011, 03:42 PM
