    Feb 2012
    Stinger chainguide on a Slayer
    Tried to mount a Stinger BB chainguard this afternoon but it seems it doesn't work that well.
    The guide rubs against the granny (which I really need ) and when I tighten the cranks the whole thing blocks. i'm having the standard RaceFace Atlas cranks and correct me if I'm wrong but I think I can't just add another spacer to get more clearance between the guide and granny.
    Because you tighten the cranks all the way down till you can't go any further. So adding an extra spacer would put more pressure on my bb bearings right?
    How've you guys managed to fit a Stinger on a Slayer?
    ups and downs
    Race Face cranks should have 1mm thick black rubber coated spacers that allow a 49-51mm chainline adjustment, if there is one on each side it would be set for a 50mm chainline, if you put them both on the drive side it would give you 1mm more clearance to the granny and a 51mm chainline.
    Feb 2012
    Thx @rockyuphill!
    Hadn't thought about that solution. Will try it first thing tomorrow!
    Hey mvdlans, ook hier ?
    Heb je het opgelost inmiddels?/Did you solved the problem yet?
    gr Jaspero ( forum)
  1. 2011 Slayer 50 vs 2012 Slayer 30, which to buy
    By PuraVida in forum Rocky Mountain
    Last Post: 08-03-2012, 11:52 AM
  2. Stinger ISCG on the EG?
    By PedroC in forum Titus
    Last Post: 01-09-2012, 06:39 PM
  3. Need help with Uzzi and Stinger Chainguide
    By sandiegobiker in forum Intense
    Last Post: 07-14-2011, 12:34 PM
  4. stinger on my 2x9
    By Tjay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2011, 07:08 PM
  5. Which Stinger for my DT?
    By jitenshakun in forum Knolly
    Last Post: 02-14-2011, 12:32 PM
