Results 1 to 6 of 6
    Slayer SXC 2010 how to put up together suspension
    Hi,
    After joining apart the suspension I encountered that I have two different bolts.
    The RM manual describes that there are two parts no. 7: 180400-070 Bolt Flange HD, Thru.BLT Internal M8 x 1.25 OD:12 x 70
    The photo will show what's it's about:
    One is thicker the other thin.
    Where they should be mounted?
    ups and downs
    Check the length of the sleeve section to make sure they are both 70mm. The 2010 Altitude 29 used a bolt that was 180400-071 BOLT - OD:12 X 71 mm THRU BOLT, INTERNAL M8, so one of those two bolts might be the incorrect length.
    @rockyuphill
    Thanks.
    Can you send me 2010 SXC manual? The one I have is probably 2009
    ups and downs
    Here's the link to the 2010 manual
    http://www.bikeaction.de/media/pdf/2...s_Handbuch.pdf
    Then there is something wrong with this manual.
    I have slayer SXC 2010 and part number 6 looks like this: https://www.dropbox.com/s/5h59k9gtu8....19.jpg?v=0mcn which is the same as part number 8. What's more I don't have in my frame washers: part number 4
    Part number 5 in my case is M12x63 instead of M12x67(as in manual).
    weird...
    ups and downs
    Those 1 piece bolts were used in 2007 and 2008.
    Attached Thumbnails Attached Thumbnails Slayer SXC 2010 how to put up together suspension-slayer-sxc-se-zoom.jpg
  1. Replies: 3
    Last Post: 05-22-2013, 07:24 AM
  2. 2010 Slayer SXC 50 Build
    By imsorrywhat in forum All Mountain
    Last Post: 07-31-2012, 10:16 AM
  3. 2010 Slayer SXC 50 Build (Pictures!)
    By imsorrywhat in forum Rocky Mountain
    Last Post: 07-31-2011, 07:34 PM
  4. 2010 Slayer SXC
    By tosa in forum Rocky Mountain
    Last Post: 07-09-2011, 01:46 PM
  5. 2010 Slayer SS 427 questions
    By AMhardtail in forum Rocky Mountain
    Last Post: 02-17-2011, 08:03 PM
