Results 1 to 9 of 9
    Apr 2005
    Sizing help for Rocky Mountain Altitude 750 (2015 model)
    I'm 6"2 with a 34" inseam.
    Wondering what would be a better fit for me: large or XL
    Aug 2010
    I'm not on a Altitude but a T-bolt and a 6'0" with at 32" inseam the large fits me perfect. I would lean towards a XL if I was you. Any shop close that has one in stock you could throw a leg over?
    ups and downs
    Yep, you'd likely be happier on an XL, otherwise the cockpit may feel a bit cramped, especially with a dropper post with no setback. I'm 6'-1" with long arms, I'm on a Large Tbolt and if I was any taller I'd want the XL size.
    Mar 2005
    I am 6'1" and have an Altitude 750 MSL in L. I could go with an XL also. With your size I believe you would be happier with XL size.
    chips & bier
    Reputation: eric's Avatar
    6" exactly with a short inseam (dunno what).... I'd go for the XL. I'm on an L with a 50 mm stem, and wouldn't really want to go any shorter.
    Oct 2015
    Rocky's are small, get the XL. The extra wheelbase will be beneficial on an enduro style bike.
    Cactus Cuddler
    Reputation: tehllama's Avatar
    Jul 2013
    XL or XXL (if you want to go stubbier on the stem).
    I'm your size, and on a Large Instinct (with 70mm stem) - when I get the chance, I'm moving to an XXL so I can run a 50mm stem. The seat tube length won't be problematic (especially if you're running a Reverb Stealth dropper - or a similar 435mm or shorter option if you want 150mm drop), you can steepen the seat tube by running the seat farther forward (or neutral with a non-layback post), and run a shorter stem - all that would put the XXL sizing in your range - in terms of sizing out of the box, unquestionably take the XL.
    I'm 6'2" (187cm) and have an XL 2015 Altitude Rally Edition - no way would I go with the Large. I run a 50mm stem and could run a 150mm dropper (bought a 125mm as wasn't able to get 150 at the time).
    Apr 2005
    Thanks to everyone for their responses. I went with the XL and it fits really well!
  1. Rocky Mountain Altitude 27.5- confused with sizing.
    By russmu66 in forum Rocky Mountain
    Last Post: 05-18-2014, 08:22 PM
  2. Rocky Mountain 'Altitude' 750
    By Settertude in forum 27.5
    Last Post: 10-06-2013, 08:19 PM
  3. Which Rocky Mountain Altitude (730 vs 750 msl)
    By Ro_bby in forum Rocky Mountain
    Last Post: 10-03-2013, 06:24 PM
  4. Rocky Mountain Altitude 90..?
    By EFMax in forum All Mountain
    Last Post: 05-07-2013, 12:11 AM
  5. My Rocky Mountain Altitude 29
    By Fuze911 in forum 29er Bikes
    Last Post: 12-18-2012, 01:26 PM
