Results 1 to 7 of 7
    Reputation: Seventh-777's Avatar
    Aug 2013
    Sherpa rear shock specs?
    Silly question here, but the bike's not in front of me and I can't seem to find the info online.
    I have a 2015 Sherpa and I'd like to replace the rear shock. I can't seem to find the right size for a replacement, though. Would anyone happen to know offhand what size it is? From RM's website it's a "MANITOU MCLEOD CUSTOM VALVED. SMOOTHLINKô DESIGN 95MM. REBOUND / 4 POSITION IPA PLATFORM SETTINGS".
    I'm just looking for the right size replacement in a Fox or RS, so that I don't order the wrong stuff. Thanks!
    Trail: Scalpel-Si / Sherpa / Fatboy
    Gravity: Nomad / Glory
    Road: Stigmata / Slate
    "Aah the great indoors - No One Ever"
    ups and downs
    If you order it as a new Fox piece they will have a database that relates the shock size and valving to a specific year and model of Rocky. It looks like the same size as the Element from 2012-2016, which would be a 6" x 1.25" and would likely need the same valving as the Element shock
    Compression FIRM
    Rebound FIRM
    Climb FIRM
    Aug 2013
    ^ Thanks very much.
    I've hemmed and hawed, and I've settled on the Fox Float DPS. This may be another silly question, but I figure it never hurts to ask before I spend $450+ on something I can't use...
    Would anyone happen to know if I will need new/additional bushings to swap the stock Manitou shock out for the Fox? Or should I expect the Fox to come with whatever I need? (Or perhaps reuse what's on the bike already.)
    Thanks again!
    ups and downs
    The last time I ordered a new Fox shock to a particular Rocky spec it came with reducers and bushings, other than the Rocky specific linkage pieces which I re-used, but that's a small sample, so you'd hope so, but you never know for sure until it arrives.
    Was wondering how you made out with the fox upgrade. I am in the same position, my Sherpa could use a new shock and fork. Love the bike but suspension isn't the greatest
    Aug 2013
    Quote Originally Posted by jts140 View Post
    I went with the float DPS. It works as you'd expect, and looks fantastic w/the paint scheme. I'll probably end up getting the kashima fork too, once I figure out my hub options. The fox fork is boost only, and these wheels aren't.
    Thanks for the reply, I want to change mine, however this is all new to me. Any help would be appreciated. Does hardware come with it or was it an easy swap. Thanks
  1. '09 Altitude rear shock specs ???
    By homeagain in forum Rocky Mountain
    Last Post: 10-19-2013, 12:44 AM
  2. 09 Anthem rear shock specs
    By yeti575inCA in forum Giant
    Last Post: 03-20-2013, 04:42 PM
  3. 09 Anthem rear shock specs
    Last Post: 03-14-2013, 05:26 PM
  4. Question: Rear Shock Specs
    By psisp in forum Santa Cruz
    Last Post: 07-03-2011, 09:49 AM
  5. sf03 rear shock specs
    By specializedsteve in forum BMC
    Last Post: 05-18-2011, 08:06 PM
