Results 1 to 10 of 10
    Jun 2012
    Rocky mountain cable quality
    Need to replace my shifter cables. How is the quality of the RM outer cables that came with my element 950.
    Will getting SRAM cables make a big difference.
    The inner cable for shifters is 4 mm, correct?
    ups and downs
    Shifter inner cables are typically 1.2mm diameter. The cable casing is 4mm diameter.
    The only cables that you'd feel a huge difference with would be the fully sealed Gore Ride-On cables, but they've dropped them from their line. SRAM sells a version of them now. It might be difficult to get them to work with the interior frame routing. Those definitely make a huge difference in lever effort at the shifters.
    Jun 2012
    I see what you are saying, that will be impossible to get through the frame without drilling.
    Anyone has tried that. Intrigued by a closed system.
    If you cut the cables, you think I will still feel the difference?
    Edit: few more questions.
    You think there will be a difference between.
    Jagwire 4mm LEX Bicycle Shift Cable Housing
    Amazon.com: Jagwire 4mm Derailleur Housing w/ L3 Liner, Roll/25 Black: Sports & Outdoors
    or
    SRAM 4mm Slickwire Road and Mountain Bike Shift Cable Kit
    Amazon.com: SRAM 4mm Slickwire Road and Mountain Bike Shift Cable Kit (Black): Sports & Outdoors
    Reputation: ccaddy's Avatar
    ... " I see what you are saying, that will be impossible to get through the frame without drilling... "
    Drilling ??
    What are you talking about :-0 ??
    ups and downs
    You only need to get the Teflon liner through the frame, but those liners are still 2mm O.D. so they would be a snug fit on the cable guides. You wouldn't need to drill them out much compared to the 1.5-1.8mm diameter hole in the cable stop at the head tube and the bottom bracket insert.
    Jun 2012
    That would be more then a snug fit. 2 versus 4 mm is quite the difference.
    Anyone successful running 4mm through an element frame?
    edit: spelling
    Reputation: zonoskar's Avatar
    I didn't have any troubles fitting the Gore cables to my 970. I installed them a year ago and they are still going strong without any maintenance. I'd say they are well worth the money. I wouldn't recommend going full length cable housing as that will require drilling the cable stops and would most probably void your warranty.
    ups and downs
    You don't run the outer housing through the frame, just the 2mm Teflon inner liner, that gives you continuous cable housing from a water/dirt infiltration point of view. The Teflon inner liner slides freely through the cable casing, so you cut the cable housing sizing first and then run the inner liner through the housing and frame and then insert the inner wire.
    When I ran the Gore cables through the external guides and stops on my Element 70 MSL the inner liner was a snug fit the cable guides and stops, I needed to run a small round file through to clean the paint off of many of them. It's good to hear that they have a bigger opening in the internal routing stops.
    Gore cables can last for years. The set I installed on my hardtail have been going service free since 2009.
    Quote Originally Posted by Learux View Post
    edit: spelling
    Attached Thumbnails Attached Thumbnails Rocky mountain cable quality-2013_0921new0002-001.jpg
    Jun 2012
    Thanks for explaining that. I did not know there was a separate cable.
    That looks like what I want.
    Reputation: Tarekith's Avatar
    Mar 2005
    Personally I've had better luck with the SRAM stuff versus Jagwire lately. Used to love their stuff, but lately has given me a lot of headaches with some of the complete kits not being long enough for my Slayer.
    Tarekith.com
    '17 Specialized Enduro Elite 29
  1. Quality Mountain BB30 Bottom Bracket?
    By ALS650L in forum Cannondale
    Last Post: 08-02-2014, 08:59 PM
  2. determining quality of Mountain lx derailler
    By cmugler in forum Vintage, Retro, Classic
    Last Post: 06-29-2013, 08:45 AM
  3. Replies: 5
    Last Post: 04-18-2013, 08:30 PM
  4. Cable HD vs Satellite HD (Dish) - picture quality?
    By MTBeing in forum Off Camber (off topic)
    Last Post: 02-13-2013, 08:52 PM
  5. Rocky Mountain Internal Cable Routing Noise
    By field_c in forum Rocky Mountain
    Last Post: 08-08-2012, 09:58 PM
