Results 1 to 25 of 25
    Feb 2007
    Are RM's Wheeltech Hubs really this bad? Now What?
    Hey guys/gals, I am i So Cal and have a 2012 element 930 with four months/400 miles on it and the rear whelltech xc hub just blew ( loud pop/snap and now freewheels) stranding me in nowwhere land. I have been riding over 20 years and have never had that happen
    I contacted RM and they referred me to my online dealer in Canada( yes, I prefer LBS but i purchased late in year and no one had them). I am getting the run around so warranty looks bleak. Maybe RM will step up?
    Questions: Is this hub even worth going through the hassle of warranty? I will have to pay shipping to Canada,wheel re-build,etc. Maybe i just got unlucky but I don't have much faith now. How does a hub on a $2500 bike fail so quick?
    My gut tells me just to upgrade the whole wheel which i planned to do in a year or so but just now catching back up from bike purchase. I am also unhappy to be "forced" into an upgrade four months into ownerwship. I need the 12x142 rear. If I can only buy the rear right now, what hub/wheel do you guys recommend? I read up on other forums and know there are millions answers but do i go with pre-built ( like dt swiss tricon or find builder? I could swing around $400. Opinions on my course of action?
    ups and downs
    Freehubs do fail for various reasons, luckily it wasn't a $1300 XTR wheelset, Shimano have decided they won't warranty their $250 titanium freehubs when they explode.
    A lot of hubs can be near their limit with 29" wheels and big cassettes and high torque riders. A custom rear wheel with a rim of your choice and a DT Swiss 350 or 240S hub (with Star Ratchet system) would be solid, same with something like a Hope Pro 2 Evo (although noisier). The DT hubs are a breeze to service, they come apart without tools to lube the star ratchet, and they last a long time.
    Mine failed too . . . . after two weeks. I agree with Rocky, go with a DT 350 and a solid rim (mine is a wtb i23). Not too expensive and has been solid. Check on Ebay and see if you can find a deal, though it might be hard to find the 12x142. Why warranty something that will blow again? Hey RM, the rear hub is not a place to skimp! Can't really fix it out on the trail.
    Feb 2007
    Rockyuphill, i sure appreciate your insight, my research has pointed me in that same direction ( those 2 hubs ,350 and hope) but it is nice to hear if from you as well.
    I have seen some sets on line with WTB I23 on line. I have the stock RS recon gold fork up front. do you know the spacing on the 20mm thru axle. i have seen 20mm x 100 , 110,120 and don't know what I have.
    ups and downs
    All 20mm axle hubs are all the same 110mm width, and those are different from 15mm x 100mm front hubs. The DT 350 oversize front hubs are convertible to any axle format
    Universal Cycles -- DT Swiss 350 6 Bolt Disc Front Hub
    BTW, it's critical that you use the 6 bolt oversize 350 hub, the center lock version only converts between 9mm and 15mm.
    Two local shops have had rocky send them new hubs and the shops were switching them out on demo and sales bikes. The hubs are horrible, ive seen 5-6 broken rear hubs now.
    Feb 2007
    Hey rodeoj, curious if you know, was Rocky replacing them with a different type of hub or a new variation of the same hub?
    The replacements are heavier, that much I remember. Still wheeltech.
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Reviving an old thread...
    Anyone have details of the wheeltech hubs that Rocky supplies with the 2015 Blizzard fat bike?
    My Blizzard is on order, and I was leery of these hubs from the start. It really seems like the freehubs on a lot of house brand hubs are problematic... specialized comes to mind among others. Only hubs I really trust these days are Hope, so I'm wondering if I should bite the bullet and rebuild (at least the rear wheel) with a Hope hub rather than risk getting stuck somewhere with a broken freehub?
    ups and downs
    It looks like the Salsa 3 fat bike hubs are made by Formula, so the Wheeltech hubs are likely a 12mm thru axle version of the Formula Fat bike hubs.
    Reputation: MartinS's Avatar
    The Blizzard Fat hubs are not holding up well, weird reverse pawl design that doesn't look like any formula I have seen. They seem to fail after a couple of weeks of riding. When you get the bike pull apart the hub and degrease it thoroughly and lube it with tri flow and hope for the best.
    ride
    Reputation: ignazjr's Avatar
    Quote Originally Posted by MartinS View Post
    The hub is made by Quando. RM asked them to spec the hub with it's most durable freehub - able to handle lots of torque. I just got mine. We'll see how it holds up. I like the design, personally. Gives the pawls a little more backbone then if they were mounted on the freehub itself.Are RM's Wheeltech Hubs really this bad? Now What?-img_20141125_122953125.jpg
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    Quote Originally Posted by ignazjr View Post
    The hub is made by Quando. RM asked them to spec the hub with it's most durable freehub - able to handle lots of torque. I just got mine. We'll see how it holds up. I like the design, personally. Gives the pawls a little more backbone then if they were mounted on the freehub itself.Click image for larger version.
    Thanks for the information and the photo... any idea on the POE of the freehub?
    Hope they do okay for you, my buddies one lasted 2 weeks and his second one is making noise. His is not the only one to go back to our local shop so far.
    I'll be paying very close attention to the rear hub when I get my Blizzard next month. At the moment I'm trying to decide if I should preempt the problem by changing out the grease before the first first ride. I'd likely use Slick Honey since I have a big tub of that and it is supposed to handle low temperatures very well. I've used it in my Hope Pro 2 Evo hubs without issue.
    I would strongly suggest degreasing/re lubing them at the start, a buddy who is a Rocky dealer (not my local shop) is saying it can help, he has had a couple of blizzard hub failures too.
    Thanks for the advice, I will very likely do just that.
    Quote Originally Posted by kwarwick View Post
    *answering my own question* Looks like the POE is 30 based on counting the number or clicks for a full revolution.
    I took the time today to open up the hub and replace the factory grease with slick honey. I think I can see the problem that leads to these failing. Basically the leaf springs used to engage the pawls just don't seem strong enough... definitely no where near as stiff as the ones that Hope uses. Also because of the folded over shape of these springs I noticed that any grease getting on the inner surfaces of the springs causes a bit of suction that further reduces their ability to quickly respond and pressure the pawls. If this happens under heavy load pawls will probably slip and chip leading to an early death of the freehub.
    So I made point of not putting grease on the inner surfaces of the springs and hopefully the viscosity of slick honey is such that it won't cause stickiness if it does creep in.
    *fingers crossed*
    I had to rent a Blizzard last Sat after a hub failure on my own bike (Fatback import hub, lasted 2 seasons) and even though it had had the hub re-done I managed to spin the freehub 4 times in a 1 hour ride. Rocky has a problem with these hubs, can't see how they made it to production.
    My Blizzard hub has had the axle nuts unwind or the bike was delivered that way. I'm unclear how tight to get these? I've had a couple of skips in the freehub and would like to remove, clean, and re lube with some light oil. But only if I know how to reassemble properly.
    I assume you are talking about the rear hub?
    The ends of the axle nuts are serrated so I don't think they could unwind by themselves unless the thru axle was very loose... more likely they weren't tightened down from the factory. When I took mine apart the caps were tight, but not super tight. After re-lubing I just went for a similar tightness... didn't worry too much about a particular torque.
    So a little update on mine and a buddy's experiences with the reliability of the rear hubs supplied on our 2015 Blizzards.
    My buddy finally blew his up about a month ago... there was a fair bit of warning as the hub had been popping occasionally since he bought it new in December 2014. Hub was replaced with Hope Fatsno so he gave me the old hub to look at. When I opened it up I could see lots of damage to the 6 pawls that engage the ratchet ring:
    Here they are removed from the hub:
    The ratchet on the freehub looks fine:
    So last week my rear hub finally started acting up too. I experienced one really loud pop in the middle of the ride and then I could tell things were not quite right with the engagement so took care applying power and was able to complete the ride without any more loud pops.
    Inspecting the pawls from my hub I found a couple (top and bottom) that didn't look happy:
    After lots of research I found that this reverse 6 pawl system is used by a few companies under different names. Halo is one... they call it 6-drive. Apparently Nukeproof uses them in their Generator hubs too according to these spares being sold at CRC:
    Nukeproof Generator Pawls & Springs | Chain Reaction Cycles
    So for $25 I decided it was worth trying a set of these pawls... I have no illusions that this won't happen again, but if I can get another 2 years out of this hub it makes good economic sense vs. the $300 I would have to spend on a Fatsno hub.
    So did the $25 fix work?
    Looks like I may have the same issue.
    Quote Originally Posted by justjaded View Post
    It sure did. Hub has been good as new since installing these pawls (200kms ago).
    Since my Blizzard only gets winter riding I don't put on big mileage like my other bikes, so hard to say how long these pawls will last. The first set lasted about 500kms so I picked a few more sets to have in reserve just in case.
    Karl
  1. Centerlock Hubs - Better than regular 6bolt hubs?
    By mattsmc43 in forum Wheels and Tires
    Last Post: 05-28-2013, 11:46 AM
  2. Sram x-9 hubs versus Stan's ZTR hubs
    By <sL4yEr>RuLz in forum Wheels and Tires
    Last Post: 04-18-2013, 06:28 PM
  3. Anyone prefer freewheel hubs to cassette hubs??
    By vindiggitydog in forum Singlespeed
    Last Post: 03-20-2012, 12:54 PM
  4. Velocity hubs vs Stan's stock hubs
    By 7Wayne7 in forum Wheels and Tires
    Last Post: 02-22-2012, 04:11 PM
  5. Alex TD24 and Wheeltech disc catige hubs
    By ernie00 in forum Wheels and Tires
    Last Post: 05-26-2011, 10:26 PM
