Results 1 to 37 of 37
    RM Recommend lubing ABC bushings now?
    My lbs tells me that RM is now recommending that ABC bushings be lubed with Sram Jonnisnot. Anyone know about this?
    ups and downs
    I always check the German distributor bikeaction.de website for tech data, they keep their tech section up to date. They haven't posted anything new regarding the ABC bushings. The 2013 tech manual section they have posted still reads...
    Lubrication
    All IGUS bushings are a dry fit installation and function. They require NO grease or oil to
    install or function. Only after washing with water should the bushing area be sprayed
    lightly with WD-40 to disperse water, and then wiped clean to prevent dirt buildup.
    Caution: prolonged exposure to water can cause the bushings to swell.
    It will be interesting to see if there have been service bulletins sent out to dealers in particular climates (really dry or really wet) that haven't been posted on the German website.
    Yeah, I checked there first. It would be nice to see it in writing somewhere.
    Thanks.
    Sent from my SCH-I535 using Tapatalk
    Reputation: Zerort's Avatar
    Jan 2013
    I keep mine lubed with a really fine film of Mobile 1 grease.
    by Silentfoe
    I'm satisfied knowing that what I wear during my "day" job makes me more of a man than you'll ever be.
    wheelie king
    Reputation: 661lee's Avatar
    Quote Originally Posted by KThaxton View Post
    The demo rep told me the same thing. Use a light coat of SRAM Jonnisnot.
    Thanks, it's always good to hear it from more than one source.
    What other alternatives to jonnisnot are there - I use Rock'n'roll red stuff elsewhere on my bike, would this be similar?
    Rocky Mountain 2003 Hammer, 2009 Vertex 70 RSL, 2012 Element 970
    2012 Wilier Triestina Gran Turismo
    I won't pretend to be the authority on this but my thoughts are....you'd want to use a grease, not a liquid lube, and further, I think you'd want to use something that is designed for use with metal and composites, like Jonnisnot. Some lube's solvent could degrade the polymer material of the bushings.
    Mar 2012
    Any updates on this?
    It would be nice to have an intermediate option when chasing down the perpetual creaking before succumbing to the $150 bushing replacement which still might not solve anything.
    I'm thinking about WD40 vs silicone spray vs Slick Honey.
    Bel-Ray waterproof grease for the Win. You can grab a tub at your local motorsports shop for a few $$. Their demo guy turned me on to this and it works awesome - bike is silent and has been for a few months now
    Nov 2013
    I was told they recommend lube now especially for Pacific Northwest/North Shore conditions. I rode all winter so I figured I'd take a peek at the rear end. The bushings were a bit discolored but not worn...good to see. I took apart all the rear bushings and put a bit of Slick Honey on them. They also suggest Judy Butter?
    Anyway, it has to be something that won't harm the material of the bushings.
    Although to be honest I now see more dirt sticking around the bushing locations - a concern I heard raised before - so we'll see how that shakes out.
    I've tried WD-40 and it doesn't seem to be working at all. I think I'll try the Slick Honey, unless you all think something else is working better. Living in Florida, every day it rains and I feel water gets in the pivots when driving home. Also do I have to take the pivots completely out or can I just loosen it to lube it up.
    Dec 2010
    And for Italy or at least Europe wich kind of oil or grease? I've tried paraffine oil given with a needle siringe for some months but now it'isnt enough...any advice?
    Regards
    Ernesto
    ups and downs
    It would need to be a very low viscosity synthetic type grease that isn't water soluble , so something like Johnny Snot shifter lube, Judy Butter or Slick Honey. It's primary function is going to be keeping muddy water out of the bushings. WD-40 is primarily a water displacer and not a lube so that and any sort of penetrating oil won't help.
    Mar 2012
    Quote Originally Posted by edibetta View Post
    Regards
    Ernesto
    Ernesto,
    I'll be in Torbole riding Garda from about July 27-August 9. I just got a tub of Bel Ray Waterproof Grease which contains about 10x more than I'll ever use. If you'll be around there I could maybe smuggle some in for you.
    Dec 2010
    Quote Originally Posted by jm2e View Post
    Ernesto,
    Hi thanks!
    My email is: ernestodibetta at gmail.com
    when you are in Torbole let inform me maybe we can ride toghether somewhere in Tremalzo ! I should work in those days but maybe I can have half day free!
    Regards
    Ernesto
    Dec 2010
    Quote Originally Posted by rockyuphill View Post
    Should I use loctite on screws after greasing?
    Regards
    Ernesto
    ups and downs
    Yes, and you want to use the 243 (blue) Loctite that they recommend for large and small fasteners. Because the pivots rotate, there is always a chance that the bolts can ratchet loose if they weren't at the spec torque with Loctite, and that could result is losing a bolt that would strand you on the trail somewhere.
    This is from the 2014 Tech Manual, they are officially recommending greasing the IGUS bushing
    http://www.bikeaction.de/media/pdf/2...t_MS_FInal.pdf
    Lubrication
    All IGUS bushing exterior surfaces shall be greased. Grease is also required where the bolt
    contacts metal such as a bearing or the frame.
    After washing with water the bushing area should be sprayed lightly with WD-40 to disperse
    water, wiped clean to prevent dirt buildup and then re-greased. Caution: prolonged exposure to
    Hardware and Torque Specification:
    All custom hardware (alloy thru-bolts, screws, and nuts) requires the use of LOCTITE 243 (blue) a
    medium strength thread-lock. The torque specification unless otherwise stated is 100 to 110
    in*lbs or 11.3 to 12.4 Nm.
    Non custom hardware (steel bolts) requires the use of LOCTITE 243 (blue), a medium strength
    thread-lock. The torque specification unless otherwise stated is 60 to 80 in*lbs or 6.7 to 9.0 Nm
    Oct 2012
    A couple of months ago I emailed Rocky to get some advice on how to improve small bump compliance. They made a couple comments about greasing as a side note. Here is the pertinent part:
    "Have you been riding all through the 8 months that you have owned your Altitude? Have you brought it into the dealer that you purchased it from to have the bike checked over since it has been purchased to make sure everything is running well? Applying a light film of Bel-ray waterproof grease to the surface of the bushings might return the bike’s small bump sensitivity. Please take your bike into your local Rocky Mountain Bicycles dealer and have them check the pivots to make sure the hardware is in good condition and if they could use to be greased."
    If I am understanding this correctly, it sounds like greasing is recommended and using Bel Ray on the bushings might be the way to go.
    chips & bier
    Reputation: eric's Avatar
    Good this is now official. Next step: zerks for those of us living and riding in the slop!
    Can anyone translate this or know where to get an English version?
    http://www.bikeaction.de/media/pdf/T...r_MAI_2014.pdf
    Danke schoen
    ups and downs
    It's a note saying the new 2014 tech manual is available. As is a new 12mm thru axle and adapter from Tune.de, plus the source for a flush cutter for zip ties so they won't slice you up. But a set of nail clippers work nicely for that
    Danke schoen
    Mar 2012
    Quote Originally Posted by beachbum1 View Post
    My advice: Get a Rockshox Monarch Plus. It will improve small bump compliance, medium bump compliance, will give you a firmer and more consistent pedaling platform and will make the bike feel bottomless on big hits.
    And the grease will help with creaking.
    Reputation: Ducman's Avatar
    So we are talking about part #18 in the manual (instinct), that is the one that now gets grease? Will Phil wood waterproof grease work?
    ups and downs
    Essentially both sides of the beige ABC Igus bushings would get some waterproof grease on them. Phil Woods should work well. Should make it easier to assemble everything as well, it's quite sticky.
    Oct 2013
    My 180493 UAT ALLOY WASHERS No 43 are shot after 200hrs so need replacing asap.
    They are worn down and a lot of play has developed in the link.
    Apparently there is a bad batch of these on some Altitudes,softer metal or something.
    Local RM are trying to get some new ones under warranty,fingers crossed.
    The 1805444 IGS IGUS ANGULAR CONTACT BEARING No18 are fine though.
    Enclosed pics
    Attached Thumbnails Attached Thumbnails RM Recommend lubing ABC bushings now?-013.jpg
    Altitude 750 2014
    Oct 2013
    Nice one Rocky!
    Getting new link and all the bushings under warranty
    Enclosed tech bulletin on frame noise.
    Apology couldn't upload full pdf due to file size.
    Altitude 750 2014
    Could you email the pdf version?
    Oct 2013
    ^^ pm for you
    Altitude 750 2014
    Can I get that also? I am still having issues with mine and getting it fixed properly would be much appreciated.
    Oct 2013
    ^^ pm for you
    Altitude 750 2014
    Dec 2010
    Could I also get a copy of the PDF please?
    Me too :-/ PDF please. Seems like a handy document. Thanks!
    Oct 2013
    send me a pm with your e-mail and i'll fwd the pdf to you.
    Altitude 750 2014
    ccm
    ccm is online now
    West Coast Racing
    Reputation: ccm's Avatar
    me too please
    Dec 2010
    Took bike into LBS for this to be checked - no issues. Thanks for the info.
    Dec 2010
  1. Shadow Plus RD lubing
    By DennisF in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-27-2014, 12:09 PM
  2. Lubing MRP chain guides
    By RiderC in forum Downhill - Freeride
    Last Post: 12-12-2013, 03:02 AM
  3. Lubing/Greasing new Airborne Bike.
    By rliddane in forum Airborne
    Last Post: 08-16-2013, 06:57 PM
  4. Lubing Locks - What do you use?
    By highdelll in forum Commuting
    Last Post: 10-08-2011, 08:12 PM
  5. cleaning amd lubing
    By blkcheerio in forum General Discussion
    Last Post: 04-18-2011, 04:56 PM
