Results 1 to 2 of 2
    RM Element 970 RSL - Syntace W35 MX Wheelset
    Anybody tried this wheelset? I am curious about the Syntace W35 which would replace a Mavic Crossmax SLR wheelset has proven to be too minimal for a Clydesdale (and yes, Mavic suggests as much).
    The wider Syntace sounds interesting. Rear chainstay clearance would be a gamble. I have a pair of Maxxis Ardent 2.4's mounted tubeless on the Crossmax SLR. Fit is good even with some wobble.
    A wider rim will change the tire profile. For the W30, Syntace writes that it is suitable for tires, "from 2.2 to 2.35'' whereas the W35 is suitable for tires, "from 2.25 to 2.5''. Rim inner width for the W30 and W35 is 24.5 mm and 28.4 mm, respectively.
    Right now, I don't see any reason to get the W35. On the other hand, if there are are true to spec 2.4" tires that make sense, why not simply take "wider is better" as far as it goes for the 970 RSL.
    Left on my own, I might go up from with a W35 HiTorque MX Front 20 (over-sized bearings; stout) where I don't anticipate any problems. In the rear? W30 ... seems like I might be pushing it otherwise (i.e. clearances would be very tight).
    Thoughts? Advice? Experience?
    Figured the W35 was not appropriate and might introduce tire clearance problems for the Element 970 RSL. Ordered the W30 instead. A matter of millimeters. I can post back after: (1) the wheels arrive; (2) the rims are converted to tubeless; (3) the garage floor is cleaned up of Stan's; and, (4) a ride or two take place.
  1. Syntace W35 650b wheelset
    By pat656 in forum Wheels and Tires
    Last Post: 06-25-2015, 07:14 PM
  2. Syntace W35 MX wheelset
    By ashas in forum Wheels and Tires
    Last Post: 01-08-2014, 09:29 AM
  3. Syntace W30 MX wheelset reviews/opinions?
    By xbrian in forum 29er Bikes
    Last Post: 05-02-2013, 04:08 AM
  4. Syntace MX Wheelset?
    By stumpynerd in forum Wheels and Tires
    Last Post: 02-08-2013, 02:08 PM
  5. Syntace 40mm wide 29er wheelset?
    By Slow Danger in forum Wheels and Tires
    Last Post: 09-25-2012, 03:12 PM
