Results 1 to 8 of 8
    Nov 2012
    replacing internally routed gear cable- Element 29 BC- tips?
    Just pulled the rear derailleur cable out to replace it and now see that it is not lined internally in the frame .
    Very difficult to route the new cable inside the frame, cannot seem to get it out at the tiny exit hole at the BB.
    Any tips for replacing/routing the cable?
    Shouldn't there be a inside liner?
    (Probably should have used this trick:)
    J
    ups and downs
    Why not just remove the cable port plug at the BB?
    Jun 2012
    Take tension of both derailleur cables, remove plug( you can't remove it if you leave one cable on) mount the bike in such a way that the down tube is vertical.
    I had an issue myself and found that the easiest way to get it to come out of the exit port was to simply hold the cable at the entry point by the headtube and as I pushed it through the frame I spun it. this made it slip out of the exit port instead of going up into the frame
    Nov 2012
    great thanks for the tips- finally managed to do it, somehow it got tangled inside many times ..
    Mar 2005
    I just got a 2012 element msl frame. It does not seem to be like the cable port plug (aluminum) under the BB is removable. How hard should have have to pull it for it to come out?
    ups and downs
    It has a rubber o-ring that may be holding on to the plug, but it should just pull out
    Quote Originally Posted by quasi_shawn View Post
    Mar 2005
    OK, I put a little tri-flow around the edge and it loosened up and came out. Thanks!
  1. Replacing front derailleur cables element 950
    By Learux in forum Rocky Mountain
    Last Post: 03-09-2013, 09:33 PM
  2. 6mm Gear cable ferrules and suitable cable?
    By Rick Draper in forum Vintage, Retro, Classic
    Last Post: 09-23-2012, 02:01 AM
  3. Internally routed brake housing - pros and cons
    By rasse1977 in forum Brake Time
    Last Post: 01-17-2012, 01:07 PM
  4. Replies: 2
    Last Post: 07-03-2011, 09:02 PM
  5. Internally routed cables
    By def156 in forum Frame Building
    Last Post: 03-18-2011, 03:00 PM
