    Reputation: ccaddy's Avatar
    Problems fitting an XO crankset to my 950 Element .
    For my 2012 950 Element 29'r , I just got an XO 2x10 crankset to replace the stock X9 unit .
    The big ring on the XO is a 42 while the X9's is a 38 .
    The XO's 42 is touching the front derailleur cage and wont
    fully insert into the BB .
    Do I need a different derailleur or just a smaller big ring .
    The XO's and X9's sprockets are not interchangeable either .
    ups and downs
    SRAM has specific FD's for every chainring combo(26/39 and 28/42). They also have specific top and bottom pull FD's in the same direct mount version. It makes ordering a coffee at Starbucks a simple process by comparison.
    And they have a horribly complicated chart if you are changing between SRAM cranks.
    Attached Thumbnails Attached Thumbnails Problems fitting an XO crankset to my 950 Element .-sram-crank-chart.jpg
    Flow Chart Maddness LOL
    So can I make this 42/28 crank work in place of
    the 38/24 unit ?
    If my derailleur was a clamp on , I would just raise
    it and it would fit but its a direct mount .
    ups and downs
    Yes, you would need the SRAM S3 low direct mount FD for the 42/28 crankset. And you'd have to make sure you got the bottom pull version.
    Quote Originally Posted by ccaddy View Post
    the 38/24 unit ?
    Attached Thumbnails Attached Thumbnails Problems fitting an XO crankset to my 950 Element .-sram-fd-low-direct.jpg
  1. Fitting a 104mm BCD ring in a 102mm XTR crankset?
    By hugofabreu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-16-2015, 08:39 PM
  2. n00b crankset fitting question
    By wangmauler in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2014, 07:35 PM
  3. BB/Crankset Not Fitting Each Other SLX M660/SM BB70
    By zachvii in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2012, 08:41 AM
  4. Problems Fitting Brake Adapter 160 to 203
    By Deer_Dodger in forum Brake Time
    Last Post: 01-06-2012, 06:32 AM
  5. Problems fitting a Stinger to a large Spitty
    By magpies14 in forum Banshee Bikes
    Last Post: 04-21-2011, 09:04 AM
