Results 1 to 2 of 2
    Jun 2010
    Problem routing gear cables on Altitude 90 RSL
    Hi, building up an 2010 Altitude RSL, and was going to install the gear cable. Have to tread it inside the frame and on the right side (front deraillure) its no problem. On the leftt side (rear deraillure) i cant get i trough!
    Could it be anything inside the frame routing it wrong?
    Any?
    Elad
    Norway
    In haste to assemble I managed to push one end of the inner hose out of the port socket and it took a while to reposition it with strings. (Never try to push a ferrule through. )
    Try to see if the inner guide hose is at place at both ports. Put a small LED light inside the frame if that helps. If You see the inside of the frame through the side port, then the hose is misaligned.
