Page 17 of 26 FirstFirst ... 7131415161718192021 ... LastLast
Results 801 to 850 of 1275
  1. #801
    My Instinct 950.
  2. #802
    Re: Post your RM shots
    Mine.
  3. #803
    Mar 2005
    Here is my Element 70 (R)MSL after a decently muddy race.
    But I prefer it to be a clean
  4. #804
    I always wanted one in my youth but could never afford it.
    Now I can, so here it is.
  5. #805
    Straight out of the box, no modifications. Maiden voyage will be Tomorrow.
    Post your RM shots-869465d1392336684-slayer-2011-vs-2013-p1050718_zpsa9e8a9cc.jpg
    My bike, Slayer 70
  6. #806
    Aug 2010
    RM Altitude 90 RSL 2010 from Athens Gr
    Post your RM shots-img_20140218_121146_1.jpgPost your RM shots-img_20140218_121203_1.jpg
  7. #807
    Reputation: zonoskar's Avatar
  8. #808
    Before
    After
  9. #809
    ^sweetness^
    My bike, Slayer 70
  10. #810
    Dec 2013
    2014 Instinct 950
    Loving this bike, had it for a month now and rode nearly 500km.
    Added a LEV Integra Dropper Post and Remote Rear Shock Lockout.
  11. #811
    Dec 2013
    Here's my build... 2012 Element RSL Team Carbon. Almost bought a Titus Racer X frame when I got a smokin' deal on this instead. Couldn't be happier! Swapped most of the components over from my Hei Hei. Still waiting for a few carbon components to get this thing under 24lbs for race season. Also saving a few bucks to get proper XT shifters and brakes (rather than the dual control ones I have now). Later on, I might try 650b (if I can swap that fork for the Fox Float F100) and possibly a dropper post! Running it 3x9, but will either switch to 2x10 or 1x10 etc. once I decide.
    Took it for a first ride today... while I need to get used to it for the downhill (and also since I'm going from an oversized 19.5 L frame to a proper medium), at times during the climb I felt like it was almost climbing on it's own!
    Cheers!
    BTW, some seriously sweet rides in this thread! =P
  12. #812
    wheelie king
    Reputation: 661lee's Avatar
    I think the aluminum Instincts look great, love the frame lines.
  13. #813
    Oct 2013
    8 months on.
    <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> Pic of my Altitude 750 taken on the way up Snowdon.
    Fitted stealth, Gore on,Odl grips and carbon fat bar .
    Around 100 hrs riding so far,bike has been awsome.
    Much better shifting on front with the Gore on but still not 100% happy.
    Drop it to 1 very soon i think.
    Found some corrosion inside the bottom race,will be keeping an eye on this.
    Love the Ride !
    <!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
    Altitude 750 2014
  14. #814
    Reputation: Zerort's Avatar
    Jan 2013
    ^^^Complete sentences please. Or is English your second language?
    by Silentfoe
    I'm satisfied knowing that what I wear during my "day" job makes me more of a man than you'll ever be.
  15. #815
    Collector Rocky Mountain
    Reputation: Pizzaman.light's Avatar
    Excuse me, I have a element 950, which mounts to the rear thru axle?
    I know it's a 142x12, but that system? For understanding the step to choose from, I have to change it but I see that there are various choices .....
    Una Rocky e' per sempre,preferibilmente se fatta a mano.
  16. #816
    Jan 2013
    This thread is getting brutal.
    by Silentfoe
  17. #817
    ups and downs
    It's the Shimano system. DT Swiss has an RWS version as well.
    It is not compatible with the Syntace X-12
  18. #818
    Did I post my retro Blizzard yet?
  19. #819
    So dt and compatible with Shimano?
  20. #820
    Reputation: Dr.Zoidberg's Avatar
    Quote Originally Posted by rockyuphill View Post
    I'm not really following what this means. I replaced the OEM DT Swiss wheelsrt on my 2012 950 with an Easton wheelset, 12 x 145 in the rear. Does this mean that Easton uses the Shimano and DT Swiss system?
  21. #821
    ups and downs
    All the 12x142 hubs are compatible, the differences are the way the axle QR interfaces to the frame dropouts that is unique between the Shimano and Syntace X-12. The DT RWS E-12 thru is compatible with the Shimano axle interface. The Syntace X-12 has a tapered seat on the axle interface, the Shimano is flat.
  22. #822
    Rev XX installed.
    Little drop on the altitude. Need a burlier bike i think..
    Any thoughts on how much i can throw with this bike ?
  23. #823
    Mar 2012
    @zonoskar your old rocky is amazing! could you post other photo of the details? and if you can write the list of components... I recognize old turbine crankset, and I think that could be a syncros Ti seatpost...but it's a beautiful ht mtb!!!
  24. #824
    Thanks Archibike! The crank set is indeed an old Turbine, but I don't know how old (there are some numbers on the inside of the arms). The seat post is indeed a Syncros Ti. The rest of the components are Avid Single digit V-brakes + levers, Mavic Crossmax v2 wheels/hubs, a red Flite. Shifting duties are handled by Shimano XT with a XTR rear derailleur (950). Handlebars are from Specialized (still looking to replace those), stem is a Rocky Mountain OEM and the forks of course are Pace RC35 MXCD.
  25. #825
    Rode my first enduro a couple of weeks back; had a great time on this bike!
  26. #826
    Reputation: skyno's Avatar
    New Altitude build
    I'm so stoked to re-join the RM family - RM was my 1st bike in the late-90s - it was stolen - just finished building up my dream rig:
    Frame: Med RM Altitude 27.5 (Full Carbon 770 Frame)
    Shock: Float X
    Fork: Pike RCT3 Solo
    Headset: Cane Creek
    Brakes: Shimano XT Trail 180F / 160R
    Drivetrain: XO1 w/ 32T
    Wheels: LB Carbon Rims laced to Hope Evo Pro II Hubs
    Tires: Hans Dampf 2.35F / Conti X-King 2.2R (Tubeless)
    Stem: Thompson Elite X4 50MM
    Bars: Carbon Haven
    Post: Reverb Stealth
    Saddle: Spec. Phenom Expert
    Ride 9 Setting: Slacked Out! (66 degree HA)
    Weight: Barely 25 lbs. w/o pedals (I couldn't believe it!)
    Took it on it's maiden voyage just after taking these pics - this bike rips - up and down! Couldn't be happier!
  27. #827
    PSE
    PSE is offline
    Reputation: PSE's Avatar
    Oct 2012
    My Vertex 950RSL the last ride before rebuild, as pictured 8.88kg
  28. #828
    Reputation: glorth2's Avatar
  29. #829
    Reputation: caad4rep's Avatar
    Here's my Vertex updated for 2014. It's an oldie but goodie as far as I'm concerned
    Frame: XL RM Vertex SE
    Fork: Fox Float 100 RLC
    Headset: FSA
    Brakes: Magura Marta Mag SL 180mm F/R
    Drivetrain: XTR
    Wheels: Crossmax ST
    Tires: Hutchinson Python Tubeless Light
    Stem: Thomson Elite X4 90mm
    Bars: Thomson
    Post: Thomson Elite
    Saddle: Spec. Fizik Alliante (Soon to be a SI SLR XC)
    Pedals: Time ATAC XC 12
  30. #830
    Reputation: kpm700's Avatar
    My new RM Altitude 750 msl. Got a killer deal on the 2013 closeout and have changed it up quite a bit. Should be competed (for now) this weekend after I install my new X-Fusion Sweep fork, Shimano brakes and WTB Frequency rims with new Maxxis High Roller 2s.
    I've already done the poor man's xx1 with the Race Face wide narrow chainring a the Wolftooth 42t cog. Swapped handlebars and stem for Race Face Atlas ones and ESI grips
  31. #831
  32. #832
    Quote Originally Posted by kpm700 View Post
    Sweet looking rig! I tried really hard to find a '13 closeout, but wanted full carbon - couldn't find one in the US! - and I would have had to pay big bucks to bring it in from Canada so I ended up getting a new one.
    Out of curiosity, how is that Wolftooth 42 cog so far? Do you get flawless shifting or is it a bit sloppy? Also, looks like Gooseberry Mesa in the background?
  33. #833
    Quote Originally Posted by skyno View Post
    I've really like the Wolftooth cog so far. It's pretty flawless with no issues with it at all. Might be a little more clunky getting into the 42t and where the 17t was removed but I don't even think about it when riding.
    The pic is at Little Creek Mesa, just opposite of Gooseberry. Awesome trail
  34. #834
    Reputation: Meladri's Avatar
    Here is my vertex, I just change the origins wheels for now. My first 29 "is really nice.
  35. #835
    Updated with Mavic CrossMax SX wheels, WTB Pure V SLT, circa '06 RMB grips and light 8" rotors.
    My bike, Slayer 70
  36. #836
    Reputation: jrastories's Avatar
    Took long enough but I made the switch to 29 wheels and I'm loving it so far. The bike is amazing to ride. Here's the new Element 999 built up pretty well with a 120 fork on the front, 1X10 XTR and Next SL cranks, formula brakes, stans/dt wheels. It's sitting at 10.3 kg right now but I don't think I want to change anything about it. And unfortunately the nice little puppy sitting in front of the bike just can't keep up any more.
    Rocky Element
    My Attempt at a Blog
  37. #837
    There's no need to fear.
    Reputation: Boofhead's Avatar
    A Pair of Altitudes
    My wife and I both ride Altitudes. Hers is a 2010 RSL 90 and mine is a 2013 MSL 790. Not too many upgrades - we figured Rocky did a pretty good job on both builds.
  38. #838
    Feb 2012
    Sweet ride 14' ∑ RM Instinct 970 MSL
  39. #839
    Crimea, Russia.
    Alititude 750 MSL with mattoc, shimano brakes/transmission
  40. #840
    Reputation: Shakester's Avatar
    Jun 2012
    An updated picture of my Altitude 70. Swapped out the red housings to a less flashy white. Threw on a set of Sun Ringle Chargers as well. Hopefully, I'm done.
  41. #841
    Reputation: sand wedge's Avatar
    Sep 2012
    I had no idea Crimea was so beautiful! What trail is that mountain road?
    Quote Originally Posted by Alpo View Post
    Crimea, Russia.
  42. #842
    Quote Originally Posted by sand wedge View Post
    I has no idea Crimea was so beautiful! What trail is that mountain road?
    Yeah, it's very beatiful place. Sun, mountains and black sea!
    This road runs at the piedmont of the "Dimerdzhi" mountain
  43. #843
    My beast..going on 4 years of straight abuse and still rolling!! love this bike:
    <iframe src="https://www.flickr.com/photos/73141335@N06/14245521219/player/" width="640" height="428" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    <iframe src="https://www.flickr.com/photos/73141335@N06/14245585959/in/photostream/player/" width="428" height="640" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    <iframe src="https://www.flickr.com/photos/73141335@N06/14430919992/in/photostream/player/" width="640" height="428" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    <iframe src="https://www.flickr.com/photos/73141335@N06/14245627260/in/photostream/player/" width="428" height="640" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    <iframe src="https://www.flickr.com/photos/73141335@N06/14245601979/player/" width="640" height="428" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
  44. #844
    Mar 2012
    hy guys!
    Does anyone use or have used the 1x9 or 1x10 with the new narrow-wide chainring on the old Element(or Instict) or Slayer(or edge) 2001-2006 model?
    I'm thinking about a 1x9 configuration for my old slayer and I need to know if with new kind of chainring I can use the bike without chainguide...
    Thanks to all!
  45. #845
    Archibike,
    you can use 1x9 or 1x10 at any bike definitely.
    30.000m descending in Crimea and Alps - no chain loss at all!
    Greetings from France
  46. #846
    Quote Originally Posted by Archibike View Post
    hy guys!
    Thanks to all!
    I've had zero issues with the Race Face narrow wide 30t chainring and the SRAM x-9 type 2 rear derailleur. No chainguide, and I haven't dropped the chain since I got it.
  47. #847
    Mar 2012
    Archibike,
    thanks @Alpo! amazing bike!!!
    thanks @kpm700!
  48. #848
    Mar 2012
    I've finally decided to use 1x9 on my old Slayer... first impression (during a short back-country xc ride) was very good!
    I temporary use a 36t FSA dh ring, and with the correct length of the chain and the good spring of the xtr derailleur, I haven't dropped the chain... probably on september i'll buy raceFace or Hope narrow-wide chainring, but only for aesthetical purposes...
    Some photos of my old rocky
    I hope that next upgrade could be a RaceFaceTurbine crankset, Thomson Am carbon bar and probably an Hope Pro2 gunsmoke rear hub...and a ck headset...
    this white Ritchey comp bar is "a little" hugly if compared to the other components
  49. #849
    Aug 2013
    Early morning ride today. Bike is finally the spec that I want, probably should have bought the Rally edition from the start. Main changes:
    - 160mm pike fork
    - monarch plus debonair
    - e*thirteen chain guide
    - raceface SixC 785mm bar
    - minion DHF/HD tires
    Still need to dial in the suspension, but it's super fun already. Weights 28.8lbs with pedals.
  50. #850
    Aug 2014
    My Rally edition as of last week
