Page 14 of 26 FirstFirst ... 410111213141516171824 ... LastLast
Results 651 to 700 of 1273
  1. #651
    Reputation: glorth2's Avatar
    Quote Originally Posted by spookyload View Post
    Well...I guess I should post a picture of the final build. I have it built with Racing Ralphs on one wheelset and Furious Freds for commuting. XO drive train, XX crank, Crossmax ST wheels, Magura MT-8 brakes, 2013 Fox F100 Terralogic, and Raceface Next SL seatpost bars and Turbine stem. It is wicked light, but haven't weighed it yet. Rides like a freaking rocket.
    If you don't mind my asking, why did you go with the Crossmax STs as opposed to the SLRs? I'm building up a 950 RSL and was thinking of going with the SLRs but my LBS owner is trying to steer me towards the STs. I am 200lbs but not a hucker by any means.
    Thanks.
  2. #652
    Reputation: Lpcunity's Avatar
    Jun 2010
    I'm a bit of a Slayer lover. Lots of RM love from Colorado.
  3. #653
    Jun 2010
    Session
  4. #654
    Jun 2010
    I'm still learning the straight up geometry but so far it's been a fun rig.
  5. #655
    Jun 2010
    I have a friend on the summit of Began Peak in Evergreen Co.
  6. #656
    Reputation: zonoskar's Avatar
    My bike got voted Bike of the Year 2012 by forum.mountainbike.nl (sorry, Dutch only). How cool is that!
    Props go out to Rocky for making such a gorgeous bike.
  7. #657
    ups and downs
    Instinct 970 in its stealthy black glory in the out of doors. I'll take the spoke protector off the rear wheel when the new RaceSport Mountain Kings arrive and I install the tires.
    Attached Thumbnails Attached Thumbnails Post your RM shots-2013_0106new0004.jpg
  8. #658
    @rockyuphill: Ok, we need a FULL ride report, stat! Also compare it to Tallboy LT, Banshee prime, Yeti SB-95 and Kona Satori please Kickin' bike, it's on my short-list to supplement my Element.
  9. #659
    ups and downs
    Quote Originally Posted by zonoskar View Post
    Still limited saddle time on the Instinct 970 with the weather we've had and other commitments. This is only my second experience on a 29" FS bike after the 2hr test ride on an Element 950 last summer at Mont Sainte Anne. Getting up on it and getting rolling reminded me of my Slayer SXC.
    The standard Continental tires are not confidence inspiring on wet roots, my RaceSport Black Chili versions of the Mountain King 2.2's should be here this week, and then I will feel better about tackling wet trail conditions.
    The 70mm stem length makes for a very fast turn in, I sure can't complain about the handling being sluggish. This bar/stem setup is a 725mm wide bar and 70mm stem, and even though the HTT length is 5mm shorter than my 26" Element, this cockpit feels very comfortable.
    With the CTD suspension in the Trail setting the bike feels very plush but not spongy. Even in the D for Descent position, climbing short steep climbs you get a lot of rear suspension movement but it doesn't suck a lot of energy out of going forward, or slacken the bike out too much. I expect that just as with Pro Pedal I will find a Trail suspension setup I like and just leave it that way. It pedals very efficiently in Trail so that must be mostly like the original Pro Pedal valving.
    I was impressed that the Avid brakes bedded in quickly and quietly in wet conditions and stopped well. Maybe I can hold off sticking a set of XT brakes on it.
    I'm using the range of fork/shock pressures shown in the Rocky tech manual (from bikeaction.de) and that feels pretty good, will tinker as necessary. Right now it is setup in the default BB drop of 30mm, after I get some time at this setting, I will try it in setting 2 with 20.7mm of BB drop and then at setting 7 for 35mm of BB drop.
    As for comparing to all those other bikes... well really, none of those are a Rocky Mountain so, you know, how good are they going to be?
  10. #660
    Reputation: Team Rocky's Avatar
    Dec 2008
    New and Old
    2003 Team Element- 2012 Element 50
    Attached Thumbnails Attached Thumbnails Post your RM shots-561730_4135060389170_936756002_n.jpg
  11. #661
    @rockyuphill: Thanks! How are the longer chainstays handling wheelies or getting over logs? Sounds like a winner to me. It's just a shame that the lower speced Instinct 950 looks very much like the Element 970 I already have. I don't care much about all those remote lockouts and stuff from the higher specced Instinct 970 (although the Fox up front is nice). Did you weigh the bike?
  12. #662
    ups and downs
    The bike weighs 30.42 pounds with the Eggbeater pedals. I haven't ridden much gnarly terrain yet, it's been very very wet and the standard Conti tires are frightening on wet surfaces. Once the new tires are here I'll see what it's like on real trails.
  13. #663
    Dec 2012
    Rockymountain Vertex
    Rockymountain Vertex with Rockshox Judy SLs and Red Magura Johnny Ts
  14. #664
    Quote Originally Posted by cdubb30 View Post
    Upgraded the wheels, Thru axle front fork, centerlocks, blacked out post and stem, sick Odis.
    Too bad it creaks like a som'bich cause it actually looks like a 3k+ bike.
    What did it weigh stock? I'm thinking about a 26" Element and wondering if I should go with an aluminum frame or if I should upgrade to carbon.
  15. #665
    Quote Originally Posted by rockyuphill View Post
    Love the stealth look!
  16. #666
    Built my Vertex 29'er SE up into a 1x10 for 2013. Sweet!
  17. #667
    ups and downs
    A pleasant dry, cool, sunny day and hero dirt. First time on this 26" wheel bike in a few months. Sure is lighter than the Instinct and the carbon wheels are sure lighter. Still no firm favourite.
    Attached Thumbnails Attached Thumbnails Post your RM shots-2013_0210new0005.jpg
  18. #668
    My 2012 Rocky Mountain Slayer
    Post your RM shots-dsc02243.jpgPost your RM shots-dsc02251.jpgPost your RM shots-dsc02252.jpgPost your RM shots-dsc02253.jpgPost your RM shots-dsc02254.jpgPost your RM shots-dsc02255.jpg
  19. #669
    Quote Originally Posted by Lpcunity View Post
    Nice pose
  20. #670
    Oct 2011
    love the white! I have the 2012 70. What chain guide have you fitted and any probs with it?
  21. #671
    Blackspire stinger. Its OK but I would spend the extra money and get something better. I am going to a 1x10 blackspire der chainguide.
  22. #672
    Nov 2007
    I've had this bike for a few weeks now, but held off posting until the ENVE wheels got fitted! I had the 2012 970RSL Alloy and still, until getting its carbon blinged sibling 999RSL, is the most amazing dually I have ever ridden.
    At the moment the bike is stock except for the ENVE handlebar and wheels (including tyres). Very lucky that our shop owner is best of mates with the Australian distributor of ENVE and looked after the team very very well. Bike weighs in at 10.15kgs on the bathroom scales.
  23. #673
    element 999
    I have the stock white saddle and will probably go back to that one to better match the wheels and grips. pretty stoked on the build. full xtr with shadow plus. king cage - ti cage
  24. #674
    Mar 2013
    Yes. Still riding my 2002 Blizzard. It's been my primary ride for 11 years and it is getting new drivetrain as we speak. Reborn for another good run!
    Quote Originally Posted by Sixty Fiver View Post
    Does anyone still ride steel ?
    Got the frame rather cheap and built it up with some spare parts... Race Face crank, XT derailers and brakes, Avid levers, Mars Elite fork Raceface bars, no name stem, Race Face bars, Pro Logic headset, Oury lock on grips, XT triggers...
    The rather excellent rear wheel came off my old Hammer and I upgraded the 7 speed freehub to an 8 and I built up the front wheel with an Suntour XC Pro hub laced to an NOS Rhynolite.
    The Blizzard is the sweetest hardtail I have ever ridden... it handles like it is on rails and climbs like a goat on speed.
    A back injury has kept me off the trail for over a year but I got the bike a little dirty tonight...
  25. #675
    Sep 2012
    It weighed in at 26lbs. Had to get rid of it though. Frame warranty issue with the bushings and the rear drop out burned me though.
  26. #676
    BJF
    BJF is offline
    Apr 2005
    Post your RM shots
    2012 970.
    Just got a set of enve wheels.
  27. #677
    Collector Rocky Mountain
    Reputation: Pizzaman.light's Avatar
    Scream, a fairy tale.
    Una Rocky e' per sempre,preferibilmente se fatta a mano.
  28. #678
    Reputation: Puxa!'s Avatar
    I think I may participate in this thread with mine.
    This is a quicksand trap I got into two days ago...
  29. #679
    Feb 2010
    Custom Element for sale on eBay
  30. #680
    Mar 2013
    Update on 2002 Blizzard Rebuild: While enthusiastic about giving the bike a second life, the shop found cracks in the head tube and chainstay welds at bottom bracket. Sent pictures off to RM to see what they want to do. Rebuild on hold - had to buy a used Santa Cruz Highball Carbon as used market on RM Hardtails is next to nil. Would love to have picked up a used Vertex 29 Carbon instead but no such animal in the used market. Lucky to find the SC in a medium on short notice.
    Waiting to hear the verdict from RM. It is confusing as one senior tech said definitely cracked, unridable, you are so lucky it didn't go on you at speed and another independent tech said naw, it's just the paint cracking!
    Silver Lining - i get to try a carbon 29er.
    David
  31. #681
    President of the Internet
    Reputation: Widgeontrail's Avatar
    Mar 2006
    There's a 3/4 pound difference between the alum and carbon frames. Not worth the extra $1000 imo.
    Sometimes you eat the trail, sometimes the trail eats you.
    Thinking of buying a home?
    http://Search-Sacramento-Homes.com
  32. #682
    Altitude 70 2010
    Best frame i've ridden so far. Only thing missing is a Dropper post.
    Slacked the headangle a little bit with the Sektor forks.
  33. #683
    Nice Altitude
  34. #684
    Kickin it Old School
    Far from Stock 1996 RM Cardiac.
  35. #685
    Still loving the Element 970. And with the help of RMB-PM2, I now have a new set of bushings to replace the worn ones.
    Last snow of this winter (I hope):
  36. #686
    Mar 2005
    Got new parts for my Element.
    Race Face Turbine Stem pimped with black Ti screws (125g) and an Race Face Next SL 630mm bar (135g).
    Compared to my old set up (F99 stem and 87g 590mm Carbon bar) this Race Face combo is a bit heavier, so I ordered a new Crank set to neutralize wheight penalty
    The new season has started quite well
    Finally still 9.52kg.
  37. #687
    ups and downs
    Had the hardtail out for the first time in a long while today. It was nice riding a 19.5 pound bike again. But I kept anticipating the geometry change from the Element rear suspension compression while cornering or being out of the saddle. That was amusing.
    Attached Thumbnails Attached Thumbnails Post your RM shots-2013_0504new0002.jpg
  38. #688
    Reputation: Dr.Zoidberg's Avatar
    Where did you get the Rocky chain stay protector!?!
  39. #689
    What kind of tires are you running on the 970 and how do you find them? I'm thinking about either Mountain King II (black chili, protection) or Nobby Nics (snakeskin, pacestar) for my 950.
  40. #690
    Quote Originally Posted by Team Rocky View Post
    Nice 03 element.
    I have a 98 still in great shape that looks just like it.
    Minus the disc brakes
  41. #691
    Reputation: sand wedge's Avatar
    Sep 2012
    Quote Originally Posted by mrwulf View Post
    mrwulf, where did you get the Rocky Mountain chain stay protector?
  42. #692
    Mar 2005
    This is a self designed chainstay protector. So unfortunately not available ready to use in an shop.
  43. #693
    Sep 2012
    That's great attention to detail!
  44. #694
    If either of RMB-PMs are viewing....please get RMB protectors into your store! I have a feeling there is fairly strong demand for them....
  45. #695
    So went for a Gravity Dropper to finalize the build. (minus the white tie wraps,still determing the cable routing)
    And shot some better pics.
  46. #696
    Sep 2012
    mrwulf,
    Am I reading this correctly that your bike weighs only 9.52kg? That's just under 21lbs! Can you give us a breakdown of the components? I assume you are running tubeless?
  47. #697
    Reputation: jallll's Avatar
    Dec 2008
    Re: Post your RM shots
    my ex hammer than now is owned by civilense in foromtb...
    i can,t understand why rocky doesn,t sell it now...... can niner sell a sir and no one will buy the hammer??
  48. #698
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
  49. #699
    Mar 2005
    Quote Originally Posted by sand wedge View Post
    mrwulf,
    Hi sand wedge,
    yes I am running tubeless and I really can recommend it. Here we have the detailed parts list
    <a href="http://fotos.mtb-news.de/p/1371378" ><img src="http://fstatic2.mtb-news.de/f/a3/97/a3973hsdi1ph/large_2013_05_ElementParts.jpg?0" class="fotoalbumLikeable" data-photo-id="1371378" /></a>
  50. #700
    PSE
    PSE is offline
    Reputation: PSE's Avatar
    Oct 2012
    Vertex 950RSL 2013 (M), ~ 9.7kg
