Congrats on the acquisition.
Judging by the crown finish and shape of the lowers, the fork looks like it might be a Rock Shox Psylo from 2003 or 2004.
Thank you for the info on the fork! It sure looks like the one you named from searching through some pictures. Is this fork worth servicing, or am I better off looking for another new/used fork?
If there's no obvious wear on the stanchions it's worth a shot at servicing it. Fork damping technology has improved a lot in 10 years, and you'd likely benefit from a more modern adjustable travel fork like the ETSX50 and ETSX70 were shipped with (Fox 32 TALAS)
Thank you Rockyuphill. Your advice has been very helpful.
Upon closer inspection the front stanchions have a few minor blemishes, so I am looking into replacements. I've found a great deal on a pair of new Suntour shocks. The model is: SR Suntour Epicon TAD. I know the brand isn't the best, but for my needs would this be a good investment? As this was for a pair of shocks, I would outfit the other on my wife's Iron Horse 4.5 Maverick bike.
They look like an OK fork, and they have travel adjust of 100-140mm, so that should work well.
I just acquired an ETSX Scandium frame myself. As of right now, it sits on the workbench. All the paint has been removed, so it's bare aluminum. I'm debating powder or anodizing it. I'm trying to build this thing on the cheap. The biggest investment will be the fork. I'll start a new post when I get it going.
Rocky's Scandium Team frames have always been wet painted because the temperatures for powder coating weren't compatible with the heat treating of the scandium frames.
Good to know that! I will be painting mine later on this year. So far have somewhere between 250 and 300 miles on mine and I need to replace the crank bearings. The bearings just started to make some sounds that are less than ear pleasing. Also decided to stick with the normal for for a bit more. Figured it'd be best to put something nice up front that will last.
Do you know if the Scandium can be anodized without hurting the integrity of the frame? Otherwise, I'm good to go on my graphic-less, somewhat polished ride!
Also, does anyone know if the newer rear triangle, linkage and shock can be adapted to the older front?
From Easton's Scandium fabrication instructions
2.8 Frame Finishing
2.8.1 Wet Paint
Wet paint is the preferred finish for SC7000 to promote an attractive finish and maximize material properties.
2.8.2 Anodizing
Anodizing SC7000 frames should not be performed. Anodizing will significantly reduce frame fatigue life. In addition, the unusual grain structure of SC7000 tubes will become visible after anodize resulting in an undesirable cosmetic finish.
2.8.3 Powder Coating
Traditional powder coating can not be used on SC7000 frames due to the curing temperatures. Powder coating (or any other thermal process) can only be performed as long as the curing temperature is not higher than 325 degrees and the cure time is less than 30 minutes.
These lower temperature powder coat materials can be obtained from:
SPRAYLAT Corp.
3333 N. Interstate 35
Gainesville TX 76240
(817) 665-9590
Toll Free: (888) 725-7250
There are some limitations to rear triangle interchangeability of the later models. You'd need to compare the tech manual exploded diagrams and parts list from the years of interest to see if they are compatible.
Thanks for that info, rockyuphill. Maybe I'll just rattle-can this thing some obnoxious fluorescent color on the front triangle, and a contrasting fluorescent on the rear! Nobody will want to steal it then!
Neon + spatter... then they'll steal it because they will think it's some exotic MTB from 1986
By muffetmd in forum General Discussion
Last Post: 03-30-2013, 04:57 PM
By ironbrewer in forum Rocky Mountain
Last Post: 01-31-2013, 01:51 PM
By muffetmd in forum Bike and Frame discussion
Last Post: 07-10-2012, 12:57 PM
By muffetmd in forum 650b/27.5
Last Post: 07-07-2012, 04:05 PM
By Gildnerb in forum Rocky Mountain
Last Post: 12-09-2011, 08:19 AM
- You may not post replies
- You may not edit your posts
Forum Rules
