Hi all....running the stock Vanilla on my ETSX and looking for a new fork. Upgraded the shock to a RS MC 3.3 and love it. Just need something new and more solid on the front. Considering last years crop of forks for budget purposes. Looking @ Nixon 115-145, Pike 454, or All-Mountain SL. Basically it has to have thru axle(heavy guy @ 200#'s), and variable travel. Anyone care to make any comparisons.
I got a 2007 AM 1 SL on my SXC and love it, but I think that it may be too tall for an ETS-X.
A Pike would fit nicely, though I've only seen one on an ETS-X so far...
No, my 2005 ets-x was replaced by an sxc after I discovered a crack in the seattube. I'm missing it, it was such a versatile bike! It had a fox talas (100-140mm), great fork but without a through axle...
I'm sure a fork such as those listed above are built more for a 6" trailbike than an ETSX. However I am a bigger guy and the fox on the front right now is too squirmy. I'd prefer something with a thru-axle and longer travel, not for hucking off stuff, just for very steep declines.
Fox 36 TALAS. (100, 130, 160mm of travel with 20mm thru-axle). Just a question, what version of Vanilla do you have (R, RLC et.)? I'm 220 lbs and have the same bike with a Fox 32 TALAS RLC and it doesn't feel squishy at all.
Adding a fork with more than 140mm travel might void your frame warranty, best to check into it first.
The new Marzocchi 55 ATA fork is continuously adjustable from 125-165mm, so you could adjust that anywhere within the 125-140mm range. When cranked down to 125mm it's about the same height as any other 125mm fork. A bit chubby at 5.11 pounds though.
Vanilla R '04. Its not because its flexing that I'm looking for a new fork, more like I need a higher a-c for steep chutes and variable travel for so I can crank it back down for normal riding and tackle uphills. Fox 36 are nice but a bit too burly and expensive for what I'm looking for.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
