Results 1 to 6 of 6
    Reputation: skyak's Avatar
    New Altitude Head Angle
    On the Rocky Website it lists 66.6 - 68.3 as the head angle range under the Geometry tab, and 66.9 to 68.1 on the Downloadable Info Sheet.
    Anyone know which is correct?
    Also...Based on the dimensions of the frame, my calcs indicate that a 15mm reduction in fork height will result in a ~ 0.7 degree increase in head angle.
    ups and downs
    If you're talking about the new 650B Altitude, the head angle adjustment comes from the Ride 9 adjustment of the rear shock position, not the fork travel.
    The most accurate angle info is likely on the Altitude Ride 9 geometry calculator
    Ride 9 || Rocky Mountain Bicycles
    Ya...the Ride 9 shows 66.6 as well. Probably the Info Sheet is outdated.
    I was doing the fork calcs to determine the head angle effects of using different forks, for example:
    the normal Fox 32 150mm is 520.9 mm.
    the Magura TS8 150mm "650B' fork A2C length is 530mm;
    the RockShox Rev 650B is 539mm;
    the Fox 34 650B is 544.5mm in 150mm mode.
    Potentially I could use a different fork with a slacker ride 9 set-up and find a happy medium.
    ups and downs
    In very general terms a 25mm change in fork A2C is worth about 1 degree in head angle change for the typical range of MTB wheelbases and geometries (plus or minus a bit).
    This fork looks interesting to me. Not sure where you can buy it in Canada though.
    2013 TS8 650B 150 Tapered
