Results 1 to 10 of 10
    help with 2001 pipeline
    I just bought a used 2001 RM pipeline and from what i can see in pictures there should be a fitting in the rear arm across the upper brace for the front derailleur cable tubing to go to and use as a stop. Mine just has four holes in that brace but it does look like at one time a fitting was in one of them. Any ideas on where i can get that piece or who should i speak with. I do not know of any rocky mountain dealerships around my area in western NY.
    Any help would be appreciated.
    Thanks Matt
    Jan 2005
    You could give RM a call (look up their number on their website bikes.com). A pic would really help us understand your problem. Is it something you can fix with a zip tie?
    I know exactly what you are talking about. The original piece on mine was made out of some sort of plastic that "extruded" itself through the hole after a while. I replaced the part with a modified stainless steel socket head bolt (#10-32 I think) that I center drilled through to act as a cable guide. A quick/easy way to fix it would be to locate a front brake cable hanger bolt off an old canti setup and drop that in there (so long as it doesn't fall through the hole). Hope this helps. Good luck.
    Reputation: Angel Dust's Avatar
    Hi guys!
    Need your help on this one. Ever since RMB stopped entertaining online queries from their consumer, I'm kinda stuck with this. I know the Pipeline has 4 to 6" of adjustable travel in the rear, but what I'd like to know is which setting equates to what amount of travel? I've marked out the 3 points in the attached pic.
    I'd be grateful for any kind of help. Also, there seems to be water trapped inside the frame. Even after stripping the frame, I can't seem to find a way to get rid of the water. Where could the water have seeped in and how do I get rid of the annoying swishing sound?
    Thanx!
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    A is 4", C is 6".
    I don't post to generate business for myself or make like I'm better than sliced bread
    Thank you very much. Really appreciate the info.
    Nov 2007
    I just checked the one on my 02 pipeline and it looks and operates like a wheel skewer but with a heavier spring. I'm trying to figure out the lockout any idea on that?
    BT
    Lockout? Pipelines don't need lockouts. The "skewer" is just for quick-changes of the wheel travel/leverage ratio.
    Nov 2007
    Quote Originally Posted by DeeEight
    I was reading on another post that there was a lockout on the shock. As I'm pretty new to a full suspension bike I was wondering what position the blue lever on the shock needs to be in to make sure if there was a lockout it wasn't locked. In looking at the fox site this is the story:
    The compression adjuster is the blue lever. There are three options for lever position for the Vanilla RL. For one option, the lever is at a 45° angle counter clockwise to the shock in the normal position. Moving the lever clockwise 90° increases compression damping. On another option, the
    lever is in line with the shock in the normal position. Moving the lever 180° in either direction increases compression damping. On the third option, the lever is in line with the shock in the normal position. Move the lever 90° clockwise to increase compression damping. The increased compression damping setting will be firm but will “blow off” under a big hit or heavy load.
    On a regular RL, the blue lever activates the lockout. RMB has long had custom valved fox shocks though, and since the pipeline being an URT doesn't need a lockout shock, its probably been revalved so that the blue lever varies the actual compression damping range instead of just having the circuit open or closed.
