Results 1 to 9 of 9
    Mar 2011
    Fork for 2014 Instinct
    I had a chance to demo the instinct and had a good time with it. Im thinking of building up a frame and would like to put a rockshox pike on the front. What is the consensus on a 140mm vs 150mm fork on this frame. I have heard that the pike has a shorter axle to crown than the fox 34 and so i wondered if a 150 would be ok even though rocky specs the bike with 130-140 fox forks. My concern with a 150 is that the bike might not feel balanced with the 130 out back. Thoughts? Thanks in advance.
    Axle to Crown:
    Pike 150mm: 561.0mm
    Original Fox 32(!) 130mm used on Instinct 2014 MSL:: 530.8mm
    Attached Thumbnails Attached Thumbnails Fork for 2014 Instinct-2014_fox_32_29in_44mm_rake_user_spec_revb.jpg
    Attached Files Attached Files
    ups and downs
    Interesting, Fox does a 44mm and 51mm rake 29er fork, and Rock Shox does a 46mm and 51mm rake fork. I wonder what the fork spec should be for the Instinct?
    Mar 2011
    I was thinking of comparing the pike to the fox 34 rather than the 32. The 34 in a 140 has an axle to crown of 553mm.
    ups and downs
    All the Instinct models use 32mm x 130mm forks, so that 530.8mm A2C would be your reference fork height.
    Quote Originally Posted by rockyuphill View Post
    Except BC Edition with 34 Fox. ;-)
    Maybe i am wrong, but in my opinion the Instinct with 150mm front is too high and will loose all his great uphill Performance and "flowy" characteristics.
    I go with Rockyuphlll and the 530.8 reverence...
    Mar 2011
    Thanks....I'm pretty much looking for a BC edition type build with different components so I thought I would just get the frame. It sounds like the pike 140 would be the way to go. I was talking with a buddy and the rocky dealer owner and they both recommend the 150 based on my desired intent. I too thought that doing that may sacrifice the bikes all around capabilities even with a zero stack headset and the stem installed low against the top tube. Thanks for the responses.
    ups and downs
    I found out some useful info.
    The 130mm travel Instincts use a 32mm fork with 44mm offset (rake).
    The 140mm x 34mm fork on the BC edition uses the 51mm offset (rake) to speed up the handling to compensate for the longer travel.
    Feb 2014
    Did you ever get your bike sorted with the pike? I'm looking at doing the same with the 140mm 51mm offset.
  1. 2014 Rocky Mountain Instinct
    By CannondaleF9 in forum Rocky Mountain
    Last Post: 03-09-2016, 06:11 PM
  2. Fox fork on the 2014 Crave Pro
    By mtb_beginner in forum Specialized
    Last Post: 09-18-2013, 09:11 AM
  3. 2014 Epic max fork?
    By molopoko in forum Specialized
    Last Post: 09-16-2013, 07:18 PM
  4. Instinct 950 or Element 950
    By marmoset in forum Rocky Mountain
    Last Post: 05-06-2013, 11:56 AM
  5. Julbo Instinct
    By Michaelk in forum General Discussion
    Last Post: 01-08-2011, 05:45 PM
