Results 1 to 3 of 3
    Sep 2012
    element bc edition fork air pressure
    Hi guys, any bc edition 120mm fork travel riders out there?
    I ride an element bc edition mostly in the 120 mm travel position. I rode it all last year and had to have a fork swap mid season. The seals would melt on the stanchions due to high friction coefficient I believe and it would hinder fork response, the crown also creaked. So fox sent me a new tallas with the 2014 ctd upgrade. On that last fork the ctd failed 1.5 months after receiving it and the rear ctd as well. So I sent it back in for service at fox and had them rebuilt and I had both rear shock and fork kashima coated.
    But I still find that the fork sits low in its travel as did the previous forks with the recommended air pressure. I am 6'2'' weight 195-200 geared up ride an XL frame and mostly ride standing position so weight slightly more forward. I don't seem to get full compression travel even with the recommended air pressure. Seated sag seems ok but standing position, I find it sits low in its travel. SO I'm tempted to ad air pressure like maybe 110 pds but then It will sit higher when standing pedalling but I will get even less compression travel. Any suggestions ?
    Tks guys
    ups and downs
    Set it up based on 25% sag for the way you ride it, and it will all work out if you ride in that position consistently. If you aren't getting full travel, drop the pressure a couple of PSI at a time until you do.
    Nov 2013
    I'm closer to 220 geared up and I run 105lbs in the forks. Admittedly, this is my first 'modern' fork so I don't have a lot of comparisons, but it feels pretty good at that pressure. I'm running rebound in the middle and compression set softer (#1) when the ctd is in the trail position.
    I hope I got all that lingo right. I've slowly reduced spring rates and tire pressures week over week...against my instincts, but tue bike definitely feels plusher and more controllable.
  1. Element 970 handling vs 970 BC edition
    By Michaud in forum Rocky Mountain
    Last Post: 09-07-2014, 03:37 PM
  2. element bc edition diet
    Last Post: 11-11-2013, 10:11 PM
  3. 2013 element bc edition tubeless set up
    Last Post: 08-26-2013, 05:03 PM
  4. Replies: 1
    Last Post: 03-30-2013, 09:38 AM
  5. 2013 Element 970RSL BC Edition
    By Saddle Up in forum Rocky Mountain
    Last Post: 10-25-2012, 04:54 PM
