Results 1 to 3 of 3
    Jun 2012
    Element 950 main pivot bolt
    Just read that those have not been greased when istalled.
    Can I remove just the main pivot bolt, grease it with out disassembling
    the rear triangle?.
    Or maybe just remove shock mount from top tube to take tension off
    Tx
    ups and downs
    You can do it without disassembling anything other than removing the crank. You need to be able to get at the bolt behind the drive side crank and chainrings.
    Jun 2012
    Cool, thank you Sir.
  1. Main pivot pin loosening
    By brant in forum Titus
    Last Post: 05-29-2012, 12:03 PM
  2. Intense M1 Main Pivot Bolt Stuck ?
    By heavyp in forum Intense
    Last Post: 05-28-2012, 02:29 PM
  3. Need main pivot bolt!!!!!
    By Coopie in forum Diamondback
    Last Post: 09-14-2011, 12:27 PM
  4. K2 EVO main pivot bearings
    By Bark Rash in forum Shocks and Suspension
    Last Post: 08-03-2011, 10:30 PM
