Results 1 to 14 of 14
    Oct 2013
    Creaking Rocky 730 Altitude
    I have tried everything cleaning bushings.Checking chairing bolts tightened crank, new BB,checked axle for tightness, greased seat post. Checked steerer tube greased and prepacked head set. Greased spider on cranks. PLEASE HELP BEFORE IT GETS CHUCKED INTO A POND OR PUT INTO A CAR CRUSHER. Thanks guys Jack Graves!!!!!
    ups and downs
    90% probability of dry metal to metal contact in main swingarm pivot axle.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    after everything else you've done if greasing the swingarm pivot doesn't resolve it see if you've got pedal washers or at least grease on the threads and spindle/crank interface. i've actually stripped and rebuilt more than one bike with a phantom creak only to find that was the problem.
    now it's generally the first thing i check/eliminate since it's the simplest.
    "Knowledge is good." ~ Emil Faber
    ups and downs
    I chased a creak on my aluminium hardtail for almost a year, replaced or greased everything, only to find one day it was the nylon buckle on my hydration pack.
    Oct 2013
    Quote Originally Posted by rockyuphill View Post
    Thanks guys I have checked my peddled also. Ill try greasing all my pivots again. I'm about to just live with it or maybe sell it. I Love the Bike but the Creaking is Driving me Bonkers.
    Reputation: binrat's Avatar
    May 2005
    Shock bolts for the rear shock?? That's what fixed mine.
    ups and downs
    All the metal to metal contact points in the Ride9 hardware should be greased as well.
    May 2005
    I did that at the same time as the shock.
    Oct 2013
    Thanks guys ill give the shocks bolts another try I appreciate all the feedback.
    Reputation: Kliemann53's Avatar
    I have the same bike. Try opening the QR on the seat post tighten nut 1/8 to 1/4 turn close QR. that's what fixed mine.
    Oct 2013
    I have a different none quick release seat clamp thanks though.
    Do you have a dropper post? When I bought my bike I also got a stealth post, it made allot of noise. the shop that installed it found they had put the top piece on backwards.
    Oct 2013
    No dropper I put a Thompson but it creaked before the switching of seat posts.
    Aug 2014
    Same frustration... creaking, but found a solution (at least for me)
    Quote Originally Posted by jackgraves View Post
    I also have been exteremly frustrated with the amount of noise this bike creates after only 230 off road miles on it. I did find 3 main sources for my creaking (which now have been solved and back to a quiet bike). First the seat tube; Even though my seat was not slipping I found that my seat tube/seat post was causing a creak. I tightened up the seat post collar and that cured that particular creak.
    The next creak which I could not identify the location for several weeks, turned out to be the 4 bolts on the handlebar stem mount. I slightly tightened each of the 4 bolts and this solved the noise. I could not re-create the noise without riding so it was difficult to identify the location of the creak. It sounded like it was coming from the headset and sometimes sounded like it was coming from the shock area.
    Lastly, I had to perform this twice so I am not sure which ABC bushing it was but I took apart the rear pivot near the derauiler along with the main pivot by the BB and all the pivots near the shock. Althought they indicate no lube required, I cleaned each and installed back with a little grease on each. This finally solved all the creaks I have up to this point.
    I am still disappointed that a bike with so few miles on the trail developed so many creaks (my 2004 stumpjumper did not develop any creaks until several years old and were easy to identify and fix) but I guess with this much travel and the suspension design there are going to be some trade offs. anyway I hope my tips help
  1. 2013 Altitude 750 -- creaking noises
    By uberstein in forum Rocky Mountain
    Last Post: 02-22-2016, 02:42 AM
  2. Rocky Mountain Altitude 90..?
    By EFMax in forum All Mountain
    Last Post: 05-07-2013, 12:11 AM
  3. My Rocky Mountain Altitude 29
    By Fuze911 in forum 29er Bikes
    Last Post: 12-18-2012, 01:26 PM
  4. Creaking on Altitude 70RSL
    By jesse101 in forum Rocky Mountain
    Last Post: 06-30-2012, 08:52 PM
  5. Rocky Mountain Altitude...
    By BlackCanoeDog in forum Eastern Canada
    Last Post: 07-11-2011, 11:44 PM
