Results 1 to 5 of 5
    Coil shock on a 2012 slayer 50
    Who's done it. Pros and cons? Does the bike still climb well? I don't shuttle very often, mostly climbing up and riding down.
    ups and downs
    What's your goal for the change? Are you you having trouble getting the bike dialed in for your weight range?
    Mostly just a bad case of upgrade-itis and i can get a pretty good deal on a fox shock. I also feel like I'm adding a lot of pressure and still going through my travel pretty quickly. Or I add too much pressure and its too firm. I can't seem to find the right range. I'm about 220#s all geared up.
    I also have a 140mm hard tail 29er that is my go to trail bike, so I was thinking of beefing up the slayer a bit.
    Dec 2012
    I'm planning on adding a vector HLR coil on mine sometime this year, if you do it let me know how it turns out!
    I have the same issue as you, too much air and it's too firm, just under that and it goes through the mid-strock too quickly. It must not be a weight thing, because I'm about 150 all geared up.
    If its a 2012, then its a Fox RP23 right? You might try just spending $14 on a volume reducer kit from Fox. This will keep things active and make the shock more progressive towards the end of the stroke. The kit comes with 3 plastic reducers, which take about 2 minutes to change. Try the larger volume reducer first.
  1. 2012 RM Slayer Rear Shock mounting hardware
    By KaiFD3S in forum Rocky Mountain
    Last Post: 05-13-2013, 06:01 PM
  2. RM Slayer with coil shock
    By tim_from_PA in forum All Mountain
    Last Post: 05-02-2013, 02:16 PM
  3. 2012 RM Slayer build shock advice
    Last Post: 04-27-2013, 07:24 PM
  4. REAR Coil shock on sj evo 2012- ?
    By gozal in forum Specialized
    Last Post: 02-10-2013, 02:31 PM
  5. Slayer SXC and coil shock
    By Verkebyll in forum Rocky Mountain
    Last Post: 12-21-2011, 02:43 PM
