Betd strong bushes on 2011 slayer 50?
Does anyone use the Betd strong bushes on their 2011 slayer and know what size to order?
I think I'd like to try them out, but I'm not sure what measurements they are looking for and I am not sure that I have a measuring device accurate enough to do my own measurements anyway.
The BETD reducers are identified by the overall width of the reducer (typically in the 15.75 - 32mm width range) and the bolt hole which is either going to be 6.1mm (1/4") or 8.1mm (5/16").
You can measure the width of the Fox alloy reducer in the shock by using a pen and marking something like a matchstick through the bolt hole, and then measuring the mark on that matchstick.
Thanks for the reply!
Thanks a lot! I'll get to measuring... seems simple enough.
T
- You may not post replies
- You may not edit your posts
Forum Rules
