Results 1 to 15 of 15
    Sep 2012
    bc edition creaking noise since new
    I have been trying to find the source of a sound that sounds like shot pedals. At first (when new) I thought it was my 1 year old shimano pedals that were creaking so I got a new pair, the creaking is still there. My LBS greased everything greasable (bushings, bolts, crank,...), changed cable housings but it's still there could it be a carbon fracture in the frame? Any other thoughts? Worst thing is they have the same bike as a demo in the bike shop ant it's creak free.
    Dec 2009
    Every time I hear a creak I overreact and think it is something major. More often than not it is the seatpost either needing paste or being under torqued.
    ups and downs
    I chased a creak like that for a year, it turned out to be the buckles on my hydration pack.
    Reputation: zonoskar's Avatar
    Did you change the cleats when you changed the pedals? Might be worn cleats.
    Sep 2012
    Seat post has been greased and torqued to spec, as for the pedals, I even went with flats and the creaking is the same. I can reproduce the creaking by standing beside the bike brakes locked and by applying side pressure to the crank or frame(so prob not from the hydration pack). Some of the creaking definitely is comming from the fork but everything greasable has been greased and tightened so it's either from the stations or head tube part. Some of the creaking I suspect might be from the susp bushings but they've been greased. Oh and it's really bad, cracking symphony, I even hear a squeak, from the fork seals I believe, sometimes. I don't know if the whole thing will fall apart or ???. Bringing it back to the bs tomorrow and they will remove the fork for testing and verify the rear plastic bushings. I will Keep you posted. Any other thoughts
    Reputation: Tarekith's Avatar
    Mar 2005
    Been hitting my bushings with WD40 after washing per Rocky's suggestion, seems to be keeping the creaking away for now.
    Tarekith.com
    '17 Specialized Enduro Elite 29
    Feb 2006
    Spokes?
    Sep 2012
    Quote Originally Posted by Tarekith View Post
    Thanks I will try that, funny the seem to creak the most when hot, like after 10 minutes of slightly ruff stuff.
    Sep 2012
    Quote Originally Posted by Pisgah View Post
    Spokes?
    Spokes seem ok it's really coming from the rear susp bushings I think, mostly when they're hot and from the fork. The lbs mechanic took the fork off and figured out that it was creaking at the crown when off the bike, so a fox issue for that end.
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Triflow on the stanchions and the steer tube, makes everything better. WD40 won't last long enough, it'll evaporate quickly.
    Mar 2005
    Rocky specifically recommends WD40 as it displaces water out of the bushings helping prolonge them. It's not meant to be a long term lubricant solution.
    Tarekith.com
    Where did you find this info from Rocky? I recently aquired (won actually!) a 2013 Instinct and have been disapointed in my search for technical data from RM. My old bike is a Specialized and you can find all kinds of tech data on their site.
    Mar 2005
    Quote Originally Posted by KThaxton View Post
    http://www.bikeaction.de/media/pdf/2...nual_Final.pdf
    Page 5
    My last bike was a Spec Enduro as well, and yes they make it really easy to find the info you need.
    Tarekith.com
    ups and downs
    There's also a 2013 manual on the Bikeaction.de site
    http://www.bikeaction.de/media/pdf/2...ANUAL-Jan9.pdf
    Awesome! Thanks guys...
  1. Creaking noise 575 with MRP LRP
    By Ehien in forum Yeti
    Last Post: 01-20-2013, 04:41 PM
  2. El Mariachi Creaking Noise
    By Malibulx3 in forum Salsa
    Last Post: 10-15-2012, 08:33 AM
  3. Anyone else have a creaking noise?
    By msouthall669 in forum Trek
    Last Post: 06-24-2012, 09:21 AM
  4. Creaking Noise In My Crank Set
    By Cabaku in forum Beginner's Corner
    Last Post: 07-02-2011, 09:33 PM
  5. ENDO Creaking Noise.
    By hjb117 in forum Knolly
    Last Post: 01-23-2011, 11:02 PM
