• 07-04-2012
    LeeL
    Anyone running a SLX front d on RF Turbine cranks on a RSL 70 Element?
    Subject says it all - anyone running a SLX front derailleur (M661) on RF Turbine cranks 2x10 cranks on a RSL 70 Element?
    It's a bugger to adjust. No problem on the granny. Getting it to shift to big is tricky. The upper limit is set so the inner part of the SLX front D cage is just missing the little ring and even so the chain does not want to go from granny to big.
    Or should I just raid RMB-PMs parts desk
  • 07-05-2012
    rockyuphill
    Are you running the front shifter in 2 speed mode? That does make a bigger difference than it should
    Are the RF cranks setup with the 1mm rubber spacer on each side for a 50mm chainline?
  • 07-05-2012
    LeeL
    oh whoops on the front shifter! Going to configure that
